3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Be a Scientist: Bottle Electricity.
Step 3Connect the inside.
Connect the inside.
Poke a small hole in the middle of the film cannister lid.
Cut a piece of wire about 7-10cm long. Strip the ends and thread the wire through the lid.
Turn the inside end into a loop, then use a piece of tape to stick it to the foil inside the cannister. Slide the lid along the wire and put it on.
If you are planning to add the discharge loop, carefully scrape away 1-2cm of the insulation from the wire that will be just outside the lid. Give it a twist to make the loop. When you put the lid in place, push the wire back into the lid until the discharge loop is just at the lid.
2 comments
Mar 5, 2012. 5:34 PMTheBookworm says:
Quick tip: NEVER try to strip wires while your hands are covered in glue. You will end up making the wire so gluey that you cannot grab it, and your tools will be filthy. :)
By the way, GREAT Instructable
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
830
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
