Beauty Table From Old Sewing Machine / Mesa De Belleza Con Vieja Maquina De Coser
Published
Introduction: Beauty Table From Old Sewing Machine / Mesa De Belleza Con Vieja Maquina De Coser
One day I woke up thinking that I was close to celebrate my 4th wedding anniversary so I started a hard task... thinking of a present for my wife. LOL! fortunately, few days before we found an old structure from an antique sewing machine and my wife thought it good be good to recycle it and add a piece of glass of 10mm to make a table.
Searching on the web for possible ideas of colors and stuff I found this beautiful idea for her anniversary present.... a BEAUTY TABLE!!!!! Something to have all her make-up and beauty devices all together in the same place... PLUS I can have the toilet neat and the mirror free!!!!! LOL!
Un día me desperté pensando que pronto celebraria mi 4º aniversario de casado y comencé uns dificil tarea... pensar en que regalarle a mi esposa. jaja! Por suerte, unos dias antes encontramos con ella unas viejas patas de una maquina de coser antigua y mi esposa que sería muy lindo recuperarla y ponerles un vidrio grueso encima para hacer una mesa.
Buscando en internet posibles combinaciones de colores para mi mesa encontré una hermosa idea para regalarle a mi mujer... UNA MESA DE BELLEZA!!!!! Algo donde poder tener todos sus maquillajes, esmaltes y artefactos juntos en un solo lugar... Y ENCIMA yo puedo tener el antebaño ordenado y el espejo libre!!! JAJA!
Step 1: Dissembling and Sanding the Sewing Machine /desarme Y Arenado/lijado De La Maquina
I decided to paint the metal parts in aluminum color, and the wooden parts in white. As you may know, whenever you want to re-pain something, you need to sand it, take all the rust and old paint away, and leave the surfaces as clean as possible.
I have no pics of the machine from the time I bought it, but the metal frame was rusty and the original paint was damaged. So I was planning to clean it myself and bought a brush to be used with a grinder. After 20 minutes of working on the legs and checking on the results, and after calling to some places asking for the cost of sanding, I decided that taking the metal pieces to an industrial sander would be a great Idea… totally inexpensive compared to the hard work and time It would have meant to make it myself.
So It was time to start with the wooden parts. Dissembling each part made sanding way easier. As you can see in the 2nd, the top layer of the wood was a bit damaged, so once it was separated and completely sanded I used some plaster to fill the little gaps open between the wood fibers and cover all kind of imperfections the old wood might have had (have no pics of it either). Once the plaster was completely dry, I sanded again to leave the surface as smooth as possible.
Note that the top cover originaly opened to the side, so, as I need it to open to the back I changed the position of the hinges.
Decidí pintar las partes metálicas en color aluminio y las de madera en blanco. como ya saben cuando quieren re-pintar algo, debemos lijarlo y limpiarlo de toda suciedad de enrumbre y pinturas viejas lo mas posible.
No tengo fotos de cuando compré la maquina pero la esttructura metalica estaba enrumbrada y la pintura dañada. compré un cepillo metalico para usar con la amoladora y luego de 20 minutos de trabajo y ver los resultados, y luego de llamar a un par de empresas, decidí llevar las patas directamente a una casa de arenados industriales donde por un bajo costo, me salvé de el duro y largo trabajo de cepillado.
Ya trabajando sobre la madera, desensamblé todas las piezas para que sea mas facil lijarlas. como se puede ver en la 2º foto, el laminado de arriba de la tapa estaba dañado asi que usé un poco de masilla de yeso para cubrir las grietas de entre las fibras de la madera vieja. una vez seco, lijé toda la masilla para dejarlo lo mas liso y parejo posible.
Fijense que originalmente la tapa abría hacia un costado por ende, como yo necesitaba que abriera hacia atras, tuve que cambiar la posición de las bisagras.
Step 2: Painting and Decorating
After cleaning all the dust from sanding off the surfaces, I started painting all the parts. For the metal parts (legs and hinges) I used a 3 in 1 synthetic enamel, a kind of paint that is anti-rust, anti-corrosive and sealer. I chose aluminum color to make it look natural, but I’m not so pleased with the result, I may change it… perhaps. LOL!
