Introduction: Beats by Andrew's P1
Picture of Beats by Andrew's P1
In this Instructable we will show you how to make a headphone at home.
Step 1: Grab the Materials
Picture of Grab the Materials
Go and find all the materials
Materials:
We chose a Plastic cup so it can be the base of the headphone where the sound will come out.
We chose the Electrical tape because it can produce to conduct electricity throughout the wire.
Alligator clips can be optional
Aux cord is to connector it to your phone then connect your wire to the Aux Cord to here sound coming out
Magnets are used to be placed in the middle of the wires and produce magnesium to so the sound can travel.
Glue stick was used as a base to wrap around the coil
Wire (28 gauge)was the amount to be able to here sound.
Wire cutters/ Scissors was to cut any wire sticking out
Sand paper was to sand the end of the wire to connect them together.
Step 2: Wire
Get a piece of 28 gauge wire
Step 3: Wire Continue
Measure wire
Step 4: Glue Stick
Picture of Glue Stick
Wrap wire around the glue stick to make the coil
Step 5: Sand Paper
Picture of Sand Paper
Sand both ends of wire, rotate all sides to make sure everything is sanded correctly(1 inch)
Step 6: Magnets
Picture of Magnets
Place one magnet on bottom of cup, then the other one from the other end
Step 7: Cup
Picture of Cup
7: Turn cup upside down place magnet in the middle then the wire goes around the magnet, then put electrical tape to hold it down.
Step 8: Alligator Clips
Picture of Alligator Clips
Connect alligator clips to ends of sanded wire
Step 9: Aux Cord
Picture of Aux Cord
Connect aux cord to sanded wire
Step 10: Phone
Picture of Phone
Play Song
Step 11: Recording
Record Data
Step 12: Repeat
Do this for each Coil
Step 13: Troubleshoot
If for some reason you cannot hear sound try re-doing the wire but with more coil so the sound with be louder, make sure you connect it the aux correctly and that the positive and negative are not touching, no opening make sure all of is into once circuit.
Step 14: 3 MAIN COMPONENTS OF THE SPEAKER
Three main components for the speaker is the AUX Cord because without no sound will be heard,the wire is important because without it theirs no sound traveling thought them and the electrical tape is important because it help conduct electricity on the wire. The voice coils vibrate because wavelengths pass through them and if there big it begins to vibrate like an earthquake if its small it people do not feel it but when is big then yeah the ground shakes hard. When the wavelength is hard the vibration turns into sound because the wavelength has sound and when its strong enough the vibration turns into sound. We tested 3 different types of coil and the loudest one was 25 and the lowest was 15 we couldn't here much in 15 but when we add 10 more then it makes a difference in sound quality.
DIY Hacks and How Tos (author)2016-03-03
Fun project. Very well done.
About This Instructable
155views
0favorites
License:
More by Andrewm2410:Beats by Andrew's P1
Add instructable to:
