3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Battery-free 5 volt project power
Step 13Connecting the faceplate and step-up converter circuit
A. Put the motor M1 back into its original location in the bottom half of the case. Extend the wire that's coming out of the motor - the ground M1(-) wire - so that it's touching the middle pin the of switch, SW1(1), and the negative terminal of the large capacitor, C1(-).
B. Cut and strip the M1(-) wire to the appropriate length and solder the wire, SW1(1), and C1(-) together. This is an important connection, so make sure the three are soldered.
C. Turn the case so that the motor is on your left, and bend the cathode lead of D1, D1(-), so that it's touching an exposed part of the positive terminal of C3, C3(+).
D. Solder D1(-) and C3(+) together and trim the remaining length of D1(-).
E. Solder the SW1(2) wire to the negative bus of the faceplate.
F. Solder the wire connected to the positive bus of the faceplate to the positive terminal of the large capacitor, C1(+).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:Griswold Lighting
