Batch Text Encrypter
10,373
26
8
Posted in TechnologyMicrosoft
Introduction: Batch Text Encrypter
The batch file I am going to show you can encrypt text and the second file can decrypt it.the batch file isn't mine but I thought it was very interesting and anyone reading this might like it. The original code can be found here
Step 1: Encrypt Text
Copy this code into notepad and save it as Encryt.bat or anything else with the .bat file extension
@echo off
setlocal ENABLEEXTENSIONS ENABLEDELAYEDEXPANSION
title Encrypt
color a
:mainmenu
set savefile=on
::set Encrypt=Nothing
(set CHAR[a]=UDFM45) & (set CHAR[b]=H21DGF) & (set CHAR[c]=FDH56D) & (set CHAR[d]=FGS546) & (set CHAR[e]=JUK4JH)
(set CHAR[f]=ERG54S) & (set CHAR[g]=T5H4FD) & (set CHAR[h]=RG641G) & (set CHAR[i]=RG4F4D) & (set CHAR[j]=RT56F6)
(set CHAR[k]=VCBC3B) & (set CHAR[l]=F8G9GF) & (set CHAR[m]=FD4CJS) & (set CHAR[n]=G423FG) & (set CHAR[o]=F45GC2)
(set CHAR[p]=TH5DF5) & (set CHAR[q]=CV4F6R) & (set CHAR[r]=XF64TS) & (set CHAR[s]=X78DGT) & (set CHAR[t]=TH74SJ)
(set CHAR[u]=BCX6DF) & (set CHAR[v]=FG65SD) & (set CHAR[w]=4KL45D) & (set CHAR[x]=GFH3F2) & (set CHAR[y]=GH56GF)
(set CHAR[z]=45T1FG) & (set CHAR[1]=D4G23D) & (set CHAR[2]=GB56FG) & (set CHAR[3]=SF45GF) & (set CHAR[4]=P4FF12)
(set CHAR[5]=F6DFG1) & (set CHAR[6]=56FG4G) & (set CHAR[7]=USGFDG) & (set CHAR[8]=FKHFDG) & (set CHAR[9]=IFGJH6)
(set CHAR[0]=87H8G7) & (set CHAR[@]=G25GHF) & (set CHAR[#]=45FGFH) & (set CHAR[$]=75FG45) & (set CHAR[*]=54GDH5)
(set CHAR[(]=45F465) & (set CHAR[.]=HG56FG) & (set CHAR[,]=DF56H4) & (set CHAR[-]=F5JHFH) & (set CHAR[ ]=SGF4HF)
(set CHAR[\]=45GH45) & (set CHAR[/]=56H45G)
echo Enter a string to encrypt:
set /p Encrypt=
cls
set Encrypt2=%Encrypt%
set "EncryptOut="
:encrypt2
set char=%Encrypt2:~0,1%
set Encrypt2=%Encrypt2:~1%
set EncryptOut=%EncryptOut%!CHAR[%char%]!
if not "%Encrypt2%"=="" goto encrypt2
echo Input string: %Encrypt%
echo.
echo Output string: %EncryptOut%
set string=%EncryptOut%
set temp_str=%string%
set str_len=0
:lengthloop
if defined temp_str (
set temp_str=%temp_str:~1%
set /A str_len += 1
goto lengthloop )
echo.
echo Output string is %str_len% characters long!
if "%savefile%"=="on" echo.%EncryptOut%>>%~d0%~p0encrypted.txt
echo.
start http://forum.imgburn.com/index.php?/topic/21566-batch-encryption-working/
pause
cls
goto mainmenu
Step 2: Decrypt Text
Save this batch file as Decrypt.bat or anything else with the .bat file extension
@echo off
title Decrypt
color a
:mainmenu
set savefile=on
::set Decrypt=Nothing
(set CHAR[UDFM45]=a) & (set CHAR[H21DGF]=b) & (set CHAR[FDH56D]=c) & (set CHAR[FGS546]=d) & (set CHAR[JUK4JH]=e)
(set CHAR[ERG54S]=f) & (set CHAR[T5H4FD]=g) & (set CHAR[RG641G]=h) & (set CHAR[RG4F4D]=i) & (set CHAR[RT56F6]=j)
(set CHAR[VCBC3B]=k) & (set CHAR[F8G9GF]=l) & (set CHAR[FD4CJS]=m) & (set CHAR[G423FG]=n) & (set CHAR[F45GC2]=o)
(set CHAR[TH5DF5]=p) & (set CHAR[CV4F6R]=q) & (set CHAR[XF64TS]=r) & (set CHAR[X78DGT]=s) & (set CHAR[TH74SJ]=t)
(set CHAR[BCX6DF]=u) & (set CHAR[FG65SD]=v) & (set CHAR[4KL45D]=w) & (set CHAR[GFH3F2]=x) & (set CHAR[GH56GF]=y)
(set CHAR[45T1FG]=z) & (set CHAR[D4G23D]=1) & (set CHAR[GB56FG]=2) & (set CHAR[SF45GF]=3) & (set CHAR[P4FF12]=4)
(set CHAR[F6DFG1]=5) & (set CHAR[56FG4G]=6) & (set CHAR[USGFDG]=7) & (set CHAR[FKHFDG]=8) & (set CHAR[IFGJH6]=9)
(set CHAR[87H8G7]=0) & (set CHAR[G25GHF]=@) & (set CHAR[45FGFH]=#) & (set CHAR[75FG45]=$) & (set CHAR[54GDH5]=*)
(set CHAR[45F465]=() & (set CHAR[HG56FG]=.) & (set CHAR[DF56H4]=,) & (set CHAR[F5JHFH]=-) & (set CHAR[SGF4HF]= )
(set CHAR[45GH45]=\) & (set CHAR[56H45G]=/)
echo Enter a string to decrypt:
set /p Decrypt=
cls
set Decrypt2=%Decrypt%
set "DecryptOut="
:decrypt2
set char=%Decrypt2:~0,6%
set Decrypt2=%Decrypt2:~6%
set DecryptOut=%DecryptOut%!CHAR[%char%]!
if not "%Decrypt2%"=="" goto decrypt2
echo Input string: %Decrypt%
echo.
echo Output string: %DecryptOut%
set string=%DecryptOut%
set str_len=0
:lengthloop
set /A str_len += 1
goto lengthloop )
echo.
if "%savefile%"=="on" echo.%DecryptOut%>>%~d0%~p0decrypted.txt
echo.
start https://www.instructables.com/member/batchcc
pause
cls
goto mainmenu
Step 3: Other Batch Codes
Thank you for viewing my instructable please see my others
ore batch codes here
And
A full screen matrix batch code here
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    8 Comments
    i tried a variation of @echo off
    title Decrypt
    color a
    :mainmenu
    set savefile=on
    (set CHAR[a]=B) & (set CHAR[b]=a) & (set CHAR[c]=c) & (set CHAR[d]=d) & (set CHAR[e]=R)
    (set CHAR[f]=f) & (set CHAR[g]=g) & (set CHAR[h]=h) & (set CHAR[i]=O) & (set CHAR[j]=j)
    (set CHAR[k]=k) & (set CHAR[l]=l) & (set CHAR[m]=m) & (set CHAR[n]=u) & (set CHAR[o]=W)
    (set CHAR[p]=p) & (set CHAR[q]=q) & (set CHAR[r]=e) & (set CHAR[s]=s) & (set CHAR[t]=t)
    (set CHAR[u]=N) & (set CHAR[v]=v) & (set CHAR[w]=i) & (set CHAR[x]=x) & (set CHAR[y]=E)
    (set CHAR[z]=z) & (set CHAR[1]=1) & (set CHAR[2]=2) & (set CHAR[3]=3) & (set CHAR[4]=4)
    (set CHAR[5]=5) & (set CHAR[6]=6) & (set CHAR[7]=7) & (set CHAR[8]=8) & (set CHAR[9]=9)
    (set CHAR[0]=0) & (set CHAR[@]=@) & (set CHAR[#]=#) & (set CHAR[$]=$) & (set CHAR[*]=*)
    (set CHAR[(]=() & (set CHAR[.]=.) & (set CHAR[,]=,) & (set CHAR[-]=-) & (set CHAR[ ]= )
    (set CHAR[\]=\) & (set CHAR[/]=/)
    set /p Decrypt=
    cls
    set "DecryptOut="
    :decrypt2
    echo.
    set str_len=0
    :lengthloop
    set /A str_len += 1
    goto lengthloop )
    echo.
    echo.
    pause
    cls
    goto mainmenu
    and i used the same key scheme in the encrypt one but this does not decrypt it although it encrypts it just fine the way i want it to any suggestions?
    This isnt secure "a" will always be UDFM45
    and "b" will always be H21DGF
    and "ab" will always be UDFM45H21DGF
    "ab" encypted will always be "a" encypted plus "b" encrypted
    P.S. this is a cipher not a encyption
    The only problem is that it doesn't know if a letter is using caps, so if you have a password with CAPS, when decrypting it will show up without CAPS
    Just wanted to state to Wolfbane221 that cipher is a form of encryption. So to say that is more of a cipher than encryption is like saying a shoe isn't a shoe because it has velcro straps.
    Hi, i have problems with running this some tips what should i do? I am running WIndows 7
    common things include did you copy to much ( the description) or did you miss a few lines.
    Another problem is saving it as .txt.bat instead of just .bat
    explain what the problem is
    Cool Batch file. more of a cipher than encryption though :)
