3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Be a Scientist: Bottle Electricity.
This is a quick-and-dirty method for making a Leyden Jar (an early form of capacitor) from my old friend, the 35mm film cannister.
Step 1Tools and materials.
Tools:
Something sharp.
Scissors.
Glue stick.
Materials:
35mm film cannister
Aluminium (kitchen) foil
Wire
Sticky tape
Optional:
Proper wire strippers.
310 comments
1-40 of 310next »
Apr 15, 2012. 10:09 PMchubawabu says:
Great instructable.
Mar 5, 2012. 5:34 PMTheBookworm says:
Quick tip: NEVER try to strip wires while your hands are covered in glue. You will end up making the wire so gluey that you cannot grab it, and your tools will be filthy. :)
By the way, GREAT Instructable
Jan 12, 2012. 9:24 PMHiggs Boson says:
So to charge it using the CRT you would just rub the wire connected to the inside foil on the screen? could you charge a leyden jar with a fly back transformer or would it have to be an electrostatic generator?
Jan 2, 2012. 7:39 PMfreeza36 says:
how else can i charge it?
Jan 3, 2012. 2:46 PMfreeza36 says:
ballons don't work for me. I have yet to try my old tv
May 20, 2011. 9:40 PMvishal11 says:
Wat ll charge it
Mar 25, 2011. 6:54 AMElectorials says:
nice tutorial!
it works perfectly ;)
Thanks!
Mar 13, 2011. 7:22 PMthink3000 says:
could you charge it with a plasma globe?
Apr 11, 2010. 6:14 AMlunchweek says:
Thank you, great instructable. I built two of these yesterday and they're working great!
Oct 7, 2008. 5:29 PMgeeklord says:
does a CRT monitor charge it very effectively???
Dec 11, 2008. 9:39 AMskuitarman says:
put tin foil on the front of the screen then brush the wires on the tin foil, but be careful you can get A pretty nasty shock
Apr 7, 2010. 8:45 AMbeehard44 says:
i'll revamp this leyden jar with that method but with a 1.5l soda bottle
Dec 11, 2008. 2:06 PMgeeklord says:
O, good idea. I thought about doing that with a plasma globe.
Dec 22, 2010. 11:36 AMfreakyqwerty says:
Did you try that method?
Dec 27, 2008. 2:09 AM2743 says:
BUT, what would happen if we hold the tin foil onfront of the crt tv screen with our bare hands?
Dec 5, 2008. 1:08 PMCoffee bean says:
this applies to tube tvs right?
Dec 5, 2008. 4:38 PMCoffee bean says:
thanks i was pretty sure.
Dec 27, 2009. 10:18 PMpocholox8 says:
could i use aluminum tape?(pls answer asap)
Nov 15, 2009. 9:45 AMyoyoyolilay says:
 wait, what source? do you just rub the wires together? or do the wires have to be connected to something?
Dec 12, 2009. 5:53 PMthe_burrito_master says:
get a pvc pipe and an old t-shirt rub the pipe over the top wire. it works much better than destroying your crt tv.
Mar 21, 2010. 11:05 AMNicOmbra says:
Jumper?
Nov 22, 2009. 12:46 AMAlphaRomeo says:
how about using a gas lighter - I suppose that it self is generating good are, isn't it
Sep 28, 2009. 12:51 AMAlphaRomeo says:
would it be better to use some rubber gloves or stand on some wooden platform to save oneself getting hurt?
Sep 29, 2009. 9:45 PMAlphaRomeo says:
I have been checking various high voltage instructables - can someone add safely measures that one should take - of if those are already explained - can we have the link please
Nov 19, 2009. 2:32 PMdroyce4596 says:
the biggest safety measure in my opinion would be don't let both of your hands touch a conductive material at the same time just in-case it has a charge in it. Because the most dangerous shock is from hand to hand because it goes across your heart which could potentially stop your heart.
1-40 of 310next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
831
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
