another laptop case? Yes - wen I make my firs Instructable this idea come in my mind. Fist is a very cheap and simple case, how everybody can make, but I don`t put accent to design
This is a more elaborate design solution, but I maintains green materials (98%) for a cheap and ecological solution.
Probable, at this dimension, can fit 2 OLPC, but I make for an 15,4" laptop (I don`t have one OLPC to measure and try) .
Is a perfect case for any laptop: low cost, shock-absorption, relatively easy to make, reusable, biodegradable, and have a beautiful design
RO version:
Buna,
alta carcasa de laptop? Da, ideea mi-a venit cand am facut prima carcasa, pe care am incercat sa o fac cat mai simpla si ieftina, astfel incat sa si-o poata permite oricine, sau sa o poata prelua o fabrica care sa o faca pentru laptopurile ieftine gen OLPC.
Noua versiune este cu un design mai elaborat, dar am incercat sa mentin utilizarea de materiale ecologice (98% - are 8 suruburi de metal), si sa obtin un produs ieftin si relativ usor de realizat.
Probabil, ca la dimensiunile la care am facut eu geanta (testat cu un HP de 15.4"), incap 2 OLPC-uri, dar n-am avut un OLPC ca sa-l masor :)
Consider ca este o geanta foarta buna pentru un laptop (totusi perfectabila): pret mic, foarte buna protectie la socuri, relativ usor de realizat, din materiale reciclabile, si (zic eu) cu un design deosebit.
Remove these ads by
Signing UpStep 1
After this be sure you have all materials and tools:
- 1 piece of 3,5mm corrugated cardboard (1600x560mm), or more small pieces , but quite hight to not cut components'
- 2 piece of 6mm corrugated cardboard (1600x560mm), or more small pieces ... - " -
- 1 piece of 3mm plywood (70x48mm)
- 1 piece of hemp tape (1500x60mm)
- 8 screws (4x80mm)
- cutter (if you have patience and time ), or a laser cut machine (eeeeee..... wonderful Epilog ;) )
- wood/paper glue, transparent after dry,
- boring mill and 3,5mm wimble/drill
- drafting ruler
- pencil
And, of corse .... passion.
All my images is before dry glue - I hurried to participate to contest :)
RO version:
Pentru inceput am facut schita (in Inkscape - este un program gratuit), si in aceasta faza puteti face si eventualele modificari de forma, sau adauga diverse accesorii (locasuri pentru memorystick, tel mobil, etc.) - eu i-am facut un "buzunar" pentru alimentator si mini-tastatura numerica..
Inainte de a va apuca de treaba, asigurativa ca aveti toate materialele si sculele necesare:
- 1 bucata carton ondulat de 3,5mm grosime (1600x560mm), sau bucati mai mici, dar in care sa incapa piesele de decupat,
- 2 bucati de carton ondulat de 6mm grosime (1600x560mm), sau bucati mai mici ... - " -
- 1 bucata de placaj sau placa lemn groasa de 3mm (70x48mm) - pentru balamale si prinderea panglicii suport,
- 1 bucata panglica canepa (1500x60mm)~- am gasit in magazinele de bricolaj,
- 8 suruburi (4x80mm), la 2 se vor taia capetele (pt. balamale)
- cutter (daca averi rabdare si timp) , sau un echipament laser (eeee... ce bun ar fi un Epilog ;) )
- clei de hartie/lemn, care devine transparent dupa uscare
- masina de gaurit si burghiu de 3,5mm
- rigla, creion, radiera
Si bineinteles - multa pasiune si placerea de a face asa ceva.
Imaginile puse de mine sunt inainte de a se usca cleiul - intre timp a devenit transparent :) - m-am grabit sa-l inscriu in concurs.
If you read even paragraph 3, from my Intro, you find the answer.
About me: I change 2 desktop & CRT monitor from home and office (big energy consumer) with one laptop - is first step. Ooo.. and I like my bike :)
Offtopic: for HP Eco Solution please read this website: http://www.hp.com/hpinfo/globalcitizenship/environment/
My ideea is to use for cheap laptop for kids (like OLPC), only summer (or in equator country - he wish to rain sometimes).
Other users - opposite pole - is people who like design, ant want to be admired for original design :)
I response to andreiad: Is not a "rain case" but is possible to cover with ecological plastic foil when rain.
Is not problem to repeat hold up , but I sugest to put 3-4 hinge, not only 2; for long term use.
Now I use to carry a HP DV5 (2.7Kg) and is very easy to use. (And for girls is like a Ferrari : Oauuuuu.... is a new Gucci bag? I wannnttttt.....:) )
Thats the guy, he was featured on make and a few other blogs about a week or 2 back, so i _assumed_ you had seen it there! Be sure to check his out, there is all sorts that he has made using the same technique.
Some guy sell one case like this, with 180 BP :) - in this case is a luxury product.
