Batman Cowl From Craft Foam
8,805
53
12
Published
Introduction: Batman Cowl From Craft Foam
About: Science Teacher. Maker. True-Believer.
Who doesn't want to be the Dark Knight for Halloween?! This craft foam project is an easy way to create a flexible and wearable cowl for next to nothing.
You can either download the files, print, trace and cut your own cardboard or visit my Esty shop and purchase the kit and I'll cut the pieces for you! Note:
Materials needed:
  • PDF file or Craft Foam kit from Etsy
  • Two 18" x 24" craft foam sheets (if using the files linked above)
  • hot glue
  • Scissors or a xacto knife
Finishing materials
  • Black roofing silicone
  • Black Plasti-Dip spray
Step 1: Begin Gluing the Pieces of the Head
Work slowly, glue, cool, glue cool. Press the prongs of the head pieces togther and glue along the back (inside) of the cowl.
By glueing from the base of the prongs and working towards the ends, gluing an inch or two at a time, you will avoid seeping hot glue though to the top. Craft foam is not very forgiving if you need to re-heat and remove glue.
If you're unsure about how a part fits together, trace and cut a practice part first and assemble with tape so that you understand exactly how the part bends and fits together.
Step 2: Attach the Front and Back of the Head
Once you have glued the front and back prongs, attach these two pieces to form the primary shape of the dome/ top of the head.
Be sure to line the parts up precisely as you hold them together while they cool.
Step 3: Attach the Sides and Chin
Find the seams that match the sides with the top of the head. Look closely at the image and the parts themselves, as the pieces should fit pretty exactly here. Glue one side to the helmet and then work around to the other. In the first image you can see that I originally experimented with separate side/ chin, but later decided to create one continuous piece. Much easier to glue.
Close up the slits between the chin and sides creating a little undercut curve as you do. Attach the missing chin piece and glue it from behind/ inside. Make sure you use the one that fits exactly. There is a similarly shaped piece (but longer and pointy on the ends) that is used for the neck, so don't glue the wrong part.
I noticed a bit of natural curl in the laser cut parts, so I sorted the sides of the cowl so that they curve inward. If this does not occur naturally, curl the foam around a baseball bat or broomstick for a few minutes to help with the shape.
You can also use heat with craft foam and it will retain any shape you mold it into as it cools. You shouldn't need to do that here, though, and use heat sparingly.
Step 4: Build the Ears
Glue the three triangular pieces into a pyramid as shown in the first image (a bit blurry, but you can see what's going on here)
Then attach the ears to the head, again gluing inside the helmet. I left a few gaps when I assembled this one, and I plan to fill them with black silicone just before painting in the finishing stage. This allows a little less time spent precision gluing and a faster overall build.
Step 5: Glue the Neck and Lower Cowl
Glue the three triangular pieces of the neck. I overlapped these pieces just slightly to give a bit of dimension to the cowl, but I'll lose some length in the neck/ fit. Again, trace and tape up paper or cardboard templates if you want to see how these will fit together before ruining your nicely cut craft foam.
Glue the prongs of the lower cowl as seen in the pictures. (Notice that I've included top and bottom photos for many of these so that you can see what the finished seams should look like if you keep all of the glue on the inside.
Fold the cowl as shown in the final image around the trapezius muscles so that it os shaped and ready to fit up with the head.
Step 6: Glue the Eyes and Nose
Ok, last part, and by far the most difficult. But after this, you're done!
Remember the techniques you've practiced so far: Go slow, glue inside, trace and tape templates to practice, and look closely at the pictures.
The nose goes together pretty clearly. Don't fold and glue it at a 90 degree angle, rather create a bit wider, obtuse angle.
Create a similar angle when gluing the outer edge of the eye sockets together. The inside of the eyes (closest to the nose) are meant to be scrunched up a bit and create a furrowed, mysterious, abandonment issues expression.
Pinch the slits in the brow to really drive home this look and glue it to the top of the eye sockets. I worked from right to left as I like to start with the obviously matching sides/ angles, but next time I might try starting in the middle as this was the most difficult to get right.
Step 7: Glue the Eyes Into the Cowl and You're Done!
Sweet! Try it on, and tell someone "I'M BATMAN!"
To finish the cowl, I plan to add a bit of black silicone into the seams and then spray the cowl with black plasti-dip. However, this MUST be done at the same time. If you wait for the silicone to dry, nothing will stick to it, so you must spray paint immediately while the silicone is still drying.
If you purchased one of my Etsy kits, i'd love to get your feedback on the kit, part design and this instructable. I'm constantly revising, so let me know what you think.
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
    12 Comments
    Hi, I was wondering what size your head is. Cause Idk if the templates will fit me. Also could I use 12x18 foam sheets? PLEASE REPLY!!!!
    I'm a pretty average human head size.
    I'm sure you could use your foam sheets, but you might need to edit the file to re-layout the parts.
    (GIMP is free! https://www.gimp.org/downloads/)
    Do you use 3mm foam or 5mm?
    3mm. But I would like to try slightly thicker craft foam.
    Ok, thanks.
    OK, now how do I make the templates bigger sized? Cause they're not coming out in the size they should be.
    Thanks! Craft foam is much less forgiving of hot glue, so the seams really have to be glued slowly and carefully. I'm hoping to clean it up with some silicone and black plasti-dip spray.
    I know what you mean, although it is a bit harder to work with, it yields awesome results. This is a mandalorian gauntlet that I finished with craft foam, also if you use a heat gun on the foam it slightly melts the top and gives it a great look.
    P.S. Yes that is my part way finished stormtrooper helmet in the background.
    Looks great! I like the layered look with foam too. By varying thicknesses and dimensions, and layering foam pieces, you can get really interesting looking armor. I want to try it with Batman gauntlets sometime soon.
    What do you finish with? I've used plasti-dip and lots of paint, but after one Halloween night out it's pretty beat up and cracked.
    I love all the helmets in the background too! Looks like my desk! My girlfriend, on the other hand, is not so in love. I'm probably about two or three helmets away from not having a girlfriend anymore...
    I just used spray paint for a silver base coat, then acrylic paint over it.
    Lol, just include your girlfriend on your helmet builds and maybe she will warm up to them.
