3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Be a Scientist: Build an Electrostatic Motor
Step 5Running the Motor.
Connect one wire to connect to a good Earth point - any bare metal part of the home plumbing system is good. If all your water pipes are plastic, poke the wire into th cold-water tap and let it trickle slowly. For your own safety, do not connect the motor to any part of your mains electrical supply.
Now you need a source of static electricity:
If you are lucky enough to own a Van der Graff generator (or you have made your own!), that would be perfect. The earth wire can be connected to the bottom dome of the generator. Otherwise, anything that generates static will do. Inflate a long balloon, rub it on your sweater, and then gently stroke its length down the end of the wire not connected to the Earth. Repeat. Gather several friends, also with balloons, and take turns to add charge to the machine. Lay a sheet of aluminium foil over the screen of a TV or monitor that crackles a lot when you switch it on and off, and use wire to connect the foil to your motor. The more static you can supply, the faster your motor will run. We ran six motors simultaneously from my Van der Graff generator.
17 comments
Apr 6, 2011. 7:02 AMUgifer says:
This is great - thanks for the instructable.
I bought a cheap refurb Van de Graaff off e-bay and it arrived today. The thing is, the generator makes so much electrostatic wind that a plain plastic cup will turn in any case - no need for the foil!
I made my rotor using mylar film from a crisp-bag (chip-bag if you are American) and it seemed to work very well. Turned when the other end of the wire was about a foot from the VdeG. No need to actually contact the dome.
Apr 6, 2011. 10:53 AMUgifer says:
Nothing huge - dome is about 9". Makes maybe a 3" spark.
I think the friction on the cup is just so low that it turns with the slightest breath. Certainly you don't need to be anywhere near contacting the dome once its charged up to make it spin (that's the rotor with the mylar strips). It wil easily turn a plain cup by the wind it produces, but you need to contact the dome for that one.
Mar 11, 2010. 7:48 PMrrpo_10 says:
this is very hard i am electriacally shocked 5 times and still i can't make the rotor move....can you help me out??--- i use my tv and a foil and on the other part i use cold water with salt....yet it,s revolves but it is not continous....aarrgghhh this one is killing me!!!...pls help me guys
Oct 5, 2009. 1:16 AMimpedance214 says:
hey i try to used the tv as a source of static but it did not work.. do i need to cover large part of the screen to collect more static?
Jan 9, 2010. 9:21 AMbears0 says:
 it cant be plasma or flatscreen it has to be the big old tvs and the bigger the better
just in case you didnt know
:-D
Nov 13, 2009. 6:08 AMarihant says:
can it detect static in the air when thunderstorm comes?
Aug 11, 2009. 2:27 AMranzau says:
Hey do you think a high voltage transformer would work.(6-15KV@30-60mA) Thanks.
Jan 18, 2008. 9:48 PMJOEDUPONT says:
try running it from a kite with a long wire.. and no electrical wires around..
Jun 23, 2009. 9:07 AMcrockman1 says:
try putting a layer of aluminium foil on the top of the kite, make sure the kite is made from an insulating material. you can also use balloons to hoist the wire. the higher the kite is the better. Tesla calls this his free energy machine i think.
May 30, 2009. 1:32 AMDerin says:
Oh no............ 1.21
Mar 14, 2009. 4:16 PMslipknot rules says:
try connecting it to a flyback transformer
Apr 30, 2009. 6:53 AMtesla coil says:
that would work real nice
May 16, 2009. 2:12 PMslipknot rules says:
or if u connected a 'fly zapper' circuit to the flyback with a spark gap, that produces high voltage, but not enough current to kill you...about 20,000v at 4 or so mA.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
830
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
