Introduction: Batch Tutorial - Take 1
Well i have seen a few batch tutorials out there, but none of them really follow up with anything so I'm making a 3 part tutorial on batch, with videos just for that extra ease.
I will attach all .bat (batch) files needed in their appropriate
step.
step.
Step 1: Hello World!
To start of to open the Command Prompt just click "Start => Run and type 'cmd'"
Basically to start off with you should open notepad and type:
Now with batch files there are various ways to "communicate".
For example:
We will be using all of them except echo as it is pretty self-explanatory.
@echo offWhat this does is essentially block the command from showing while still showing the output.
For example:
@echo offecho hello worldmsg * hello worldnet send * hello worldGo ahead and write that into notepad and save it as com.bat. Then double click to start.
Step 2: A Little More "tricky"
Okay now we get into a little more complicated, we'll not really. :D
Start off with a blank notepad document and type this:
pause basically waits for you to press ANY KEY to continue.
And you know what msg does from the previous step..
Try this out by saving it as tricky.bat.
@echo offshutdown -spauseshutdown -amsg * tricked you!! hahaNow shutdown basically just shutdowns the computer. Look at the video for a more in detail look or type shutdown -? into cmd.
Step 3: Fork Bombs / Infinite Loop (the GOTO Trap)
Basically all a fork bomb is, is a program that keeps opening copies of itself which open up copies of itself, and so on and so forth. Well a VERY basic fork bomb would be:
:Start marks a place in the script to which you may want to GOTO later or quicker then planned.
GOTO tells the program to go to a specific part
start basically "starts" something it can be a webpage, anything.
eg, start http://instructables.com''
This GOTO trap last forever until the user either breaks the process of the computer crashes.
The start fork.bat can be replaced with any command you like, for example;
@echo off:Startstart fork.batGOTO StartSave as fork.bat
@echo off:Startnet send * laconix rules!GOTO StartWhich basically send the text "laconix rules!" to anyone on your network with the Messenger Service running.
Step 4: Have Fun...
Hope your eager for the next tutorial, i know i am!
Go an hone you newly learnt skill and have phun!
