Battery Tester
Published
Introduction: Battery Tester
This Arduino project will help you test your battery. You will get an estimate of the amount of battery your battery has. DO NOT EXCEED 5V
MATERIALS:
  • 10 wires
  • 3 LED lights(color doesn't matter)
  • 1 bread board
  • 1 Arduino board
  • 1 battery(5V or less)
Step 1: Code
float on = 1.4;
float off = 1,4;
float Volts;
void setup(){
pinMode(13,OUTPUT);
pinMode(12,OUTPUT);
pinMode(11,OUTPUT);
Serial.begin(9600);
void loop(){
Volts = analogRead(0);
if(convert(Volts) > on){
digitalWrite(13,HIGH);
digitalWrite(12,HIGH);
digitalWrite(11,HIGH);
if(convert(Volts) > off){
}else
if(convert(Volts) < off){
Serial.println(convert(Volts));
float convert(float watts){
return((watts/1024)*5);
Step 2: Assembly
Different types of batteries can be used. Just a few tweaks of the code are needed. Do not use a battery that is higher than 5V.
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    Sounds good! Did you get a chance to make this?
