Battery Powered Portable VU Meter
 by Vlorbschnat
Featured
What follows are instructions for constructing a battery powered portable VU meter, as well as detailed instructions for the construction of the PCB needed to complete this project. It was designed to illuminate from 0-10 LEDs depending on ambient sound levels. I designed it to be attached to a wristband, clothing, or a necklace if the design is scaled down somewhat. Its purpose is to be worn in a nightclub or similar locale where music is playing, as an animated alternative to a glow stick. It can be used, however, for a variety of alternative purposes.
http://www.youtube.com/watch?v=cj2tngwrCHE
http://youtube.com/watch?v=ae-oSzv2UWs
Step 1: Materials Required
For this project, you will need the following materials:
1. 1 LM3916 IC
2. 1 LM386 IC
3. 10 LEDs
4. 1 UV Reactive PCB Board
5. 1 18 pin IC socket
6. 1 8 pin IC Socket
7. Various SMT Resistors
8. 1 Dremel tool
9. 1 UV Exposure box
10. Developing chemical
11. Etchant (I use Ferric Chloride)
12. 1 Fine soldering pencil
13. Fine silver-bearing solder
14. 4 3v coin cell batteries
15. 2 Sockets for 2 coin cell batteries each
16. 1 switch
17. 1 electret microphone
18. 3 (1 uf SMT capacitors)
19. Denatured or Isopropyl alcohol
In a pinch some of these components may be purchased from Radioshack but your best bet is to buy them from DigiKey.com or from Frys Electronics, or other equivalent local electronics parts retailer.
1-40 of 96Next »
nicholasm says: Nov 25, 2012. 3:30 AM
are you using ExpressPCB?
teebhai says: Dec 28, 2011. 11:29 PM
there are many other ways of etching a pcb, y u used a specific uv board for a simple project
IronWill in reply to teebhaiJul 2, 2012. 8:35 AM
for this perf board would have worked without a problem, yea?
ltelaprolu says: Sep 28, 2011. 10:57 PM
i connected the circuit but only 1st led is working :( may i know the reason?
Suraj Grewal in reply to ltelaproluMay 28, 2012. 8:49 PM
bad mic
candelo says: Dec 21, 2011. 11:22 AM
Great project! take a look my similar project
http://candelectronica.blogspot.com/2011/12/led-vu-meter-en-un-hcs08-freescale.html
ltelaprolu says: Sep 28, 2011. 11:22 PM
i connected the circuit but only first led is glowing actually blinking :( is there anything wrong in the curcuit posted above? did anyone try it?
tjmortenson says: Sep 12, 2011. 5:27 PM
Could you post a file for the pcb?
Blue_Flame says: Sep 12, 2011. 12:48 AM
Hi there Vlorbschnat
is there a way of driving multiple LED's off of one output (i.e. 10 LED's per output pin)?
I know that I will probably need to increase the drive or gain but as I haven't fiddled around with electronics for a few years my mind needs a refresher!
Many thanks
Rob
qwerty156 in reply to Blue_FlameSep 12, 2011. 1:34 AM
You could use a simple transistor like the 2n2222
ajinkyadixit says: Sep 11, 2011. 9:32 PM
hey guy please give pdf file of pcb artwork..............
skeva94 says: Apr 12, 2011. 4:45 PM
Link for PCB???
gcampton in reply to skeva94Apr 22, 2011. 9:43 PM
make your own?
skeva94 says: Apr 12, 2011. 4:46 PM
PCB link for PRINTING...
Skyyl says: Mar 22, 2011. 2:42 PM
What kind of LED's did you use, does it matter?
Vlorbschnat (author) in reply to SkyylMar 22, 2011. 10:33 PM
Some colors of LEDs require a different voltage, but it should be safe for the vast majority of LEDs
Skyyl in reply to VlorbschnatMar 23, 2011. 5:09 PM
alright thank you! quickest response iv ever gotten on here =]
LiLGq says: Mar 3, 2011. 6:21 PM
i only have one comment for you sir........."SUPER"!!!!!!this instructable is the best......iv'e been searching for thing like this that a speakers which has sorts of LED that blinks from the grooves of the music..............
LiLGq in reply to LiLGqMar 3, 2011. 7:35 PM
another thing is, is it possible to replace the electret mic and attach the two wires to the speakers?.
Vlorbschnat (author) in reply to LiLGqMar 3, 2011. 8:48 PM
Sure, that should work fine
LiLGq in reply to VlorbschnatMar 6, 2011. 4:04 PM
thanks!!!....
handyman29 says: Jul 26, 2010. 4:40 PM
Are the two 1uF capacitors polar or non-polar?
Demircat says: Jun 3, 2009. 4:59 PM
Could you post a schematic/circuit diagram? Thank you!
Vlorbschnat (author) in reply to DemircatJun 3, 2009. 10:45 PM
Actually, another Instructables member has already posted a schematic, you can find it at http://www.instructables.com/files/orig/FX5/67GS/FLROK12R/FX567GSFLROK12R.gif
handyman29 in reply to VlorbschnatJul 26, 2010. 4:31 PM
The schematic does not match your PCB board. You have totally different resistor and capacitor values. I think yours makes more sense though.
Demircat in reply to VlorbschnatJun 4, 2009. 5:06 PM
Ahh okay, is it that your schematic calls for 6v while this one calls for 9v? Thanks again!
Vlorbschnat (author) in reply to DemircatJun 4, 2009. 9:32 PM
The components should run off of either 9V or 6V, I just used 6V because the coin cell battery holders I had had 2 3V batteries in series.
LiLGq in reply to VlorbschnatMar 6, 2011. 5:38 PM
phew!.....i thought it only runs through 12 volts 'cause there are 4pcs 3volts batteries then in my place those types of batteries like CR2032 costs 80php (almost 2 dollars)..good thing i saw this comment!...
thecone2005 in reply to VlorbschnatMar 2, 2010. 1:30 AM
sorry I use lm3915N-1 and it doesn't work,i must replace it by Lm2914?
LiLGq in reply to thecone2005Mar 6, 2011. 11:22 PM
it wont really work 'cause you used LM3915.....read the materials needed again it says lms916.....hope it helped
ARJOON in reply to thecone2005Dec 9, 2010. 5:07 AM
lm3914 works better
handyman29 says: Jun 22, 2010. 1:41 PM
Can I use ceramic capacitors for the non-polar capacitors?
Vlorbschnat (author) in reply to handyman29Jun 23, 2010. 1:41 AM
Yes, ceramic capacitors are non-polar capacitors
handyman29 says: Jun 17, 2010. 1:41 PM
Can it run off of a 5vDC adapter?
Vlorbschnat (author) in reply to handyman29Jun 17, 2010. 11:44 PM
I think that should work, it was originally designed for 6V but 5V is close enough that it should still work.
handyman29 says: Jun 16, 2010. 9:14 PM
Can I use regular capacitors instead of SMT caps?
Vlorbschnat (author) in reply to handyman29Jun 17, 2010. 1:51 PM
Sure, it should be fine to use through-hole components instead of SMT components.
Zem says: Mar 2, 2010. 5:48 PM
 I kind of want to scale the size up a bit, to have it be stationary or on a wall or something, so could I use thru-hole Resistors if I scale up? (I dislike surface mount components)
Vlorbschnat (author) in reply to ZemMar 3, 2010. 8:30 PM
Sure, I actually used through-hole components for the prototype version, so it should be fine to use all through-hole components.
zack247 in reply to VlorbschnatApr 14, 2010. 11:09 PM
thank you! i was wondering this myself, as i have absolutely no experiance with surface mount components.
1-40 of 96Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
