Step 9The Red Wall in Place
Next is the red wall, the darkest part being the top. You can go ahead and glue down the leaf molding on top of the wall's bottom edge. Above this add the extra molding you cut off the top molding picture (just the straight lines and dentils). Give the whole section a neat layer of the glue. TIPS: Work quickly and be very careful to line up the corners perfectly while the Mod Podge is still quite wet. Lay down glue only for the piece you are gluing. Wipe off glue outside the area with a damp towel because dried bits of glue will produce lumps. Clean dried glue off your fingertips before picking up the next piece to lay down. Dried stuff can stick hard to the paper, and tear it trying to pull your fingers away.
Add Comment
