Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
i have a question, one part of copper wire goes connected to earth and to a static electricity fuel or to a baloon, the other part of wire... goes where?
thanks
We tended to make the foils in pairs to make it easier to balance the rotor.
My first questions would be "Was the weather humid?", and "Were you in contact with bare metal on the radiator?".
I bought a cheap refurb Van de Graaff off e-bay and it arrived today. The thing is, the generator makes so much electrostatic wind that a plain plastic cup will turn in any case - no need for the foil!
I made my rotor using mylar film from a crisp-bag (chip-bag if you are American) and it seemed to work very well. Turned when the other end of the wire was about a foot from the VdeG. No need to actually contact the dome.
I think the friction on the cup is just so low that it turns with the slightest breath. Certainly you don't need to be anywhere near contacting the dome once its charged up to make it spin (that's the rotor with the mylar strips). It wil easily turn a plain cup by the wind it produces, but you need to contact the dome for that one.
If you only have a couple of feet of spare wire, find an extension lead. Touch the plug end to your ground, and stick the spare wire into the socket end at your motor.
You could, though, charge the jar and then use it to run the motor...
Connect the the Earth (or "ground") instead. Use a longer wire and touch it to bare metal on a cold-water pipe. The container of water will charge up, but not allow that charge to flow away. When it is as charged as the TV, the static will stop flowing, and the motor will stop.
just in case you didnt know
:-D
