3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Be a Ghostbuster for Halloween!
Step 5The trap and pedal
The trap and pedal
The trap body is made from 1/8" wood and MDF and the handle is a dowel. The sideplates are thin aluminum sheet and are epoxied on. The pedal is made from some aluminum door kickplate (attached to the base with a hinge), MDF for the base and has a 2 1/2" flexible ducting hose hot glued underneath it to act as the bellows. The relay and other electronic parts/knobs came from an electronics surplus store and are attached to some plastic boxes that are screwed to the pedal.
The trap lights up ( I used the same LED chaser circuit as the lights for the proton pack) and the trap doors open. The trap has a catch plate on the underside (same as the proton wand) and a matching plate on the belt holster so it can hook onto my belt. The pedal then hangs over the trap by hooking the gray cable on top of the pedal over the trap handle.
6 comments
Nov 6, 2010. 3:41 AMgreatscottbttfride says:
cool stuff their
Oct 5, 2009. 9:53 AMbravotreble says:
can't get over how awesome all your stuff looks. where did you get the dimensions (height, width and length) to build the trap? or maybe i could make this easier and just ask you the dimensions of the trap you made
Oct 4, 2009. 3:49 AMNykus79 says:
wow the trap! I want it!... can you make me one? :)
Oct 5, 2009. 6:39 AMNykus79 says:
No problem I was kidding. But thank for link :) Maybe others would use it for theirself
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
619
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
