Bathroom Vanity Storage
Published
Introduction: Bathroom Vanity Storage
About: I am slowly coming to terms with the fact that nothing in old houses in New England will ever be square or level.
There always seems to be more stuff that belongs under the bathroom sink than there's ever room to put it in. Vanities don't have shelves under them because the drain and water supply lines are in the way. My solution works around them, and leaves the shut-offs and sink trap accessible.
Step 1: Tools and Materials
Required tools:
  1. Pencil
  2. Tape measure
  3. Needle-nose pliers
Optional tools:
  1. Drill with bits (only necessary if the inside walls of the vanity are melamine or other hard or slippery material)
  2. Combination (honestly, a plain level would work; in the absence of either you could just wing it)
  3. I didn't end up needing the screwdriver.
Materials:
  1. Screw-threaded hooks, 8
  2. Light chain, 4 times as long as the width of your vanity (cable or wire might work, but I couldn't get rope taut enough)
  3. Not shown: storage bins the correct depth to fit under the vanity
Step 2: Step 1: Measure and Mark
Basically, we're running pairs of chains across the inside of the vanity in order to establish planes on which storage bins can rest. Virtual shelves, if you will.
Tailor the measurements to your specific vanity. Start by holding a chain up across the width of the vanity. Move it up and down until you find a place where you could put another chain behind it to establish a plane. Measure that height, and draw horizontal lines on the right and left inside walls of the cabinet. This is where the combination square comes in handy, but as long as the lines are basically horizontal, you'll be fine.
To create a virtual shelf the full depth of the cabinet, drill pairs of holes at 1/3 and 2/3 of the depth of the vanity. Be careful not to drill all the way through the side. Drive the hooks deep into the holes on the left side, but only deep enough to catch properly on the right side. The needle-nose pliers help to crank the hooks in place. Again, don't screw them in so much that they puncture out through the sides of the vanity.
To create a toilet paper shelf, establish a plane just below the bottom of the basin. Drill one pair of holes an inch away from the back of the vanity. Drill the second pair of holes 3 inches from the back. The standard 4" American loo roll will perch neatly there.
Step 3: Step 2: String the Chain
Using the needle-nose pliers, cut the chain to about an inch less than the interior width of the vanity. Hook the left end of the first chain over the left rear hook, then string it across to the right rear hook. Screw the right rear hook in until the chain is taut. Repeat with the other chains, moving back to front, and right to left. Finally, make sure that all of the hooks are lying horizontally, so that they don't catch on whatever you rest on the chains.
The toilet paper gets tucked up into the awkwardly-shaped space beside the basin, up inside the top of the vanity. Be sure not to obstruct the works of the sink stopper.
Step 4: Step 3: Pack It In, Get It Out
Congratulations! You now have three layers of storage where there was only one before. Storage bins allow you to pull items out as needed, and let you empty the whole thing out quickly (for instance, if you need to close the shut-off valves NOW). If you need to do serious work under the sink, unscrewing the hooks is the work of a moment.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    5 Comments
    Wow! Those rods really made an unbelievable difference inside the storage cupboard under the sink! I thought that there was nothing that could be done about that weird space!
    Plastic tubs are perfect for the area underneath the sink so as to keep any moisture out should there be leakages from the sink above it. Furthermore, the lids can help to conceal in the mess so the area will not be an eyesore to face on a daily basis.
    You could also use TENSION RODS for this--but a great idea either way---and you could place flat boards on the rods or chains for non-container items---Hmmmm!!!!
    To prevent tension rods from slipping use either a CLOSET ROD END "kit" or for smaller diameter ones use two soda or any other lid attached to your sides; cut a slot on one side if needed to slide the rod in on one of the tops. Screw or epoxy onto your wall.
    This is great and also a solution for my awkward cupboard above the stove with exhaust pipe up the middle!
    Your cabinet looks eerily similar to mine, it's like we share the same one, except you don't have enough t.p. Women always want to be prepared for a Zombie Apocalypse by stocking up on t.p., even forsaking food storage for more t.p. room. At least that is how it seems with my wife. Anyhow, this is a great idea, thanks for sharing and by the way, Winn- Dixie is having a BOGO on t.p. this week- don't ask me how I know.
