Be a Romantic Scientist: Distill your own perfume oil.
Perfume is often seen as a last-minute gift that requires little thought. But what if you made your own, unique scents?
Step 1Materials needed
Materials needed
You will need a vessel to heat water in, a source of heat, gauze or muslin, thread, a delivery tube, a receiving vessel and ice.
You will also need a pretty bottle to store your scent.
For this example, we used a conical flask, a fabric bag of sprigs of lavender plus shredded, a plastic delivery tube and a test-tube in a beaker of cold water. The oil was stored in a film cannister. You may use whatever equipment you can find, at whatever scale you need to produce your scent.
If you are blending oils, you will need a dropper pipette for each raw oil you use.
149 comments
1-40 of 149next »
Oct 28, 2011. 12:17 PMJodex says:
(removed by author or community request)
Oct 28, 2011. 12:41 PMJodex says:
Oh sorry, I deleted my comment so I could make a new and upgraded one... Anyway my first comment was: Now I just need to find a shop that sells those flasks so I could try distilling my own scents. What do you think, would peat make anything at all?
Thanks for the quick answer! I know that I could find it easily online, but buying "live" would be maybe little easier. If I can't find any flasks here, then I'll order online.
For how long does these scents stay good? I mean that would there start to grow some mold or something like that after a few months or so?
I'll try peat - and many others - just as soon as I get all the needed equipment, by whitch I propably mean only the flask.
Oct 27, 2011. 9:37 AMMauigerbil says:
Just my luck! A rose fell off of my grandma's rosebush. This was the first thing that came to mind. Would one rose be enough?
Thanks
Maui gerbil
Oct 28, 2011. 9:07 AMMauigerbil says:
My perfume smelled DISGUSTING! Good 'ible though!
Oct 27, 2011. 6:22 PMcadams18 says:
loved it!
May 22, 2011. 10:32 AMsaintneko says:
For the curious, those type of flasks are also known as 'erlenmeyer flasks' and they are awesome. Googling either term will get you the same type of flask but somewhat different result sets - erlenmeyer tends to return all-glass, more sciency types of shopping results.
Sep 9, 2011. 11:51 AMMutantflame says:
Really? I'm English and we call it an erlenmeyer flask where I live. But then again most of my useful chemistry knowledge is self-taught so I do have quite a bit of american influence I suppose.
Aug 5, 2011. 2:07 AMwackman says:
In Spain, we call it Erlenmeyer's flask .
Aug 3, 2011. 3:25 PMdutado says:
Even in Czech Republic, we call it Erlenmayer's flask.
Dec 26, 2011. 2:15 AMaristide202 says:
That kind of lab flask is called Erlenmeyer in italy too, he was a german 18th chemist . Anyway the flask must me fire resistant, pirex, duran or somekind of similar material. A low smooth flame and one ore two of those metal nets will help not to brake the flasks. A modified pirex coffee or teapot could be an alternative to a real erlenmeyer
Jul 21, 2011. 10:16 AMAlgag says:
From what i remember from science class (and just verified on Wikipedia) it was named for the guy who invented it
Aug 22, 2011. 8:53 AMEli_Z says:
In soviet Russia erlenmeyer call you flask!
Sep 26, 2011. 8:46 AMArendos says:
I'm pretty sure that's not how the meme works.
Aug 3, 2011. 5:55 PMekjebe says:
Would someone be able to come up with a list of more common household objects to be used to create your own perfume? I know these steps listed leave much of the project up to your own creativity and equipment, but I tend to lose my common sense quite often. I'm just wondering if this is possible to do without spending money.
Sep 27, 2010. 6:44 AMVoid Schism says:
Not sure how safe peach stone innards are as perfume, as they contain cyanide.
http://www.associatedcontent.com/article/1941154/the_unknown_danger_of_peach_pits_poison.html
May 31, 2011. 7:18 PMchancerogers says:
I dont think itll matter too much as long as you dont go eating the perfume... You dont plan on eating it... do you?
Sep 29, 2010. 2:14 AMVoid Schism says:
Only bitter almons, which are not for human consumption.
Edible almonds don't produce the chemical (glycoside amygdalin) that turns into prussic acid (hydrogen cyanide).
Never try to smart arse a start arse
Aug 21, 2011. 9:01 PMVengence says:
Well apple seeds and watermelon seeds do. I eat them occasionally; many people eat them regularly. I've never heard of anyone dying from it.
Feb 10, 2011. 10:44 AMgtoal says:
Do you think this would work for extracting extra hot raw chili oil from chili peppers?
Mar 21, 2011. 2:11 PMbereal511 says:
I think that chili oil has a pretty high boiling point, so it ends up burning when you try to distill it. I used to extract the capsaicin (hot chili oil) from peppers using rubbing alcohol or Everclear; I'd just put a couple of peppers with about a quarter cup of the alcohol, then boil it for about 30 minutes, adding alcohol as it evaporated. Then I strained the peppers, and boiled off the alcohol from the solution in another container. Gave a nice ruby red oil that burned like Hell :)
Dec 10, 2010. 8:21 PMraja681 says:
can you tell me exactly what u used
Dec 11, 2010. 12:46 PMMikedood says:
Would cheesecloth be an ok substitute to muslin? Are there other materials that would work?
Nov 18, 2010. 7:56 AMGreenD says:
You should use substantially more plant material with that much water.
You should also describe the science behind why this happens - nobody asked "Well why does water take out the oil?" That shouldn't make sense to anyone :) unless you understand the reasoning.
Nov 13, 2010. 12:53 PMpyrorower says:
Something just occured to me, isn't this setup very similar to how a Moka works? Therefore, couldn't you use one to distill some of the oils provided you clean it out well each time? Here's a link: http://en.wikipedia.org/wiki/Moka_(coffee_pot)
Mar 5, 2008. 9:42 PMPhyrkrakr says:
How long did you keep the water at boil? I would assume you just boiled all of the water in the beaker off, but is there such a thing as boiling too much water through the plants?
Dec 12, 2009. 1:36 PMflamesami says:
I personally still don't understand, is there such a thing as to much water or not?
Jan 28, 2010. 6:23 PMXHorntail says:
"Too much time exposed to that much heat could damage the smell-chemicals."
Do you have any sources for this? Not looking to pick a fight, I was just thinking that if you could cycle the condensed fluid back into the boiling flask, you could make a bit of a concentrate. That wouldn't work if the extended time under heat damages the scent though. So I'm just wondering if you're sure about this and have any sources before I attempt it.
Sep 27, 2010. 3:44 PMvickers101 says:
If one soaked the bung (i.e. paper towel) in ice water and then repeated the process would this prevent denaturation? Also couldn't the same effect (concentration) be obtained from using new lavender leaves and the condensed liquid? I'm thinking I might try these and find out for myself but the ideas are out there for those who are interested
1-40 of 149next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
790
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
