loading
Step 9: Figuring out centrifugal force
Use of this "nomogram" allows you to determine the relative centrifugal force (RCF) in g's, by aligning the radius of rotation in mm (in this case, paper clip length for the rotor arm measured from the center of the motor spindle to the base of the bucket).
The Revolutions Per Minute (RPM) can be verified with a hand-held tachometer. We used an infra- red tachometer from Harbor Freight.
This centrifuge, with certain modifications, can be used for clarifying home made wines. <br>arun kelkar
As a medical professional who uses centrifuges extensively daily, I found this project clever and interesting, BUT using this for biological material other than plants is incredibly dangerous. Full body armor is not sufficient to protect you from the diseases at large in the general population to which this centrifuge guarantees you will be exposed. Biological aerosols are nothing to fool around with.
I would agree that using this in a medical diagnostic lab or equivalent would be unwise, but saying that using it for anything &quot;other than plants is extremely dangerous&quot; seems extremely cautious. There are any number of non-hazardous uses for a small centrifuge in biological and non-biological lab settings. The majority of clinical centrifuges are used in a non-clinical settings, on both prokaryotic and eukaryotic cells, and it's routine, not extremely dangerous. &quot;Biological aerosols&quot; are indeed nothing to fool around with; that's why I'm much more concerned about the guy sneezing in the elevator than the SF-9 or Top-10 cells I'm centrifuging in the lab ;^)
Your point is well taken and I agree. Here are some thoughts that I had in offering this project Bottom line, we are talking about balancing moral and ethical justification for exploring low cost alternative healthcare technologies in an effort to reduce human suffering in countries with restricted economy, against the risk/benefit of actually utilizing them. As with many projects on this site that spin many times faster, use combustibles or high voltages, this project has inherent risk (even for "botanical" specimen processing). However, we may also consider the reality that for impoverished societies with rural populations new cytology methods that only require centrifuge processing for on-site cytology screening could make a huge difference in the ability to provide any aspect of woman's health care (try for example using an egg beater centrifuge). It is also important to consider that lower speeds, protective encasement, alcohol suspension, sealed pipette tips and longer spin times can be used to increase safety. By the way, having used a series of "coffee-can" prototypes, I was amazed how well these things actually work, especially with the upside down pipettes ( heat sealed at the tip with a hand held 1" hot-wire bag sealer or para-film). Finally, I would be grateful for your opinion, as someone who is familiar with this technology, would you be able to suggest any design modifications (for non-medical use)? We were considering an interlock for the arms or a rigid rotor head with a pin to hold the casings. The design parameters are <10$ and does not require "machining" of parts. Best regards and thanks for the comment.
How about mounting the spinning centrifuge head in something like a tupperware cake container. Sealable to contain those potentially deadly aerosols. Easily cleaned of those inevitable leakages. You will be profoundly appreciative to have added this feature once you see what a huge mess a leak makes and realize what might have happened if you breathed in a lung full. And once you see how often this type of incident occurs. It probably will be resilient enough to contain a failure of the centrifuge head itself.
Excellent idea. One leak is all it takes. We also think that the spent primers should come out if they contain any residual chemicals. We were intending it to go inside the cookie tin and only put it on top for the DEMO, but your idea fits better with clean-up and safety. Thanks!
i drill holes in the blades of a fan then put test tubes in and turn the fan on itx=s back]]great ible 5 stars<br/>
That's brilliant!
Very elegant design and looks very sturdy. &nbsp;I have created another centrifuge using computer cooling fan and foam plate/bowl. The six place computer fan/foam centrifuge can run up to 920 rpm when two 3.5 mL tubes loaded. &nbsp;It will allow total 21 mL of samples to be processed at a time but the speed will drop down to 250rpm. &nbsp;That should be good enough for low speed applications, such as pond life observation.<br> <br> Just to share my design with you: <a href="http://microscopetalk.wordpress.com/projects/homemade-microscope-centrifuge/" rel="nofollow">http://microscopetalk.wordpress.com/projects/homemade-microscope-centrifuge/</a>
Wow, nicely done! Thanks for sharing your design.
This is a great idea for junior high school age science projects on up to adult microscopy hobbiests who with to collect protozoa, check sedimentation of ponds or lakes and about 25000 other uses!!
Thanks, just make sure that the take home point is that when you make one, it goes inside of a cookie tin that is on top of the smaller battery-controller tin. Its safer that way.
Just wondering, aside from remote-location cell culturing, what other applications would there be for a battery-operated centrifuge? Just looking for ideas here...
Mostly for layering or separation of cells in suspension or separating liquids that don't mix well. It can be used to wash cells or "sediment out" things that you don't want.
