3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Be an Aeronautical Scientist: Make your Own Jet Engine for a few Pennies.
Step 4Getting it right.
Getting it right.
People that do this properly use proper tools, but it is possible to get it right with just a hammer and an inappropriate spiky thing.
If your fuel is meths (recommended), and you're using a pasta sauce jar, then the hole needs to be about 10-12mm across.
When I prepared a new jet, with a roughly circular hole about 10mm across, it nearly worked. It lit, went foosh and then RRR for a second.
A couple of minutes prodding at the edges of the hole with a screwdriver made the hole about 11mm across, and it ran well. Really well.
But I forgot to video it!
Never mind, I put the flame out and let the jar cool for a few minutes, then tried again. Yipee! It worked!
39 comments
Nov 20, 2010. 7:45 AMandy55551 says:
is there a way so it doesn't brake at the end?
Feb 21, 2012. 12:05 PMskatattookid says:
i keep mine water cooled and also wrapped the glass in duct tape so if it does break its easy to clean up without getting cut. you can also just drill a hole in a can of broth and just use that.
May 7, 2012. 3:12 AMBrianRandleas says:
That was my thought on using a metal can as well. A beer can or soda can pierced from the bottom instead of "Popping the top" should work as well. If you can find a way to pull the bottom into a cone shape that should also give better results if your wanting even negligible thrust. If you are using a metal canister you should also be able to lay it on it's side. More important than the shape of the flame is the air to fuel mixture you are obtaining.
Oct 22, 2011. 5:55 PMorangetj says:
or possibly have a undamaged lid freeze the jar with the meths inside and then swap lids? but then again it might get hot fast and break sooner
Sep 12, 2011. 7:07 PMELITE-01 says:
I haven't tried this specifically,
but just as a reference to something I have done, unintentionally,
Rap a jar containing a candle in a cold, wet rag. The glass breaks pretty quickly, large cracks, some shattering, the works. so i'd assume that cold liquids, of any kind, with hot glass is a no go.
Aug 14, 2011. 3:54 PMAldeas says:
Have you looked up the heller/lockwood version of the valveless pulsejet? That version uses a u shaped arrangement of the tube with and expanded combustion chamber to set up the harmaonic combustion pulse. one guy ran a gocart on one of these things using propane as a fuel.
Dec 24, 2011. 10:08 AMBitBoink says:
Ya I remember SRL (Survival Research Laboratories) did a pulse cart back in the 90's. The pipe was glowing bright orange-hot right behind his head if I my memory serves well ... was insane looking!
Apr 27, 2012. 5:17 PMZaphod Beetlebrox says:
I wonder if it work with a pop can. Or would the hole be to big.
Apr 28, 2012. 11:27 AMZaphod Beetlebrox says:
Thanks. saved me some experimenting. If I get one working I'll post a pic.
Jan 13, 2009. 3:56 PMsceincedude11 says:
were do you get meth
Feb 21, 2012. 1:34 PMsomebody12345 says:
From a drug convention! (just kidding)
Mar 12, 2009. 5:47 PMfranklinonline says:
ask the police and youl be in jail because they think you mean methathetimene
Feb 3, 2009. 11:28 PMthe_mad_man says:
I've never seen purple metho before. the only metho I've ever seen is clear
Feb 5, 2009. 12:36 AMthe_mad_man says:
makes sense, i think petrol is purple as well
Feb 6, 2009. 8:57 PMthe_mad_man says:
confusing
Jul 22, 2011. 5:59 AMmgfsniper says:
How much Methylated spirits do you add to the jar???
Oct 13, 2011. 2:10 PMmmv5004 says:
Since you are only burning the vapors that escape from the hole, all you need is enough to coat the sides; then you can dump the rest out.
Jul 22, 2011. 7:16 AMmgfsniper says:
ok thanks
Oct 8, 2011. 7:05 PMyamahayzfr1extreme says:
cant we make it move???? i mean add tiers and place the bottle horizontally so that it moves in front...................
Oct 13, 2011. 2:08 PMmmv5004 says:
You can do this trick with plastic bottles too. Anything from little 500ml bottles up to 5 gallon water cooler bottles. They are much lighter so if you lay them on their side they can really get moving, but if you stand them up the heat will eventually melt them.
I had a chemistry teacher back in high school who used to do this a bunch; I should write an instructable building on this...
Aug 3, 2011. 1:05 PMfirepup104 says:
Whats fun is putting a ton of fuse and firecrackers in a jar then lighting it off
Jul 13, 2011. 7:31 PMiac says:
I F***ing love church bells going of in the background !'
Not quite Hallaluya (sp?), but it'll do..
Feb 27, 2007. 6:26 PMcowscankill says:
is there anything else besides meth you could use? and whatis meth? that illegil drug in america?
Jul 1, 2011. 9:12 PMHightechk says:
Lol I thought the same thing
Feb 27, 2007. 7:06 PMPink_wolfie says:
¬_¬ Metholated Spirits, not Methadone...
Apr 10, 2011. 6:02 PMjuanjomf says:
In Uruguay is blue alcohol.
are sold in gas stations where gasoline throw your car if you have questions.
Jun 9, 2007. 7:46 PMNachoMahma says:
. Is that the same stuff we call Denatured Alcohol here in the Colonies? I think it's mainly ethyl alcohol (ethanol) with some methyl alcohol (methanol) mixed in to make you go blind if you drink it.
Jul 15, 2011. 10:45 PMlukeyj15 says:
Methlyated spirits is an undrinkable alcohol. So denatured alcohol will work as will anything with an alcohol content of 70+% or so.
Jul 15, 2011. 6:20 PMcaarntedd says:
Our's is clear down here. I've tried to drink it out of curiosity (wondered what it tasted like). Not good. I knew it was harmful, but a figured a sip wouldn't kill me. I just had to know. It's a bit like putting a tea pot cosy on your head. Eventually, when you think no one is watching, you just have to try it on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
830
Author:Kiteman(The Complete Kiteman Shop)
"Happiness is a shed full of power tools." If you need help around the site, or with a project, feel free to contact me.
