3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Battery operated centrifuge for cell separation in fluid suspension.
'We offer a step by step description of how to make a battery powered 9-24 volt DC motor driven centrifuge for separation of cell in fluid suspension for under 20 dollars. This centrifuge may be used in the field (when no other technology is available), and is set in a cookie tin or coffee can to prevent accidental release of content.
Bullet shells act as the "buckets" for the centrifuge.
Paperclips are bent to hold the shell casings, which spin out when the motor begins to turn.
A DC motor speed controller allows control over acceleration and deceleration.
A motor spinning at 2000-2500 RPM with a radius of 2 inches will develop the
600 g of centrifugal force required to separate cells in fluid suspension.
We used 1 milliliter pipettes which fit into the bullet casings to spin-down a "cell pellet"
in a pleural fluid sample however a "virtual tube" of cellophane will also work .
This project was supported in part by the Center for Parabiotics Research.
Project team members: R Siderits, J Jaworski, W Lecorchick, O Ouattara
Step 1Finished prototype
Finished prototype
Here is an image of the completed centrifuge. We chose to place the motor, arms, and buckets on the outside of this cookie tin for demonstration purposes. You may choose a larger coffee tin or better yet, a 12" diameter, 2-3 inch deep cookie tin to place it inside.
Use the lid of the cookie tin to completely cover the centrifuge for safety.
The knob on the front of this image is the DC motor control. We used a two part plastic and a bottle cap as a mold for both the rotor head (center) and the speed controller knob.
32 comments
Jan 25, 2009. 12:00 AMDIY Dreamer says:
As a medical professional who uses centrifuges extensively daily, I found this project clever and interesting, BUT using this for biological material other than plants is incredibly dangerous. Full body armor is not sufficient to protect you from the diseases at large in the general population to which this centrifuge guarantees you will be exposed. Biological aerosols are nothing to fool around with.
Jul 26, 2010. 11:32 PMjexter says:
I would agree that using this in a medical diagnostic lab or equivalent would be unwise, but saying that using it for anything "other than plants is extremely dangerous" seems extremely cautious. There are any number of non-hazardous uses for a small centrifuge in biological and non-biological lab settings. The majority of clinical centrifuges are used in a non-clinical settings, on both prokaryotic and eukaryotic cells, and it's routine, not extremely dangerous. "Biological aerosols" are indeed nothing to fool around with; that's why I'm much more concerned about the guy sneezing in the elevator than the SF-9 or Top-10 cells I'm centrifuging in the lab ;^)
Jan 25, 2009. 11:25 AMDIY Dreamer says:
How about mounting the spinning centrifuge head in something like a tupperware cake container. Sealable to contain those potentially deadly aerosols. Easily cleaned of those inevitable leakages. You will be profoundly appreciative to have added this feature once you see what a huge mess a leak makes and realize what might have happened if you breathed in a lung full. And once you see how often this type of incident occurs. It probably will be resilient enough to contain a failure of the centrifuge head itself.
Sep 14, 2009. 8:33 AMsharlston says:
i drill holes in the blades of a fan then put test tubes in and turn the fan on itx=s back]]great ible 5 stars
Jun 27, 2010. 4:17 AMlabchef says:
Very elegant design and looks very sturdy.  I have created another centrifuge using computer cooling fan and foam plate/bowl. The six place computer fan/foam centrifuge can run up to 920 rpm when two 3.5 mL tubes loaded.  It will allow total 21 mL of samples to be processed at a time but the speed will drop down to 250rpm.  That should be good enough for low speed applications, such as pond life observation.
Just to share my design with you: http://microscopetalk.wordpress.com/projects/homemade-microscope-centrifuge/
Feb 5, 2009. 8:23 PMapothecary_01 says:
This is a great idea for junior high school age science projects on up to adult microscopy hobbiests who with to collect protozoa, check sedimentation of ponds or lakes and about 25000 other uses!!
