Beatiful Wall Guitar Hanger
11,882
105
4
Published
Introduction: Beatiful Wall Guitar Hanger
In past days i have adquire my last guitar, an acoustic (second hand)
and in net to put it in place close to my other electric guitars
this is the Idea.
Step 1: Supplies
Materials
- 1 Hanger (tool hanger)
- Old Photo Frame 4" x 6" (i used from my exgrilfriend)
- Wall Plug
Tools
- Tweezer
- Drill
Step 2: Process A
1. Disassembly the Flame (remove the glass)
2. Remove the back support using the tweezer
3. Blend the insert close to the surface
4. Press with brutus force the hanger to fit in the high holes in your guitar headstock
Step 3: Process B
put in place all togeter and drill a hole in your desire position
Step 4: Process C
- Plan the site
- Dill a hole in your wall
- Mount
Step 5: At the End
Final product!!!
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    4 Comments
    I see you have a BC Rich Warlock, I have the same guitar and also a Warlock Bass. Thanks for this 'ible. Nice job!
    a question: what's holding the other guitars? commons supports?
    Just curious, does hanging the guitar only by the neck (without any lower support) cause it to lose its tuning quicker? I would expect that the weight of the body pulling down would have some effect upon the strings though don't know if it would be a noticeable difference than normal tuning loss. Thanks.
    I'm in no way an expert, but I expect it to not matter.
    The weight of the guitar hangs mainly on the neck itself like this, not the strings.
    I doubt any extra force is applied to the strings at all unless the neck is weak enough to bend under the weight of the guitar (in which case you probably have a bad guitar anyway ;))
