Cheap and Easy Battery Holder Version 1
 by xtank5
Battery holders of course hold batteries and are VERY useful in electronic projects especially those that require batteries. This is the simplest battery holder I could come up with. The best thing is that it is cheap and it uses household items that everybody should have. If you want to make a holder for a larger battery then adjust the dimensions accordingly.
Keep in mind that this is my first instructable, so please be gentle. And please hit the little + thingie up there.
Step 1: Materials and Tools
For this holder you need tape of some kind. I used electrical tape because its awesome and it is maybe a better insulator than cellophane but if you don't have electrical tape then use cellophane, its better than duct tape in this case. You also need cardboard preferably from a cereal box because it is sturdy and thin. You also need aluminum foil because it is conductive and easily shaped.
You need a pen to mark the measured points on your cardboard and aluminum foil. A ruler is needed to accurately make the holders otherwise you're going to have one wonky battery holder. You need an exacto knife or scissors. An exacto is more exact ;) but scissors work wonders cutting the tape straight. The golf tee is for scoring the aluminum it isn't neccesary.
babble112 says: Apr 6, 2011. 4:27 PM
THANK YOU SO MUCH....this really helped for my science project
sk8erdude says: Jun 28, 2008. 2:33 PM
dude this is awesome! i got the exact same idea but u beat me to posting. this is a great money saver. those ones at the source are like 5 bucks -sk8erdude
DYLEGO in reply to sk8erdudeNov 2, 2008. 10:37 AM
a 2 AAA battery holder at radioshack is only 99cents
sjs229 in reply to DYLEGOFeb 10, 2009. 2:32 AM
It costs only Rs10(about 0.2$) in India lol
DYLEGO in reply to sjs229Feb 10, 2009. 7:05 PM
And they are much nicer, too!
sjs229 in reply to DYLEGOFeb 11, 2009. 12:36 AM
Ya
looking4ideas says: Jun 14, 2008. 1:15 AM
You saved me about 30 ytl(Turkish lira) THANK YOU
Trainman 2001 in reply to looking4ideasNov 4, 2008. 2:21 PM
u turkish me too
tubbychick3n says: Aug 21, 2008. 5:18 AM
i've always wanted to know how to do this myself! i know how you could wire one up to hold multiple batteries.
cowscankill says: Jun 13, 2008. 4:34 PM
wow. need this :)
ledzep567 says: Nov 30, 2007. 2:45 PM
just a few questions. this is for one battery right? if you were to make it for 2 you would just add another tick mark? the leads connect to the two tinfoil covered tabs? and the leads are the two wires that are normaly sideby side in a powercord? and you can connect the leads with just tape or something? also, do you have any ideas for a on/off switch?. thanks. by the way, great instructable ben
xtank5 (author) in reply to ledzep567Nov 30, 2007. 7:16 PM
Yes it is for one AAA battery but you could change the dimensions for a AA. No because I reccomend you use each holder for one battery each. Yes the leads do connect to the tinfoil tabs. Yes the leads are the two wires side by side in the powercord (if it's ungrounded). And yes you can connect the leads with just tape but it won't be as good as with alligater clips (reccomended) Yes I do have some ideas for an on/off switch that I might post later. Your welcome. And thank you for reading.
ledzep567 in reply to xtank5Dec 1, 2007. 11:52 AM
why do you recommend using only one battery per holder?
xtank5 (author) in reply to ledzep567Dec 1, 2007. 3:47 PM
If you put more that one battery in each holder the likelyhood of the battteries popping out of the holder is greatly increased.
ledzep567 in reply to xtank5Nov 30, 2007. 8:09 PM
thank you so much (I know I may sound like a complete moron but I have had no instruction in this feild other then electricity hurts lol)
psyci says: Oct 29, 2007. 7:02 AM
Usually when people say "this is my first instructable", it implies they rushed it and did a poor job on it. This one is very good, and useful, too! You should be proud of it!
xtank5 (author) in reply to psyciOct 30, 2007. 5:00 PM
I most certainly am proud of it and I thought other people put "first Instructable" because they were proud too (and wanted other people to be gentle with their comments as well).
xtank5 (author) says: Oct 30, 2007. 4:58 PM
Thank you for your nice comments. I appreciate them very much. If you have any constructive critisism though it is most certainly welcome.
pattern86 says: Oct 28, 2007. 10:46 PM
good instructable--i understand completely except what it's for. it just holds a battery?
sleeping_gecko in reply to pattern86Oct 29, 2007. 7:10 AM
These are used to hold batteries for electronics projects. If you take any battery-powered device (a remote control for a TV, for instance), and disassemble it, you'll find some sort of battery holder. If you're building some project that requires a battery, you could either buy a battery holder, or make one similar to this. It's just a handy way to keep the battery in place and in contact with the leads. Hope this helps explain it!
pattern86 in reply to sleeping_geckoOct 29, 2007. 7:37 AM
oh, ok! =) thanks! i get it now!
T3h_Muffinator says: Oct 28, 2007. 11:36 PM
Awesome idea! I shall implement this for all of my future uC projects, that is if I don't have a battery holder on hand....
PoisonedV says: Oct 28, 2007. 11:33 PM
This is good- I needed a containment device so I didn't have to tape my battery to the pcb xD
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
