Also everything I just said is somewhat misleading, this circuit for some reason works more like an external battery rather then charger. If someone could point out why Ipod's say charged when this is plugged in rather then charging please let me know and I will update accordingly.
On the last step at the bottom also tells you how to get the same USB plugs I use free.
*I was looking at the Minty Boost Instructable page and it said a 9v battery with a 5v regulator aren't efficient because the regulator gives off lots of energy as heat. I haven't calculated the efficiency of this circuit but it should be fairly efficient because the transistor, unlike the regulator, looses almost no energy as heat. If someone decides to calculate the efficiency please let me know what it is, I would like to know but will never get around to calculating it myself. Thanks.*
NPN circuit is on the last page.
Also this instructable may help get the Ipod to charge:
How to get your iPod to charge with your homemade charger.
Its about the data pins and uses 4 resistors.
Remove these ads by
Signing UpStep 1Parts
- 9v Battery
- 9v battery clip
- 2N4403 PNP transistor (Circuit can be modified for a NPN fairly easily)
- 5k variable resistor or trim pot (I used a trim pot because I had the right size lying around)
- 100 - 330 ohm resistor
- LED (color is up to you, I suggest green cause it looks more power, circuit working, good kind
of look to it, where as red looks like STOP! theres a problem! type of thing, if you know what I
mean)
- a ceramic or tantalum capacitor (last step I have a question about tantalum caps, Please
Comment!)
- a 6 to whatever volt 220uF cap (I used a 50v cap which is a little over kill)
- Female USB plug or other plug
- perf board or you can etch you own with copper clad
Tools
- soldering iron and stand (stands optional but handy)
- solder
- side snips
- a dremel or other tool to cut perf or copper clad board
based on a BFY51 transistor (R1 is meant to be 330 ohm, not 1k)
Does it drain battery when not using it with an iPod or other device?
If it does, can I make a switch on it? (I'm totally new to electronics)
Thanks.
If I can get some PNP transistors I will construct a circuit and trouble shoot. I couldn't find a way to order the PNP transistors from a site on the sample site list though.. Any ideas?
-gen.badger of Ninja.inc
And yes, LiPo are the scariest batteries around, I don't like having them around even, but I have a few things that use them and need them removed to charge and I always sit and watch them charge so they don't burst into flames or explode and such.
and also i had trouble finding the right transistor it is ok to usee something about a hindred digits off and npn
could you also tell me how to wire the npn?
thanks this is a great project keep up the great work
i appreciate the help
Try to use it.
www.instructables.com/id/Ipod_Touch_Charger_100_works/
cerberus.teamhackaday.com/
