3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Off-Grid Party Sound Systems
Step 7The Elements
The Elements
Depending on your application, you may want to improve the waterproofing or vibration proofing of your gear.
Waterproofing - if you are re-cycling a home audio speaker, you probably want to paint it.  a PA or DJ speaker normally has a waterproof box.  In either case, i found the woofer cone is often made of unprotected stiff paper.  You can easily waterproof this by coating it with a thin layer of a water-based urethane wood finish - such as Varthane - from your home improvement store.
Vibration proofing - i'm making mobile bike systems, these get vibrated a lot.  amps often have some larger components in them that may or may not be well attached to the amp board.  take a look and glue down anything that looks flimsy.  hot-melt glue and silicone glue both work well to glue down any wobbly parts in your electronics.  some of the T-amps are ok.  the ones from arjenhelder_electronics needed some anti-vibration glue (see the photo).  the original TK2050 from sure electronics also needed a bit of help.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
524
Author:dan(MonkeyLectric)
Dan Goldwater is a co-founder of Instructables. Currently he operates MonkeyLectric where he develops revolutionary bike lighting products. He also writes a DIY column for Momentum magazine.