Jan 27, 2009. 12:24 AMnfitz says:
(removed by author or community request)
Jan 27, 2009. 10:19 AMnfitz says:
No offence was intended, i've removed the comment. I still think my post raised some good points, and it was meant to be slightly funny, not vindictive. I didn't get your disclaimer joke first of all and thought you'd made a typo. I found the idea of having to make a centrifuge out of bullet casings in some sort of emergency situation comical..just imagining how the situation could arise..
Jan 24, 2009. 9:19 AMjongscx says:
Just wondering, aside from remote-location cell culturing, what other applications would there be for a battery-operated centrifuge? Just looking for ideas here...
Jan 21, 2009. 11:17 PMlegionlabs says:
What a great idea! I would consider building this to separate yeast out of active brewing projects for storage and later re-use. Beer is the second best (after modern medicine) application of microbiology after all...
Jan 21, 2009. 7:15 PMsoccermuffin says:
I really appreciate you posting this instructable. It will be great to build for my school science department.
Jan 20, 2009. 2:44 PMTheScientist says:
really good, looks like it works really well too! another safety note i'd just like to mention: inspect your centrifuge components for wear (particiularly the swing buckets and paper clip rotor assembly) after each and every operation. If anything looks slightly worn in the interests of your own safety it is best to replace it. this is a standard safety practice for commercial centrifuges too. If people don't do it, and a rotor shears, it can literally go through a few concrete walls before it will stop (and in fact the only safe place to be if this happens is directly above or below the centrifuge, as these are unlikely trajectories for projectiles). if you run it in a thick wood/steel box it should be pretty good for the small mass swing buckets. (google centrifuge rotor break for examples of what can happen) 5*'s :)
Jan 21, 2009. 12:24 PMPS118 says:
I'd have to second the box thing. I really hope you're not running this otherwise. When I was in medical research, we lost capillary tubes every now and then, and that was with a real microcentrifuge. Let's just say the shattering glass and biohazardous material combo does not make for a happy day -- even when contained. How much worse still if this device flings the contamination across the room!
Jan 20, 2009. 11:44 PMWyle_E says:
Do you need to know the exact acceleration? If not, a printed table would be quicker to read in the field than a nomogram. You could also use a pocket calculator. Since all you need to do is square the RPM and multiply by a precalculated constant, even the cheapest one will do. I can think of a way to use a microcontroller to get a direct acceleration readout or automatic speed control, but your design is just too elegant to fiddle with.
Jan 20, 2009. 11:33 PMhivoltage says:
it might be interesting to make a similar centrifuge using a dremel or other rotary tool for power. they're relatively inexpensive, have a good amount of torque and have built in speed control between 1,000 and 35,000 rpm. it would probably not be safe to spin that fast but you could dial the speed down whatever level is needed. serious protection would likely be needed to prevent anyone getting hurt when the speed is increased however.
Jan 20, 2009. 6:15 PMChrysN says:
Great project, it has a lot of potential in places with inadequate lab equiptment. It is a good point to build it inside a cookie tin, especially when spinning down blood and body fluids to prevent spillage.
Jan 20, 2009. 1:22 PMBongmaster says:
i got 2 of them exact same solor panels from Maplin UK :) usefull
Jan 20, 2009. 12:34 PMthatsgreat2345 says:
This is awesome, I was actually thinking about building a centrifuge but seeing if I could get an old drill off of craigslist and convert that.
Jan 20, 2009. 8:50 AMkelseymh says:
This is an extraordinary project. I'm really impressed that it functions as smoothly as it does, and your directions are (but see below) quite clear. I realize that your "blackboard" slides look really cute, but they can be a substantial impediment to actual users. Because they are graphics, none of the information provided can be searched. They cannot be read or understood by anyone who is blind or visually impaired (they can't be voiced or Brailled). They will be very hard to deal with for users on low-bandwidth connections (the impoverished, or those in impoverished regions). They cannot be translated automatically into other languages than English. Please consider either replacing those images with text, or at the very least, putting the actual text into the content of the Steps.
Jan 20, 2009. 9:44 AMkelseymh says:
Looks great! Thank you so much for considering my suggestions :-) (rated 4.5 for completeness, detail, and concept).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:siderits
