3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Beating Heart
Beating Heart
I made this good looking beating heart (.. Accidently invented near the valentines day. ;)).The device has 20 LED`S that blink at a hardware specified rate. Unlike the conventional approach of using micro-controllers i though using a simple 555 Timer would be great ..adding to it ..it would simplify the design and make it less cuber-some for those who either have no prior knowledge or dont want to waste time gathering the same.
Here`s the thing you might get after going thru the rest of the instructable.
Step 1Getting the supplies
Things that are required:
1 x NE555 Timer
2 x 10k Resistances
1 x 100uF Electrolytic Capacitor (25V)
1 x 10uF Electrolytic Capacitor (25V)
1 x 9V Battery / 3 x CR2032 Li-ion
1 x Through hole board
1 x 9V Battery connector
1 x  IC Base (8 pin)
1 x  Push Switch ( to avoid ur heart beats in front of everyone:D)
20 x  "identical" Red LED ( Identical is the catch in here.. as if they are sourced differently u might end up having uneven brightness..which will be disappointing)
Wires as required..( it goes to like " Salt to taste")\
And lastly  "Spare Time"
Other Things that might be available at hobbyists are:
soldering Iron, Solder, Flux, Tweezers, wire cutters, Helping Hands ( Clamp tool)and hot glue gun.
2 comments
Mar 12, 2012. 2:25 AMcc67 says:
I guess a 555 timer Ic is the most awesome IC ever invented. I will make this
Feb 12, 2012. 12:41 PMRobot Lover says:
This is cool. If you want to get a better heartbeat, make this circuit instead. It is supposed to be like a bomb but if you substitute the LEDs for the speaker, it will look much cooler.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:indiantinker(Indian Tinker)
Im a freelance electronics designer who loves to do photography and spends the day working for his college Solar Car Team apart from studying the B.Tech course in Electrical Engineering.
