3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Off-Grid Party Sound Systems
Whether its for a mobile bike party or a solar powered concert, a 12V or 24V sound system is the key.  I recently built several systems for mobile bike parties and this article has a pile of details.  You can also check my Easy Bike Party Sound System project if you want a simpler and smaller system and my Bike Party Sound Trailer for specific tips on a trailer design.  If you want to just purchase finished speakers built according to the principles of this guide, we sell them at MonkeyLectric.
This article covers:
  • A simple but efficient setup where you just pick the right parts and plug it together
  • A true Active 12V speaker - an ultra-efficient speaker with integrated 12V or 24V internal amp.
  • Choosing efficient speakers and amps
  • Choosing a battery
  • Weatherproofing and vibration proofing
The goal of this project is to achieve sound levels needed for off-grid dance parties while reducing weight and power use.  Compared to common setups, we achieved power reduction of 50-80% and weight reduction of 20-40% with equivalent sound output.
My friend Deep runs Flashdance, and we used his system as a reference point to compare our work against.  Deep has an amazing tricycle setup that lets him bring the party wherever he goes.  San Francisco has rather notorious hills though, so our goal was to see if we could cut the weight of his setup without sacrificing any of the sound.  A big key to cutting the weight is to see if we can use something much smaller than a car battery - and that means being more efficient about power use.
This project is brought to you by MonkeyLectric and the Monkey Light bike light
Step 1A word about Efficiency
The key to any battery-powered sound system is efficiency.  Home and car sound gear is not designed to be efficient or light - it just isn't a concern in those applications.  Low efficiency means you need lots of power to make the same amount of sound, and lots of power means a big heavy amp, a big heavy car battery, and maybe a big heavy inverter too.  An efficient speaker can produce 5x the volume from the same amount of power.  An efficient amplifier is 2x better than a standard one, plus its far smaller and lighter.  Together this means that with a bit of attention paid to your component choices, you'll get way more output for the same amount of power.
Lets take a look at Deep's current system.  He's got:
  • 2 nice Yamaha powered speakers (they have a built-in amplifier)
  • An inverter because the Yamaha's need 120V
  • A car battery
Another option I see some people using goes like this:
  • 2 big auto-sound speakers
  • a big auto amplifier
  • a car battery
Either way there is a lot of inefficiency.  Using 120V powered speakers, the amp inside the speakers is moderately efficient (not the best, not the worst).  we lose a good chunk of efficiency because of the inverter.
With auto-sound gear, you don't need an inverter but the problem is that it all the parts have very poor efficiency.  I think this is due to marketing forces at work - the folks selling you this stuff learned that if the amp and speakers are bigger and have higher watt ratings, they make more money selling them.  but, those high watt ratings are only needed because the gear is so inefficient.
74 comments
1-40 of 74next »
Apr 29, 2012. 2:28 PMsweber1 says:
Thumbs up to Dan and a little update from denmark.
Last summer me and my friends stumbled across this tutorial - and i just wanted to share our result with all of you, and Dan. This project was completed in a couple of months, we are now building a high efficient woofer to go with the system.
We went with a couple of behringer b212xl speakers - they were available used for a cheap price and have a fairly high efficiency . Installed the monkey electronics filter and a sure electronics 2x150w amp in each speaker as covered in this tutorial.
The DJ case consist of a welded steel frame as we wanted to fill this baby with acid-fluid power (read: car batteries). It can contain 7 batteries, delivering about 400Ah at 12v. We've installed a 17" inch tft monitor, which ran native 12v input through an expensive dc-dc converter to output precise 12v as the monitor needed. A computer on 12v from fitpc (in retrospective it's too slow for DJ apps - but great for winamp.. Actually an ipod would have been sufficient). We also found a nice 3 channel 12v mixer to put in.
The system can run approx 10 hours on 3 car batteries on 80% volume.
Iv'e learned that noise in this ungrounded system can be a bitch. The dc-dc converter made so much noise along with the tft that we needed to put it on seperate batteries to reduce the noise transmission from them. Also using a trafo between speaker and mixer helped a lot. And of course shielded cables.
We held a nice party for around 150 people as you can see in the images.
cheers
Apr 11, 2012. 7:57 AMdofnicom says:
Could you take this concept and create a rechargeable wireless speaker by mounting a battery in the speaker and adding a UHF Wireless Mic Receiver to the equation like a Nady DKW-8U. I am a DJ and sometimes I need remote fill speakers in weird places. A self contained powered wireless speaker would be nice. 8" or 10" with the 100Watt amp and wireless receiver. The receiver is DC14V 0.4A.
Apr 1, 2012. 11:24 PMfatdumpa says:
great article. very comprehensive. iv had this hi-fi speaker lying around for ages, using it to put drinks on. so i think il have a stab a powered mono speaker, maybe with one of these cheepies, (any good?)
http://www.ebay.com.au/itm/230608706091?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_3755wt_907
and one of those
http://store.monkeylectric.com/ProductDetails.asp?ProductCode=XOVER1
both mounted in the box, and a 12 volt battery yet to be acquired.
any of you experts know what kind of volumes i can expect from this kind of set up?
the speaker isn't massive i know, but it's a convenient size, and i can always swap it out for a bigger one.
Mar 9, 2012. 9:49 AMjeisenkramer says:
What do you think...a car battery with an inverter, a powered PA speaker with the two amps pushing out 200w total and two guitar amps - a 30 watt and a 60 watt. How long would this last us? This will be on the back of a pickup truck.
Any feedback would be huge.
Jan 4, 2012. 12:14 AMivica12 says:
Hi!
I am new to this so I have a couple of questions. Would it be a problem to connect 4 ohm speakers? I'm looking at these specifically http://www.thomann.de/gb/peavey_pro12_messengerserie.htm
Also, these seem cheap and have a big SPL, however the brand is unknown (and obviously being much cheaper than others I am a bit worried about the quality) http://www.thomann.de/at/the_box_pa15eco_mkii.htm
Thanks for the help!!
Jan 29, 2012. 1:40 PMn0ukf says:
Most amps have a range of acceptable impedance they can drive (like 4-16, read your amp's specs). If your amp only goes down to 8 ohms output and you can use two speakers per channel, you connect the two 4 ohm speakers in series. If 4ohms is the maximum output impedance and you have two 8 ohm speakers, connect them in parallel.
Jun 5, 2011. 8:03 PMimBobertRobert says:
lol i thought that it was a wheel chair connected to a bike with speakers on it. IDEA! the sound-chair!
Dec 21, 2011. 5:32 AMmacwhiz says:
Thanks for the idea! Time to go wheelchair hunting! Maybe electric?
Dec 19, 2011. 3:26 PMdfuller11 says:
I have obtained 2 SLA batteries (from computer back-up systems). They are marked "Cycle Use" 14.5-14.9V ("Standby use" 13.6-13.8V).
They are hardwired w/ a nylon plug with three terminals (marked "+"," -", and "S" (ground?)).
Anyhow, I have been unable to get them to take a charge from the 12V charger I have. Perhaps I need a more powerful charger? How should I treat the "S" terminal? (see photos).
Many thanks.
Nov 17, 2011. 11:49 AMElorrum says:
Lepai makes a small 2.1 amp, probably ta2020? that I used with 8AA batteries, 2" 4ohm speakers mounted in PVC 3" pipes, a DVC subwoofer built into a plastic bucket lined with batting. great near field, and loud enough for shouts from 50 yrds to "turn it up" but not loud enough to do so. Working with a sure 100W 24v amp with line arrays in composite fence posts as next project.
Sep 28, 2011. 4:05 PMslaterbsb says:
Hello!
This is amazing!
I'm currently pricing a system, and had a couple questions:
If I have a pair of B212XL or B215XL should I have a single DTA-100a or will I need one for each speaker?
Sep 10, 2011. 4:56 PMchriscab says:
With this setup of 24V, TK2050, and a mixer/preamp, what should be the current rating of the switch and fuse?
Sep 3, 2011. 6:44 PMchriscab says:
Thanks for the great instructions, Dan! Last night I debuted my setup with a TA2020, 12v/8Ah SLA & Gemini RS-308, created from your wonderful instructables, at the SF Bike Party and it was definitely a success. Got some great comments from people who were impressed with the sound coming from such a compact package. No trailer or car batteries for me, everything was mounted on my rear rack. I'll post pics later. Now with this portable powerhouse, tailgating and bbq picnics will be even more of a party!
So of course, I've now gotten the bug on wanting to get louder and cleaner. I'd like to upgrade to the TK2050 with the monoXover and another SLA. My question is: To get full power from the amp with 24V, I'd still need a pre-amp to boost the signal going to the amp, correct? And if so, should it go between the source/MP3 player & x-over, or x-over & amp?
Aug 2, 2011. 12:29 AMswilliams10 says:
One thing that you probably all ready know, but I'll say for anyone else who's considering this is, when choosing drivers to build your own speaker, you can't just choose whichever one that you like best, or have good specs, efficiency, etc, because, for example, if you choose a woofer that's not very efficient(lets say 85 db 1w/1m), and then a tweeter that has a very high efficiency(lets go with 100 db 1w/1m), there, you have a problem, and the high frequencies will be a lot louder than the lower frequencies. Another thing you have to consider when choosing drivers is their frequency ranges. Yes, the ranges given aren't the exact range of a driver, most drivers can play beyond the stated frequency range, but the stated frequency range is usually within a +/- 3db or so range, so any frequencies beyond that will be much quieter. If you choose a woofer that has usable extension up to 2000 hz, and then a tweeter that only extends down to about 4000 hz, you will have a large dip in the spl that is most noticeable around 3000 hz and such. Long story short, there's a lot more in choosing a driver than just finding drivers that look nice and that you like. For more detailed stuff, look at the speaker building bible on the parts express tech talk forum.
