Introduction: Beautiful and Practical Clock With Calendar
Use I2C_LCD to make a beautiful and practical clock with calendar.
I2C_LCD can display bitmap, graphic and character, you can make beautiful UI for your project with I2C_LCD.
I'm sure you'll be interested in this work.
Materials have to be prepared:
I2C_LCD(With Female Jumper Cable) x1
I2C_LCD(With universal Grove cable) x1
Seeeduino Lotus - ATMega328 Board with Grove Interface x1
Grove - RTC x1
Grove - Universal 4 Pin 20cm Unbuckled Cable (5 PCs Pack) x1
Step 1: Install the Arduino Library for I2C_LCD.
You can download the library from here: I2C_LCD Library
How to install the library? For more informations? please refer to the WIKI page.
More exciting features please refer to the User Manual.
Step 2: Install the Arduino Library for Grove-RTC.
Step 3: Connection.
Connect the I2C_LCD and Grove-RTC to your Arduino board, here we use Seeeduino Lotus.
I2C_LCD and Grove-RTC are I2C interface module, so we connect them to the I2C bus.
Step 4: Coding.
1. Download the arduino demo project (clockWithCalendar.rar) to your computer.
2. Open the project by Arduino IDE, and then upload the program to your board.
The main code is shown below.
<p>#include <Wire.h></p><p>#include <I2C_LCD.h></p><p>#include "DS1307.h"</p><p>//For detials of the function useage, please refer to "I2C_LCD User Manual".
//You can download the "I2C_LCD User Manual" from I2C_LCD WIKI page:
// http://www.seeedstudio.com/wiki/I2C_LCD</p><p>I2C_LCD LCD; //define a object of I2C_LCD class
uint8_t I2C_LCD_ADDRESS = 0x51; //Device address configuration, the default value is 0x51.</p><p>extern GUI_Bitmap_t bmClock; //Declare bitmap data packet.</p><p>char monthTab[13][6] = {"Null","Jan.,","Feb.,", "Mar.,", "Apr.,", "May,", "Jun.,", "Jul.,",
"Aug.,", "Sep.,", "Oct.,", "Nov.,", "Dec.,"};
char weekTab[8][10] = {"Null","Mon.,","Tues.,", "Wed.,", "Thur.,", "Fri.,", "Sat.,", "Sun.,"};
char dayTab[32][6] = {"Null","1st,","2nd,", "3rd,", "4th,", "5th,",
"6th,", "7th,", "8th,", "9th,", "10th,",
"11th,", "12th,", "13th,", "14th,", "15th,",
"16th,", "17th,", "18th,", "19th,", "20th,",
"21th,", "22nd,", "23rd,", "24th,", "25th,",
"26th,", "27th,", "28th,", "29th,", "30th,", "31st,"};</p><p>char timeTab[10] = {"00:00:00"};</p><p>DS1307 clock; //define a object of DS1307 class</p><p>void setup()
Wire.begin(); //I2C controller initialization.
clock.begin(); //RTC initialization.
clock.fillByYMD(2015,07,31); //Jul 31,2015
clock.fillByHMS(21,20,30); //21:20:30"
clock.fillDayOfWeek(FRI); //Friday
clock.setTime(); //Write time to the RTC chip.
}</p><p>void loop()
LCD.CleanAll(WHITE); //Clean the screen with black or white.</p><p> //Booting logo ON, backlight ON, bitmap work mode.
//If you want to display characters please switch to WM_CharMode.
LCD.WorkingModeConf(ON, ON, WM_BitmapMode);</p><p> //Display bitmap at the specified location.
//Prototype: void DrawScreenAreaAt(GUI_Bitmap_t *bitmap, uint8_t x, uint8_t y)
LCD.DrawScreenAreaAt(&bmClock, 4, 3);</p><p> //Draw a rectangle, and filled with black;
//Prototype: void DrawRectangleAt(x, y, width, height, mode);
LCD.DrawRectangleAt(0, 0, 128, 5, BLACK_FILL);
LCD.DrawRectangleAt(0, 59, 128, 5, BLACK_FILL);
//Booting logo ON, backlight ON, character work mode.
LCD.WorkingModeConf(ON, ON, WM_CharMode);</p><p> while(1)
//Update the date and time.
clock.getTime();</p><p> //Set font size.
LCD.FontModeConf(Font_6x8, FM_ANL_AAA, BLACK_BAC);
//Set the start coordinate.
LCD.CharGotoXY(5,10);
//Date format: Fri.,24st,Jul.,2015
LCD.print(weekTab[clock.dayOfWeek]);
LCD.print(dayTab[clock.dayOfMonth]);
LCD.print(monthTab[clock.month]);
LCD.print(clock.year+2000);
//Set font size.
LCD.FontModeConf(Font_10x20, FM_ANL_AAA, BLACK_BAC);
LCD.CharGotoXY(40,32);
//Time format: 00:00:00
snprintf(timeTab, 9, "%02d:%02d:%02d", clock.hour, clock.minute, clock.second);
LCD.print(timeTab);
delay(1000);
}</p>Attachments
Step 5: Enjoy Yourself.
Thanks for your time.
