Introduction: Battery Operated Air Purifier
Picture of Battery Operated Air Purifier
The Battery operated air purifier is simply to freshen up small rooms that lack air conditioning . Although this is about one cubic foot and weighs about three to 4 pounds.Testing to see how well it works was with a grove dust sensor and the air purifier halved the concentration of particles in the air . The testing was done in a closed environment and data that came as result of outside influence is exempt.The air flow comes out the the four sides of the pink lamp shade and still maintains a consistent air flow. Examples of uses is tents,shed, and etc.You will be protecting your nose from a siege of allergens and bad odors in a crowded tent while you try to go to sleep.
http://youtu.be/jK_3GKA6Pm0
Materials
Tan lamp shade rectangular
Pink lamp shade circular
8"x8"x1" merv filter 8 pleated
16# felt pads
Electrical tape
2# Rubber o rings
Duct tape
Electrical motor and fan blade from o2 cool
Leadless solder
Artist palette plastic
mini rocker switch
6# c batteries and the battery holder
Insulated wires
Clothes hanger
Carbon filter
Tools
Soldering iron
Sharpie
Tin snips
Scissors
Pliers
Respirator mask
Goggles
Wire cutters
Philips head screw driver
Step 1:
Picture of
I took the motor and fan blade from the o2 cool simply because shipping seemed expensive ans long since of Christmas season.
Step 2:
Picture of
No the wires weren't already like that from o2 fan you have to solder the wires on the motor
Step 3:
Picture of
Take the old tan lamp shade and place the the motor in it and it should be a tight fit but don't glue it yet
Step 4:
Picture of
i put on some electrical tape hoping that motor wouldn't slide out
Step 5:
Picture of
i simply put on a two rubber o ring on bottom
Step 6:
Picture of
and put on the old fan blade on the motor
Step 7:
Picture of
And at the larger end simply pressed the merv filter and taped it with metallic tape making sure that no air could escape.
Step 8:
Picture of
then put on the carbon filter measure it out and make sure it is a little bit smaller than the merv filter
Step 9:
Picture of
Then tape it as long as the tape seals it excellently it doesn't matter what is used although obviously avoid hazardous
Step 10:
Picture of
Then put 4 felt pads on top of each other at each corner.
Step 11:
Picture of
make sure it isn't off balance
Step 12:
Picture of
Then double check and seal off it once more with tape
Step 13:
Picture of
simply cut a hanger with tin snips bend the opposite it other way of the hook and put it through middle hole of the battery holder
Step 14:
Picture of
Although yo want to get the the batter holder really close to the top
Step 15:
Picture of
put on the circular shade on the tan lamp shade and then attach the pack as shown in the picture although i did put some electrical tape at the top of the battery holder
Step 16:
Picture of
make sure the battery holder doesn't show
Step 17:
Picture of
keep the wires nice and easy to take off
Step 18:
Picture of
one wire hooks up to just the battery holder while the other fan blade to the mini rocker switch and another wire mini rocker switch to battery holder . Turn it on and experiment till the air is being sucked in from the bottom
Step 19:
Picture of
the trace the circle on to the plastic artist palette and spare the hole
Step 20:
Picture of
cut the circle i used tin snips it was sort of like butter
Step 21:
Picture of
now tidy up the insulate wires and cut to the length that is nice and short but sticks out one inches above the top of the tan lamp shade.
Step 22:
Picture of
the poke two insulated wires through the hole in the palette.
Step 23:
Picture of
then secure each wire to the rocker switch as shown in the picture
Step 24:
Picture of
add a little slit for the hanger and start taping the plastic palette down
Step 25:
Picture of
it important that you tape around the rocker switch, tape the hanger and it does necessarily mean that taping the plastic palette needs to be air tight fit.
Step 26:
Picture of
your finished product varies in size since a 12"x12"x1" filter would require larger lamp shades but its basically still the same formula but a change in materials
mine looks likes like this
Step 27:
Picture of
This the system I used but to start out put the sensor and the laptop in a container the sensor would measure every 30 sec or so and it would show up on the serial monitor. this was largest clear plastic container I had and I also needed to check in on the laptop since the battery is bad and it mainly relies on the electrical outlet. So it has about 5 to ten minutes or so .
43993,0.15,76.8
43993 is the lowpulseoccupancy
0.15 ratio
76.8 concentration
sensor can detect as low as 1 nanometer in particulate size
http://www.seeedstudio.com/wiki/Grove_-_Dust_Senso...
Step 28:
Picture of
sealed in the container i did interrupt it once just a little nervous
Step 29:
Picture of
lifted the lid and quickly took a picture after enough time had past
Step 30:
Picture of
here is a close up of data
Without air purifier
43993,0.15,76.8 starting exempt
248069,0.83,428.63
153109,0.51,265.17
Exempt checked in
173064,0.58,297.54
37570, 0.13, 65.65 exempt ended
Step 31:
Picture of
now this with the air purifier
Step 32:
Picture of
Air purifier on
0,0.00,0.62 starting exempt
28833,0.10,50.56
Exempted checked in
84782,0.28,147.30
47923,0.16, 83.59
60062,0.20,104.58
100464,0.33,174.37
0,0.00,0.62 exempt ended
About This Instructable
1,588views
6favorites
License:
More by Southern grey desert foxes:Sardine WrapRubberband BowlingBlank canvas
Add instructable to:
