Problem: Two single user bathrooms - in a dorm style house - are shared by multiple people, but the bathroom doors are not visible from the main hallway. This results in many failed trips down the hallway, only to find the one containing all of your toiletries or both (depending on what the need may be) are already occupied.
Solution: A centrally located visual indicator to convey the use status of the bathrooms.
Remove these ads by
Signing UpStep 1Inputs - Detecting Door Status
Inductive proximity switches sense objects by generating a magnetic field. When a metal object reaches a certain distance from the sensors head, it will open or close a circuit (depending on the model). By placing a screw in the door, the sensor can be triggered when the door is closed.
I don't think I can execute the logic check easily with relays - though. It might take a PLC (Programmable Logic Controller) to handle it.
I love some Far Side - by the way :)
en.wikipedia.org/wiki/Flow_sensor
www.flowmeterdirectory.com/
and you could add a yellow light tied to a motion sensor to show when someone is in the bathroom, but left the door open. like if someone is brushing their teeth, or just using the mirror. then when someone needs to go really badly they can ask them to step out for a second.
http://www.youtube.com/watch?v=qTF9-j_y7zU
Also, what if someone leaves the bathroom and closes the door ? status will be inacurate. I think people are most likely to switch the light on and off (that you can detect with a light sensor) than leaving the door closed when gone when.
Otherwise, i find the system very nice and usefull :)
Interesting suggestion. Would the light switch be a better indication of occupancy? I think this would depend on the habits of the users in question, but I don't believe so - in the case of this location. It would be easier and cheaper to use the switch position in place of the proximity switches - though. Thanks for the idea of a diff rent input option.
Great idea but you need to dress it up more. You can get a low profile door sensor on ebay, and instead of using flex conduit, just run a 4 conductor speaker cable, they're low profile.
The people of this house were easily convinced to habitually leave the doors open upon exciting. The rooms are not in close enough in proximity to be easily effected by temporary unpleasant odors, and the central-air-vent-less hall depends on the thermal flow from the bathrooms to appropriately dictate the hall thermostat.
The appearance is as a design choice. I went heavy on the industrial look. This could be done with a cleaner, less visible appearance.
Thanks for the feedback.
I ran across images of LED versions - already in production - as I looked for the classic. Nice idea.
on another note, good instructable, i like this idea
After browsing the net briefly, I can defiantly say that it would reduce the sensor's costs, be allot easier to hide from site, and reduce the size and cost of the associated wiring. Thank you for the input.
