Battery Pack for 18V Ryobi Tools by MN218
This is a quick and easy way to make a battery pack that will allow you to use a Ryobi 18V tool for four times as long as with one battery. Sometimes a tool will die in the middle of an operation, this can mess up what you're trying to do and is dangerous in some cases. Speaking of dangerous! I get the impression that my little project is dangerous, so watch your back and don't get hurt, I believe in you.
Step 1: Layout
First of all, find a board that you like. It needs to be wide enough that it is at least an inch taller than your battery when stood up on its side. It needs to be as long as all four batteries lined up like in the picture. This is the space saving method of placing the batteries.
urbanprimate says: Feb 9, 2010. 4:50 PM
That's brilliant....in a kinda caveman, "does it actually work" kinda way.
So....how well does this actually work?  It's definitely inspirational.  I love my Ryobi one+ (I have the caulk gun, circular saw, reciprocating saw, and 2 drills...don't ask.), but the black/yellow batteries themselves are horrible.  They did fine when I was just running screws here and there, but then I got involved in building a deck, which involves cutting a lot of lumber.  The tools will do the job, but I suddenly find myself constantly switching batteries.  I picked up two of the low-profile battery upgrades, which are much stronger but run out just as quick under heavy loads.  Does running them in parallel give you the results it seems like it should?  The batteries would suddenly be worth having again if a four-pack got me four times the life!  I run a mobile shop out of a van, and a lot of my money goes into battery tech.
The "good" batteries cost $90/ea at Home Depot!
MN218 (author) says: Feb 12, 2010. 5:36 AM
Works pretty much how youd expect.  I wouldnt sayit gives exactly four times the life, but at least you spend less time in limbo, trying to decide whether or not it is indeed time to swap batteries.
snowluck2345 says: Apr 24, 2011. 7:28 PM
I'd say it would give your more than 4 times the life, considering this causes a lower draw on the batteries which usualy gives them a higher A*H
daggerofblood1243 says: Aug 2, 2011. 12:55 AM
Dude thats so awesome.
kricketone says: Jan 23, 2011. 6:41 PM
this is a joke right? kinda defeats the cordless thing..................
aedman says: Feb 15, 2010. 5:20 PM
Never saw this beast before. It seems like a classic though.
Mr. Rig It says: May 4, 2008. 9:28 PM
I LOVE my Ryobi 18volt one Plus tools. They are the best cordless tools on the market for the Non-Professional tool user. I have the leaf blower and weed eater and they. The leaf blower is kinda of weak compared to corded ones but it works fine for what I need it for. The weed eater works fantastic better than my corded Black and Decker. This ible would work well for the leaf blower, it sucks the battery pretty quick, the weed eater does pretty well, though it may benifit from this as well. I am sure the chainsaw sucks the battery down very quickly also so this may work wel for it as well. Ryobi now makes battery that last twice asd long as the preivous ones. When it comes to angle ginders I still use my craftsman corded, but there are times when I could use a cordless one. I would just hate to have to carry that box around. Perhaps you could make your cord longer so you could se it down to use it. Neat idea.
theRIAA says: May 4, 2008. 8:04 PM
im pretty sure those ryobi "one"s are crap. the batteries only cost like $30 get a cheap corded angle grinder for less than the cost on one of those batteries, or run that thing off 2 car batteries with a longer cord for serious power
LinuxH4x0r says: May 4, 2008. 4:30 PM
Or just use corded tools. Sheesh! Whats with cordless. I hate my cordless drill. Good job though!
MN218 (author) says: May 4, 2008. 5:27 PM
Corded tools are definitely always better for power, but when you're working in off the grid locations you've gotta choose between human powered and DC, and for now DC is my pick. What sort of drill do you have? I think anything under 18V for a cordless tool is just a lot of frustration.
LinuxH4x0r says: May 4, 2008. 5:38 PM
Or get a generator or inverter. I have a cheap 18v drill (it was $10 at menards).
Hands Without Shadows says: May 4, 2008. 3:29 PM
..........or you could plug in a different battery when the one your using runs out.
MN218 (author) says: May 4, 2008. 3:52 PM
Absolutely! That's what I do usually, but the angle grinder drains batteries incredibly fast, which is dangerous when you're using the abrasive cut-off wheel, because if it's not able to chew through the steel you're cutting it kicks back towards you instead, maybe I should put a picture of my papa's destroyed hand on here to illustrate the concept. This is also better than changing batteries out because the amount of peak performance time is increased significantly.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
