I think this project is very cool and has nearly countless applications!! We are going to be setting up our own single board, fanless computer using the beaglebone. We will setup a mini SD card so that we can boot Ubuntu onto the beaglebone, we will setup a a lightweight GUI (graphical user interface - a desktop environment vs terminal) and just for kicks we will install the arduino programming environment.
Even though this board is heavy on linux, I included this in the microcontroller section in the hopes of more arduino fans giving this board a whirl..,
I chose ubuntu because there is already an existing image to format your sd card. Also, I have been running ubuntu on my laptop to program arduino, so it seems natural that you would try and match the os from your board and your computer.
I do not know if this instructable is really tailored to any one specific project. However, it should really get you going. I do not know much about javascript or web hosting, but this feels like the perfect time to learn. Maybe later I will set up some kind of VPN connection so that I can control and monitor any project from anywhere with internet access...
I would recommend joining the group "beagleboard" on google groups. The beagleboard is much more complicated than an 8bit microcontroller.
https://groups.google.com/forum/?fromgroups#!forum/beagleboard
This instructable is basically an editorialized repost from the linux website: http://elinux.org/BeagleBoardUbuntu
If you have any knowledge or interest with linux, or beagleboard, please sign up and contribute to the beaglebone group on instructables. There is a lot to do here folks!! http://www.instructables.com/group/beaglebone/
At the end I have included how to set up a lightweight GUI so that you can SSH in from your laptop and set up a "virtual desktop." I also show how to install and run the arduino IDE so that you can use the beaglebone to program any arduino NOTE: I HAVE NOT CONFIGURED A DEDICATED SCREEN OR A KEYBOARD TO THE BEAGLEBONE. I JUST WANT TO ILLUSTRATE THAT THE PROCESSING POWER OF THIS BOARD IS MUCH CLOSER TO A COMPUTER THAN TO AN ARDUINO.
A good next step would be to figure out the HDMI cape so that you can run the LXDE desktop on any hdmi monitor.
Remove these ads by
Signing UpStep 1: Download the Disk Image
If you are already running ubuntu on your computer, these next steps ~should~ be very easy. Get ready to copy and paste!
Make sure you are uploading the most recent release
From your computer terminal:
$ wget http://rcn-ee.net/deb/rootfs/precise/ubuntu-12.04-r5-minimal-armhf-2012-07-29.tar.xz
$ wget http://ynezz.ibawizard.net/beagleboard/precise/ubuntu-12.04-r5-minimal-armhf-2012-07-29.tar.xz
This will download the disc image for your SD card straight to your computer. If you are running something other than Ubuntu, the links following the wget command will dowload the image to your computer also.
To verify that the images have downloaded correctly:
$ md5sum ubuntu-12.04-r5-minimal-armhf-2012-07-29.tar.xz
This should return:
5446d6e47a5d286f94ae3fa30db2a56b ubuntu-12.04-r5-minimal-armhf-2012-07-29.tar.xz
Visit Our Store »
Go Pro Today »
run ssh again, only this time
$ sudo ssh -v root@your_ip_address
and post the results here
I suspect that you have not copied the private key into your .ssh/authorized_keys file on your laptop (assuming its running ubuntu)
Pros
1)Beaglebone is smaller (fits into an altoid tin)
2)Beaglebone's processor is better
3) There are a lot of promising externals for the beaglebone - primarily the touch screen.
4)Beaglebone has an arduino style IO panel
Cons
1)Beaglebone is more expensive -costs $80-90, raspi is about $30
2) Raspi already has an hdmi output - I bought a hdmi cape for the bone but still have not got it working - although normal beagleboard has the hdmi output and more usb hubs
