3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Battery Powered Emergency USB Charger
In this, my first ever, Instructable, I will show you how to make a USB charger powered by 4 AA batteries. This is similar to the USB Solar Charger Instructables, except it runs off batteries. It costs about 25 dollars for the parts and that is a lot less than brand name chargers. Please don't over criticize my Instructable, as it is my first one.
Step 1Purchasing and Collecting Parts
For this Instructable, I used the following materials, all purchased at RadioShack.
1. ABS Plastic Project Enclosure (6x4x2 inches) ($4.99)
2. Red and Black 18 Gauge hookup wire ($6.99) Product # 278-1226
3. 4 AA Battery holder with snap connectors ($1.79) Product # 270-383
4. 9 Volt heavy duty snap connectors ($2.69) Product # 270-324
5. DPDT Toggle Switch ($2.99) Product # 275-666
6. 5 Volt Regulator ($1.59) Product # 276-1770
7. TO-220/TO-202 Aluminum Heat Sink ($1.99) Product # 276-1368
8. Green LED Power Indicator ($1.99) Product # 276-271
9. A screw to hold the 5 Volt Regulator to the Heatsink (can be found anywhere, just find one that fits.)
10. A cable with a connector compatible with your device.
Tools Needed:
1. Phillips screwdriver
2. Drill and bits to drill switch and LED holes, and wire hole
3. Soldering iron and solder
4. Wire cutter and stripper
5. Pliers
6. Digital Multimeter
Lets get building!
6 comments
May 27, 2011. 9:45 AMtaoybb-TH says:
WOAH!! There's a lot of loss!
Apr 16, 2011. 11:58 PMbadboy4a2 says:
Thats so cool.But what will be the amp rating if we use the AA batteries?i want to connect my phone directly to it.So when there is excess current,it may damage the phone.Can you tell how to control it?
Jun 6, 2010. 2:18 PMTubehacker01 says:
You dida pretty nice job soldering!! :D
Jul 18, 2009. 2:14 PMle-Sid says:
Really nice one... I did one myself looking like yours, except that I use a single 9v battery or a cigarette lighter adaptor for car. It becomes kind of hot thought... Used a female usb connection for output. I can charge many things from there _
Jul 19, 2009. 9:57 AMle-Sid says:
kind of... the backplate of the enclosure is metallic. I screwed the regulator plate-to-plate with thermal paste. Didn't really take measurement of the temperature, but I think it'll get about 30-40 degrees when charging my cellphone. Other devices seems to make the regulator colder. On other hand, you're right about the 9v batteries, it works but I don't get much charge time... should modify it someday
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jbyrns1993
