3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Be a Scientist: Build an Electrostatic Motor
Step 4Making the Connections.
Cut two pieces of wire. They need to be long enough to reach your source of static electricity and your earth connection. If you are using balloons to generate the static, give enough clear air between the balloon end of the wire and the motor to prevent draughts from the balloon knocking the cup off its perch.
Position the wires so they stand each side of the cup. They should be about 1cm from the cup (they MUST NOT touch the rotor), pointing at the cup. Fasten the wire in place (how you do this depends on the nature of your base - blobs of blu-tac, drawing-pins, sticky tape, it does not really matter).
Your motor is now finished.
11 comments
Feb 18, 2010. 8:51 AMmagicmike5462 says:
where do i connect the earth to
Oct 10, 2009. 3:15 PMthierrywalt says:
Hi! How could I connect this generator (http://www.instructables.com/id/Kelvin_s-Thunderstorm---Create-lightning-from-wate/) to this motor? Could you give more details on how to connect it to a TV, like how long it should be on before connecting?
Thanks!
Oct 2, 2009. 1:48 AMimpedance214 says:
is there a need of magnet?/
Jun 29, 2009. 4:08 PMrobo_bob says:
can you use likea 9 volt
Jan 18, 2008. 9:47 PMJOEDUPONT says:
have you added plates to the wires and put the up close to the spinning device?
Nov 28, 2008. 6:32 PMchriskarr says:
Any electricity does for that matter. It's quite perturbing when making Tesla coils, because all of the high-voltage electricity shoots off into the air from any imperfection in your secondary coil or your top load.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
831
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
