Batman Wood & Resin Emblem
5,240
231
14
Posted in WorkshopWoodworking
Introduction: Batman Wood & Resin Emblem
About: We love to create and we love trying new things. As we learn and grow we want to share our experiences with you and hopefully inspire you in some small way.
I have a bare section of wall behind my computer desk that just needed something. Growing up a comic book fan, I thought it would be a pretty cool idea to fill this particular wall with some superhero emblems. I had already made a Superman shield, so this time I thought it would be appropriate to make a Batman emblem. In fact, my plan is to fill the entirety of this blank space with Justice League emblems first and then possibly expand it to more DC characters as well. I guess we'll see where this all ends up. Anyhow, here is how we made the Batman Emblem. You can watch the video or check out the step-by-step.
Materials You'll Need
  • Wood of your choice (we used walnut)
  • Epoxy Resin (any will work, we used Famowood Glaze Coat)
  • Acrylic Paint (we used blue)
  • Petroleum Jelly or Mold Release
  • Finish (we used wipe-on polyurethane)
  • 3M Poster Tabs
Tools Used
  • Scroll Saw
  • Band Saw
  • Drill
  • Chisel
  • Hot Glue Gun
  • Disc Sander
  • Random Orbital Sander
Step 1: Prepare the Template
The template started out with an actual version of the Batman logo. I traced over it in Inkscape using the bezier tool and then exported the line drawing to paint.net to better size it for what I wanted. I chose to make each of our emblems about 8" wide and roughly the same height, depending on the emblem.
I cut out the template and glued it to the piece of wood using a spray on glue that has a temporary-like hold. You could use a glue stick as well.
The wood we used for this particular emblem was walnut. The wood was a little shy of 3/4" thick.
A few tabs were hand-drawn onto the template to give it some stability.
Step 2: Cutting the Emblem
Before I started cutting the interior of the emblem I drilled a few holes in the blank spaces to allow for the insertion of the scroll saw blade. Then, I cut out the interior, making sure that I left the tabs in place that I had hand-drawn in previously. If you are not sure how to use a scroll saw, there are a bunch of videos on YouTube that can help you out. If you don't have a scroll saw, you could also use a coping saw.
The outside of the emblem was cut out on the bandsaw.
Each of the tabs that I had left in place were chiseled down to roughly half the thickness of the wood. These will be covered up in another step.
Step 3: Prepping the Emblem for Resin
There are a ton of different ways you can do this. Some work better than others and some make life more difficult. Unfortunately, we chose the more difficult route this time around.
Basically, we just laid the emblem on a piece of hardboard and then glued around the perimeter, attempting to create a sealed barrier. We also added in some petroleum jelly as a mold release agent. As you'll see in the next step, both ideas had their flaws this time around.
We've had great success in the past using both of these methods, but for some reason it didn't work out so well this time. This might work differently for you, however. You could also use wax paper as a backer instead of petroleum jelly or you could break down and just buy some mold release. You could also clamp the emblem to the backer board instead of hot gluing the barrier.
Step 4: Mixing and Pouring the Resin
The resin we often use is called Famowood Glaze Coat. It's not commonly used for this sort of thing, but we have fallen in love with it as of late. Mostly we've fallen in love with the price. It is actually a bar top / table epoxy, but it works great as a casting / pouring resin as well. It is a two-part resin that is mixed in a 1:1 ratio. We added a bit of blue acrylic paint to the resin to give it the color we wanted. Here's some more info on mixing the Famowood since it's a bit different than some epoxy resins. Mixing Famowood
Pouring is pretty easy to grasp. Just pour it slowly and make sure the tabs are fully covered. You may also need to pop some surface bubbles using a lighter. Just hover the flame close to the resin, but don't touch it and the bubbles should pop.
Once you're satisfied with how the resin looks, you'll want to let it set and cure for 12-24 hours before you release it.
Step 5: Releasing and Finishing
If you should have some trouble releasing the emblem from the backer board and/or some of it sticks to the back because of seepage; don't worry. Just tear away what you can and sand off what's left. If you used MDF or hardboard as the backer board sanding shouldn't be an issue. That stuff sands down fairly quick with some 60-80 grit sand paper.
If you didn't have any trouble releasing it, then all you need to do is clean it up a bit. Some of the resin may have seeped a bit. You can removed that with a scraper or craft knife or you could even sand it.
You can add a finish if you like. We did, just to make the wood a bit darker and give it a bit of a shine. We used a wipe-on polyurethane.
Step 6: Hanging and Enjoying
The best way we have found to hang something like this on the wall, was to use the removable 3M poster tabs. These emblems aren't very heavy and they seem to work really well. We use three of them per emblem.
If you have the right tools, this project doesn't take much time at all. Plus it's a great addition to any Batman or comic book fan's collection.
We hope you enjoyed this DIY project and the video that goes along with it.
If you have any questions or comments please let us know, we'd be more than happy to help you out.
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
  • Space Challenge
    Space Challenge
14 Comments
Está genial esos emblemas.
Una pregunta. Para Que utilizas el fuego ??.
Sí. Una antorcha para hacer estallar las burbujas.
I'm going to try and make both the Batman and Superman logos. As far as trying to prevent resin leak, I'm going to try adhesive backed vinyl sheet which is very cheap and comes on a roll. Hopefully this will either peel off or maybe I can leave it on after trimming it. Fingers crossed. Thanks for the idea and taking time to upload the video.
Cool. I really want to see it when you get it done. Please make sure you share it with us. btw, We use contact paper on other projects, which sounds similar. Maybe we'll try that on the next one. Thanks for the idea.
I used the adhesive vinyl sheet and worked great. The Batman Emblem didn't work so good but that was down to my fret saw skills. The Superman came out better though. I used English Cherry wood. I think it needs a couple more coats of wipe on varnish on the wood areas. Maybe if I do this one again I might used water soluble die to colour the timber red but still allow the grain to show through.
Awesome. It turned out great. I'm with you on the darker cherry. I'm actually getting ready to start the Wonder Woman logo this evening and am toying with the idea of adding a bit of stain to make it a little darker (a bit more red), but not sure. I think I'll try your adhesive backing too. Seems like it worked well for you.
Nice work, Inkscape has a very powerful tool for create a vector form plain images (jpg,png,bmp,gif,etc) just copy and paste the template then click path on the top menu and click on Image to Phat or something similar :). Is a very powerful tool and you'll get accurate results. The batman logo is easy to draw but there's other logos way more complex and this option will save you a lot of drawing time.
Thanks. I didn't know that. Thanks for mentioning that tool. I appreciate it.
Thanks. Glad you liked it. I know my kids love the one we have.