Jun 5, 2011. 12:54 PMnetrunner says:
For the older "SURE electronics" 2x100W @4ohm KT2050, its R18 and R33 to modifie. 6,8Kohm can be added in parallel.
That is 1 resistor lower then in the picture. Can be a mistake in picture.
http://www.sure-electronics.net/download/AA-AB010_Ver1.0_EN.pdf
Apr 29, 2011. 1:21 PMweener says:
Hi there. I followed this great guide with great results! ... I've gotten myself a really hardcore off-grid party sound system - just what i was looking for. This tutorial is one of a kind.
BUT, i have to minor problems!
The setup:
2 x Behringer B215XL 15" with the above preamp and a Tripath TK2050 amp installed in each. Both are wired identical to each other!
Wired up to 24V.
1. one of the speakers are noticeably less loud than the other. We tried change their power source, audio input, and adjusting the preamp (tweeter / woofer screws) - Ideas?
2. When speakers are connected to the same power source - a loud noisy interference appears.. When one speaker is disconnected the noise goes away, also when they're on two different power sources. So the interference travels through the power cords?
I would really appreciate some help and ideas!
It's not a BIG problem, but it's annoying.
Below, a picture of the setup inside the speaker
Cheers
May 4, 2011. 7:57 PMdamiengwalker says:
Do you know if a phonograph preamp will work?
How much do you need to boost the signal by to make this work?
Thanks for the help.
FYI: I have the TK2050 and measured a power draw of 37 Watts (total) using an ipod and 2 8 Ohm speakers.
Apr 21, 2011. 8:12 AMcjones-2 says:
(removed by author or community request)
Apr 22, 2011. 5:32 AMcjones-2 says:
ahhh there !
and could I use this Valve Class A Tube Headphone Amplifier pre Bravo V2 AU1 as the level booster ?
Mar 27, 2011. 8:50 AMkwahlgren says:
Are these t-amps bridgeable to Mono? I'm looking to use a Pioneer B20FU20-51FW driver and id rather have both channels powering it.
Apr 18, 2011. 7:52 AMesmash says:
So does this mean it is possible to send all 200w to one woofer? If so, how could this be done? Thanks
Apr 4, 2011. 9:00 PMtamadoctor says:
I'm planning on building a stereo system. I'm looking at two of the Behringer B212XL's, two TK2050 2x100w Amps, and two crossovers. I'm also looking at an amp/mixer as you described elsewhere. The TK2050 is rated 100W at 4 ohms, however the B212XL is rated 8 ohms. So am I to assume I won't get full power out of this? Or could I instead wire one crossover into one amp, split the channels to the tweeter and woofer and run both in parallel to get full power and two mono speakers? I think I may be missing something here. Advice would be appreciated!
PS I'm digging the work you've done on your mobile DJ rigs. Thanks for posting!
Apr 4, 2011. 4:57 AMQsam says:
so if u have an active speaker u still need an amp and a mixer?
Mar 13, 2011. 8:49 PMZem says:
Is there a volume control for the MKII TA2020? I'm thinking of buying that. Would it just be volume from the input device?
Mar 14, 2011. 7:19 PMZem says:
Okay, thanks!
Dec 11, 2010. 2:24 PMsbriggs says:
Note that you MUST use a powered mixer to to get full power out of these, but even so these are the best deal going for a high power setup.
Could you explain this statement to me please? Is this as a power source or for the audio?
Dec 11, 2010. 4:01 PMsbriggs says:
That's brilliant! I've found the whole instructable very informative. Thank you! If you don't mind me asking a couple of questions (I'm pretty new to all this!).
- You say that having an efficient amp like the T-class you use is x2 better. Does this just mean it drains the battery less quickly? Because in terms of ensuring the amp is suitable for the speakers, we still use the power per channel rating given to the amp to compare with the RMS power of the speakers, yes?
- By choosing efficient speakers and perhaps deciding to use pre-amp crossovers, we can achieve "more output for the same amount of power". My question is, is it a problem to run a speaker/woofer at way below its RMS power? I understand that it wouldn't be being used to its full potential, but I just wanted to check it wasn't actually damaging in any way. Say I used the mini ipod TA2020 amp (so 20W/channel) with say an efficient (98dB SPL @ 1W/1m) 250W RMS speaker. Is this an issue?
- Finally, I have a pre-amp for my record player to connect to the cheap Hi-Fi system I own. Would this do the same job in boosting the MP3 player's signal as the powered mixer you use before running it into the TK2050 amp?
Sorry for the barrage of probably-quite-mundane questions but your instructable has got me hooked and I really want to learn and build more!
Dec 30, 2010. 8:22 AMN.I.Patterson says:
Hmm. The received wisdom in general (at least in live sound applications and amongst long in the tooth audiophiles...........I do both I must confess!!) is that there is no issue to running a speaker with an amp well above its power rating ( I ran my own expensive reference 200w speakers with a BGW 750a no problem, it's hugely powerful.). To be precise a speaker likes to 'see' clean UNDISTORTED power up to its maximum rating. An over specified (in terms of power with regards to the speaker) amplifier will drive a speaker cleanly without any distortion. Running an underpowered amplifier into a speaker though for fairly long periods (say over 15mins at a guess at least) at high levels will produce lots of evil distortion. This distortion over time will cause the voice coil of the speaker to heat....more likely past the point of no return and cause it in turn to burnout. An underpowered amplifier is capable of exceeding its specifications by quite some way in general. A 20wpc rms amplifier may produce (at a guess) 80wpc channel of something that cannot really be said to resemble music. We all know its signature sound, harsh, objectionable, edgy etc. We choose to ignore these warning signs when we are drunk, ignorant, distracted (driving) and on and on. The speaker will let you know that you have exceeded its and the amplifiers limits by refusing to party anymore. So that speaker that was capable of handling 40wpc rms has just been ko'd by a little 20wpc amplifier. Running a speaker with a big amplifier (as big as you like really) is a good idea BUT YOU HAVE TO BE REPONSIBLE THE SAME AS RUNNING IT WITH A LOW POWERED AMPLIFIER. No matter what wattage of amplifier speaker combination you use you can blow nearly any speaker......I think. If it sounds distorted and you play it like that for long enough something may well give. Things break. Speakers are things with finite capabilities. Also if you are playing rap/reggae/drum and bass/r&b and what not AND boosting the bass and treble still further you are inviting trouble. Music like this will sap any reserves even from a well specified amplifier. Power ratings tthough are not going to save your speakers from misuse. Your ears, experience and knowledge of application of the speakers specifications/parameters may. I venture this info by the way from having, in a past life, had to deal with distressed customers who no matter what you enlightened them to previously went off on a tangent and returned with 'toasted' speakers. Oh well after repairing said speaker they were definitely a little more 'open' to any further information you could give them! Oh yes amps are protected, at least professional amps are, from burnout but speakers have to fend for themselves as they are the 'messangers'. Messangers (Julian Assange maybe?!!!!) tend to get shot at the best of times!!
Jan 2, 2011. 6:37 AMN.I.Patterson says:
Good point Dan, your brand of real world experience supercedes theoretical advantages I concede. I did sound for my brother recently at a very big christmas golf club party (he runs a successful Motown/popular music act) and he impressed upon me to address the routing of the cables for the system with a little bit more care "never underestimate drunk people" he said!! Yes in the chaos of live performance of any kind a variable may arise that will leave you with more than a touch of egg adorning your countenance!! I guess also in a home situation if you have an inquisitive toddler sharing your home space you may rue the day you placed an amplifier capable of armageddon lovingly into the heart of your system.
Dec 13, 2010. 3:52 AMsbriggs says:
Thank you so much for your help!
I've just remembered I've got my grandad's old PA system in the attic. They're colossal, probably massively inefficient, 16ohm 70W beasts. I'm gonna see if I can work them/one into some sort of system. Perhaps in a bi-amp system with one TK2050 amp trying it's best to get them going and then a smaller TA2020 running the higher frequencies through some bookshelf speakers.
It started here! Thanks for your brilliant instructable and helpful advice!
Dec 20, 2010. 8:37 AMstiltPro says:
Would love to learn about a upgrading from a Dayton /Soundpax system using transducers / exciters to a more powerful system that is still very light weight.
We use the Dayton DTA-1/SoundPax mini amp with the pyramidal cardboard speakers
http://www.newscientist.com/article/dn1921-collapsible-cardboard-speakers-unveiled.html
inside our Dancing Christmas Tree costumes.
http://www.youtube.com/stiltpro#p/u/38/XLGrnc3NneE
The sound you hear is from that system. Very good in a quiet setting, but would like more volume for parades.
Any suggestions?
We also like to use them in our Giant Parade Puppets.
Bill Coleman
http://www.stiltwalker.com/
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
