Batman Keyholder
737
48
Posted
Introduction: Batman Keyholder
My daughter is a huge Batman fan. This easy-to-make project was the perfect addition to hold her car keys.
Step 1: Materials
The materials list is very straightforward:
• sheet wood
• glue
• paint
• hooks
Finding an vector version of your image may be difficult. However you can convert most line art graphics to a vector format using potrace. I used this Instructable for the walk-through. This is an important step to consider since vector graphics can be resized without losing detail or introducing artifacts (ie: fuzziness on and around the image).
Step 2: Cutting, Gluing and Painting
I used the laser machine at my local Maker Space to cut out the images. I used a thin 1/4" sheet of plywood as it was the easiest material to cut. Thicker pieces of plywood can be cut with the laser but I find that the plywood will have too many irregularities and produce poor results.
To make the project thicker, three copies were made and then glued together. The end result was ~3/4" thick.
And then a couple of coats of spray paint to finish off the project.
Step 3: Drill and Add Hooks
I drilled the holes for the hooks to prevent any wood splitting. Since this logo is usually black and yellow, I made sure to use gold coloured hooks. It was the perfect accent!
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
