- When dealing with superglue, make sure you do not get any on yourself if you are wearing cotton clothing. Superglue reacts with cotton, and it will burn! This will also cause the burning cotton article to stick to your skin... nasty.
- Generally, try not to glue yourself to yourself... If this happens, acetone (commonly found in nail polish remover) is a good solvent.
- Make sure not to inhale the fumes, which can be pretty toxic. Fume in a well ventilated area.
_ Make sure to use a low-level heat source, such as the coffee plate warmer I have used in the video. Using a hot plate instead can cause the superglue to catch fire, thus releasing poisonous gases.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
This is completely incorrect. Regular Super Glue will release these fumes in quantity at 200 degrees Fahrenheit.
That really depends on the type of glue used (there's quite a few different formulations). Super Glue/Krazy Glue are methyl-2-cyanoacrylate, and their flash points are above 100F but never above 200F. It's structure is not as stable and will gas before other formulations.
2-octyl cyanoacrylate is what you'll find for more professional uses (wood work, hospitals, etc.). It has stronger molecular bonds -- so it doesn't decompose/cure as quickly (but it's still pretty fast), this makes it a little more heat resistant before it's been cured. After it's cured, its bond is a bit stronger and more durable. It's likely this is what you're using, unless you're using branded super glue or krazy glue or some other base consumer product.
Yeah... did you read my first three sentences? I didn't think so....