For the wood, I chose white synthetic enamel in spray since I’m not so good with paint brushes LOL! Using brushes reduce the cost of paints like in +75 %. A tin of paint costs $35 +$15 the brush total $50, while I spent $220 in 3 large sprays (2 is ok if you are an expert spray painter LOL).
After finishing the painting, I wanted to make look different... the all-white thing wasn’t good to me, so I search on the internet for DECOUPAGE, a technique used to paste patterned napkins on surfaces to give them a better look. Check on this video to get to know about this technique. https://www.youtube.com/watch?v=qKlm0QAMk5w.
I am totally pleased with the final result. I decorated the visible sides of the drawers, and the inner side of the top where the mirror will be fixed.
Despues de limpiar y sacar todo el polvo del lijado, comencé a pintar las piezas. Para las partes metálicas compré un esmalte sintético 3 en 1, anti-corrosivo, anti-oxido, y sellador. elegí color aluminio para mantener el color metálico pero no estoy muy contento con el resultado... asi que seguramente lo cambie... ALGUN DIA jajajajaj!!!!
Para la madera usé esmalte sintético blanco ya que no soy muy bueno usando pinceles. usar pincel reduciria los gastos de pintura en un 75% aprox. una lata de 250cm3 cuesta $35 y el pincel $15, total $50, mientras que yo me gasté $220 en 3 latas grandes de pintura en spray. (con 2 latas está bien si eres un experto usando pintura en spray)
Despues de tener todo pintado, quise darle un toque diferente... la cosa toda blanca no me convencia asi que entré a internet a ver algo de decoupage, una tecnica que consta de pegar servilletas de papel en cosas para mejorar su vista. vean el link de arriba para saber de que se trata.
Estoy muy contento con el resultado final. decoré las partes visibles de los cajones y solo la parte interior de la tapa donde quedó puesto el vidrio.
Step 3: Assembling and Finishing the Work.
After everything was painted, decorated and ready, I have some pro fixing the mirror on the top cover. For that they used neutral silicone, but I also ask them to fix some metal supports on each side on the mirror since the top will suffer constant movement (open-close) and I don’t want my wife to be injured by a loose mirror… yet! LOL!
Then I screwed back all hinges, fix the top cover hinges in their new position, and…
TAH DAH!!!!
A BEAUTY TABLE for my wife to have all her beauty stuff in place. As you can see in the last picture, the paint sprays are still inside the table in order for you see how big it is to hold the curling iron, flat iron, brushes, make-up bags, cream pots and all her beauty at hand LOL!!!!!!
Hope you like my instructable and find it useful for renewing furniture and impressing your women!!
See you on my next instructabe.
Despues de tener todo pintado, decorado y listo, unos profesionales pusieron el espejo en la tapa del mueble. Para eso usaron silicona neutra, pero tambien les pedí que le pusieran unos soportes de metal en cada costado del espejo ya que la tapa va a tener mucho movimiento de abrir y cerrar, y no quiero que mi esposa termine herida por un espejo suelto..... todavía ! JAJAJA!
Luego pusé las bisagras en su lugar con sus tapas, acomodé la tapa en su nueva posición y...
LISTO!!!!!
UNA HERMOSA MESA DE BELLEZA para mi esposa para tener todo su equipo de belleza ordenado. Como pueden ver en la ultima foto, los sprays de pintura todavia están dentro de la mesa para qque puedan ver el tamaño de la misma, lo suficientemente grande para guardar la planchita del pelo, la bucleadora, cepillos, bolsos de maquillaje, potes de crema, y toda su belleza a mano, jajaja!!
Espero les guste el INSTRUCTABLE y lo encuentren util para renovar muebles viejos e impresionar a sus mujeres!
Nos vemos en mi proximo INSTRUCTABLE!
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    5 Comments
    I've always been a fan of the old sewing machine stands, and love it when people think outside the box. Good hubby! Great result! Thanks for sharing your vision and gift to your wife.
    Thank you, i have anither stand waiting for a hard thick glass to end up as a tv table!
    Oh! That would be fantastic! You home must be so interesting!
    That turned out looking great! Thanks for sharing and welcome to the community!