What a great idea! I would consider building this to separate yeast out of active brewing projects for storage and later re-use. Beer is the second best (after modern medicine) application of microbiology after all...
Wow, never thought of that. I wonder if it would "layer" on top of an oil or underneath. The speed controller would let you go slower for more time. By the way, a hand crank flashlight (hacked) will produce enough energy to run a smaller motor, if batteries are unavailable or cannot be recharged from the solar panel.
I really appreciate you posting this instructable. It will be great to build for my school science department.
really good, looks like it works really well too! another safety note i'd just like to mention: inspect your centrifuge components for wear (particiularly the swing buckets and paper clip rotor assembly) after each and every operation. If anything looks slightly worn in the interests of your own safety it is best to replace it. this is a standard safety practice for commercial centrifuges too. If people don't do it, and a rotor shears, it can literally go through a few concrete walls before it will stop (and in fact the only safe place to be if this happens is directly above or below the centrifuge, as these are unlikely trajectories for projectiles). if you run it in a thick wood/steel box it should be pretty good for the small mass swing buckets. (google centrifuge rotor break for examples of what can happen) 5*'s :)
I'd have to second the box thing. I really hope you're not running this otherwise. When I was in medical research, we lost capillary tubes every now and then, and that was with a real microcentrifuge. Let's just say the shattering glass and biohazardous material combo does not make for a happy day -- even when contained. How much worse still if this device flings the contamination across the room!
You are absolutely right! We put it on top of the cookie tin for Demonstration purposes only. Its meant to go inside a 12" diameter by 3" deep cookie tin. The first prototype, by the way was inside of a one pound coffee can. Interestingly the pipettes did not leak at all because of their shape and the fact that they are inverted in the bullet casings. Did you see the Disclaimer? This prototype is also meant to be a field solution for use in a country with restricted economy for onsite preparation of cervical-vaginal cytology. There was also a coffee cup version with a small 3500 RPM AA motor.
Do you need to know the exact acceleration? If not, a printed table would be quicker to read in the field than a nomogram. You could also use a pocket calculator. Since all you need to do is square the RPM and multiply by a precalculated constant, even the cheapest one will do. I can think of a way to use a microcontroller to get a direct acceleration readout or automatic speed control, but your design is just too elegant to fiddle with.
Good point. You really only need the nomogram once, when you decide on the radius of the rotor (paperclip) arm. Just to make sure that the speed is enough to separate out cells in fluid suspension. After that point, the pellet at the bottom of the upside-down pipette is proof of adequate g force. We also used "Virtual Tubes" made by pushing cellophane over a pencil eraser and then down into the bullet bucket! You can even seal the cellophane with a small battery operated thermal sealer from a dollar store.
it might be interesting to make a similar centrifuge using a dremel or other rotary tool for power. they're relatively inexpensive, have a good amount of torque and have built in speed control between 1,000 and 35,000 rpm. it would probably not be safe to spin that fast but you could dial the speed down whatever level is needed. serious protection would likely be needed to prevent anyone getting hurt when the speed is increased however.
Great project, it has a lot of potential in places with inadequate lab equiptment. It is a good point to build it inside a cookie tin, especially when spinning down blood and body fluids to prevent spillage.
i got 2 of them exact same solor panels from Maplin UK :) usefull
This is awesome, I was actually thinking about building a centrifuge but seeing if I could get an old drill off of craigslist and convert that.
This is an extraordinary project. I'm really impressed that it functions as smoothly as it does, and your directions are (but see below) quite clear. I realize that your "blackboard" slides look really cute, but they can be a substantial impediment to actual users. Because they are graphics, none of the information provided can be searched. They cannot be read or understood by anyone who is blind or visually impaired (they can't be voiced or Brailled). They will be very hard to deal with for users on low-bandwidth connections (the impoverished, or those in impoverished regions). They cannot be translated automatically into other languages than English. Please consider either replacing those images with text, or at the very least, putting the actual text into the content of the Steps.
Excellent observations, I didn't think of that. I'll get the text replaced ASAP. Thanks!
Looks great! Thank you so much for considering my suggestions :-) (rated 4.5 for completeness, detail, and concept).
About This Instructable
13,653views
53favorites
License:
More by siderits:Ilustrated CAD process for creating a 3D printed assistive device in ABS plastic Rapid technique for Fabricating Disposable Thermal Chambers to be used in testing Low temperature USB powered Thermofoils and heating elements Prototype configuration for a USB Powered Low cost; real time continuous radiation monitoring system for Hospital Surgical Pathology, Hematology, Biological waste management and Research facilities
Add instructable to:
