Bedazzler: DIY non-lethal weaponry
 by adafruit
Contest WinnerFeatured
Our first open source Homeland Security non-lethal weapon project - The "THE BEDAZZLER: A Do-it-yourself Handheld LED-Incapacitator".
After attending a conference where the $1 million "sea-sick flashlight" (named "THE DAZZLER") was demonstrated by the US Dept. of Homeland Security, we decided to create our own version. For under $250, you can build your own dazzler and we've released the source code, schematics and PCB files to make it easy. A great Arduino project for people who really like blinking LEDs. We also added in a mode selection so you can put it into some pretty color-swirl modes, great for raves and parties!
Yes this project does indeed cause: Nausea, dizziness, headache, flashblindness, eye pain and (occasional?) vomiting! So don't use it on your friends or pets.
Please note: This is not a kit, nor for sale...so don't ask us. All documentation is on the design and download pages.
Mad props to Scott Johnston for LED assistance. Sk0t r0x!
Step 1: Introduction
This project isn't a kit (and won't ever be) so the instructions are more laissez-faire, with many opportunities for the maker to change elements or modify the design. Take it more as a guideline (and use common sense) than a rigorous step-by-step!
Parts list
To make this project you'll need:
  • 36 or 37 1+ Watt LEDs. there are 2 Watt LEDs that are now easily available. For color versatility you can use 12 each of red green and blue. Or you can go with 18 each of green/blue for more effective dazzling. These range around $3 each. Look on eBay or other closeouts to get slightly-older LEDs for less. We used some older Cree XLamp XR-E 7090
  • You'll also need lenses/optics for each LED. Go with narrow-beam lenses, about 20mm diameter. 6 or 5 degree will be most effective. (Like this, but make sure you get ones that match your LED)
  • Balancing resistors, one for each LED. I used 1.0 ohm 1210's
  • For red LEDs (and maybe green/blue depending on your power supply) you may need a choke resistor 0.5 ohm at 5W may be OK. The internal resistance of the battery and Rds of the FET will make a difference, so do math and measurements!
  • 6" diameter LED plate, see the downloads page for layout. This holes the LEDs and lenses. In theory a aluminum core LED is helpful but we found that for quick blasting, FR4 with copper fill worked just fine.
  • 16 or 18 gauge wire for connecting things up
  • 6 N Channel logic level power MOSFETs. We used FDP6030BLs. Nearly anything that can sink 2A is just fine.
  • Arduino or other microcontroller. The AVR atmegax8 series such as found in the arduino is handy because it has 6 hardware PWMs. We used a DC boarduino and attached an FTDI cable to upload the firmware
  • Battery capable of sourcing 4A at 4V+. 3 D cells or a lead acid is a good choice. We used a 4A 6V SLA that came with the lantern
  • Heatsink. A spare AMD processor heatsink and fan worked nicely and was free!
  • 9V battery + holder with switch for the arduino, seperate supplies prevent noise issues when driving such large loads
  • Enclosure. We repurposed a cheap yet enormous flashlight from Sears. It was pricey at $40 but had the benefit of including a lead acid battery (which would have run almost $20 with shipping) and a basic lead acid charger.
  • Power supply for testing, a ATX power supply is a good way to generate 5A+ at 5V
Step 2: Build it: The PCB
You'll want to start by getting an LED plate fabbed at your favorite PCB manufacturer and acquiring all the materials necessary (image 2a).
Start by soldering in one color of LEDs (in the photo there are a few LEDs soldered in from other strings. Go with green to start. (image 2b)
You'll want a nice powerful soldering iron, use leaded solder since its hard enough to solder to the copper plane! (image 2c)
Use 1 ohm (or so) 1210's for the balancing resistors (image 2d)
For testing you'll want a benchtop supply, or use an ATX power supply with a jumper between the green power line and ground (image 2e)
Test the LEDs to make sure you put them in the right place. Each 'string' is 6 LEDs. (image 2f)
Solder in all the green LEDs (image 2g)
Step 3: Build it: The Controller
Once you have a single color in place, you'll want to build the controller. I used a boarduino (Arduino clone) but any microcontroller is fine. Wire up the power FETs so that the gates are connected to the hardware PWM outputs, and the sources to ground. (images 3a & 3b)
To make traces on perfboard high-current-capacity you can use a 20 gauge wire as a backing and solder on top to make a path. (image 3c)
Which you can sort of see here (image 3d)
You don't have to wire up all the FETs now, start with one. We used 5.08mm (0.2") terminal blocks to make wiring easy (image 3e)
Step 4: Build it: Testing & The Heatsink
Do lots of testing and be careful to connect power up properly since there are no protection diodes (image 4a)
You can load some PWM testing firmware onto the microcontroller to check the LEDs as you work (image 4b)
Complete soldering in all the LEDs (image 4c)
A final test PWMing through all the LEDs. It heats up fast so keep the max power low and/or dont run it more than half a minute. (image 4d)
Since we were too cheap to get a proper metal PCB, we'll be attaching a heatsink to the outside. While far from ideal, a spare AMD processor heatsink worked just fine. Remove the fan, take off the metal clip and then reattach the fan. Check the fan to see if it will run off of 9V. Ours did OK (image 4e)
If you have thermal paste, spread some on the heatink. If you didn't tent the vias, use kapton tappe or similar to prevent them from shorting to the heatsink (image 4f)
Step 5: Build it: The Enclosure
Next up is the enclosure. We found the Dorcy 41-1088 lantern at Sears for about $40. Its very close to the right size so we went with it. (image 5a & 5b)
It looks like this. (image 5c & 5d)
Open up the bottom to reveal a 6V, 4A sealed lead acid battery. This battery works pretty well. There's enough internal resistance that when the LEDs are on, the voltage out drops to 4V which is rather convenient (image 5e)
It comes with a charger but putting it on a 7V benchtop supply will charge it much faster (about 4 hours instead of 20). (image 5f)
Step 6: Build it: More Testing & Reassembling the Body
Test the circuit with the heatsink and fan activated. (image 6a)
Then try it with the battery as the power supply (image 6b)
Check the temperature of the LEDs, we didn't get above 58 degrees C which is pretty good. (image 6c)
Open up the rest of the lantern and remove the reflector and halogen bulb. (image 6d)
Reassemble the body. (image 6e & 6f)
Extend the power lines and wire them to the main control PCB (image 6g)
Step 7: Build it: Attaching the PCB, Lenses, and Finishing Touches
The PCB is cut down and tucked into the slot behind where the reflector went (image 7a)
The plate sits in front, sadly its just slightly too small to go into the enclosure. However, this way there is more space for the heat sink. (image 7b)
Lenses are snapped onto the LEDs. I used superglue to tack them down. This is a major mistake so don't do what I did because then the fume damage the lenses and they need to be cleaned. There's probably a better glue to use. Perhaps epoxy? (image 7c)
A 9V battery is wired up to the arduino. All the lenses are put on (image 7d)
We cut out a simple lens protector from acrylic on our laser cutter. (image 7e)
Showing the fit before we finish. (image 7f)
With some gaff or packing tape to attach the lens protector, we're done! (images 7g & 7h)
Step 8: Hardware Files
This is all public domain, so enjoy!
*Schematic for LED plate in PNG format
The LEDs originally used are CREE Xlamp 7090 but any 1+ Watt LEDs work OK. The balancing resistors are about 1 ohm, but can be adjusted. Use 2 sets of 6 LEDs for full tri-color (more versatile). Or 3 sets of 6 LEDs for green/blue only (more effective)
The arduino (or compatible) is hooked up to the LEDs via logic-level N-channel FETs. The diagram shows 2 groups of 3 colors but can be easily changed for 2 colors. If red LEDs are used, a 0.5 ohm, 5W led should be placed in series with the wire to the LED plate.
Code:
// Bedazzler! A good multiple LED PWM project, by Limor Fried
// Public domain 2009
#include <util/delay.h>
int value;
int redpin1 = 5, redpin2 = 6;
int greenpin1 = 3, greenpin2 = 11;
int bluepin1 = 9, bluepin2 = 10;
int ledmax;
#define GLITTER 0
#define SWIRL 1
#define DAZZLE 2
volatile int mode = DAZZLE;
// we use a button on pin 2 (interrupt pin) to detect mode changes
void modechange(void)
// debounce it
if (digitalRead(2) == LOW) {
_delay_ms(10);
if (digitalRead(2) != LOW)
return;
Serial.println("button");
mode++;
if (mode > 2)
mode = 0;
Serial.print("new mode! ");
Serial.println(mode, DEC);
void setup()
pinMode(2, INPUT);
digitalWrite(2, HIGH); // pullup on mode button
attachInterrupt(0, modechange, CHANGE);
Serial.begin(9600);
randomSeed(analogRead(0));
// nothing for setup
analogWrite(redpin1, 0);
analogWrite(redpin2, 0);
analogWrite(greenpin1, 0);
analogWrite(greenpin2, 0);
analogWrite(bluepin1, 0);
analogWrite(bluepin2, 0);
ledmax = 250; // change this value to adjust the maximum brightness
void loop()
switch(mode) {
case SWIRL:
//Serial.println("swirl");
ckswirl(ledmax, 10);
break;
case GLITTER:
//Serial.println("glimmer");
glimmertest(ledmax, ledmax/10, 30);
break;
case DAZZLE:
//Serial.println("dazzle");
bedazzle(ledmax, 10, 7, 11);
break;
void bedazzle(int ledmax, int pulselensec, int freqmin, int freqmax) {
long pulses;
// note we dont use red LEDs in this
int freq = random(freqmin, freqmax+1);
int pulsedelay = 1000/freq;
pulsedelay /= 2;
pulses = pulselensec;
pulses *= 1000;
pulses /= 2*pulsedelay;
Serial.print("pulsing at ");
Serial.print(freq, DEC);
Serial.print(" Hz (");
Serial.print(pulsedelay, DEC);
Serial.println(" ms on/off)");
Serial.print(pulses);
Serial.println(" pulses");
while (pulses--) {
analogWrite(greenpin1, ledmax);
analogWrite(greenpin2, ledmax);
analogWrite(bluepin1, ledmax);
analogWrite(bluepin2, ledmax);
_delay_ms(pulsedelay);
if (mode != DAZZLE) return;
void ckswirl(int ledmax, uint8_t z) {
int r, g, b;
// fade from red to orange to yellow to green
for (g=0; g// turn red down
analogWrite(redpin1, ledmax-g);
analogWrite(redpin2, ledmax-g);
analogWrite(greenpin1, g); // sets the value (range from 0 to 255)
analogWrite(greenpin2, g); // sets the value (range from 0 to 255)
delay(z);
if (mode != SWIRL) return;
// fade from green to blue
for (b=0; b// turn red down
analogWrite(bluepin1, b);
analogWrite(bluepin2, b);
analogWrite(greenpin1, ledmax-b); // sets the value (range from 0 to 255)
analogWrite(greenpin2, ledmax-b); // sets the value (range from 0 to 255)
delay(z);
// from blue to red
for (r=0; r// turn red down
analogWrite(redpin1, r);
analogWrite(redpin2, r);
analogWrite(bluepin1, ledmax-r); // sets the value (range from 0 to 255)
analogWrite(bluepin2, ledmax-r); // sets the value (range from 0 to 255)
delay(z);
void glimmertest(int maxvalue, int incr, int z) {
for(value = 0 ; value <= maxvalue; value+=incr)
analogWrite(greenpin1, value); // sets the value (range from 0 to 255)
analogWrite(greenpin2, maxvalue-value); // sets the value (range from 0 to 255)
analogWrite(bluepin1, value);
analogWrite(bluepin2, maxvalue-value); // sets the value (range from 0 to 255)
analogWrite(redpin1, value);
analogWrite(redpin2, maxvalue-value); // sets the value (range from 0 to 255)
delay(z); // waits for 30 milli seconds to see the dimming effect
if (mode != GLITTER) return;
for(value = maxvalue; value >=0; value-=incr) // fade out (from max to min)
analogWrite(greenpin2 , maxvalue-value); // sets the value (range from 0 to 255)
delay(z);
1-40 of 73Next »
roadieflip says: Mar 30, 2012. 2:35 PM
Ok. So I have a problem with the code.
I copy and paste the code into Arduino and when I go to compile, it comes up with
expected ';' before 'analogWrite'
This is on line 130
Anybody have any ideas? I'm pulling my hair out and I haven't got enough as it is...
Oh, I'm running Arduino 1 with an Arduino Nano v3.
GASSYPOOTS says: Mar 26, 2012. 2:41 PM
use a sheet of thick metal see below
joeismydad says: Jan 26, 2011. 10:51 PM
that cant shine through welding goggles.
ilpug in reply to joeismydadOct 3, 2011. 9:55 AM
yeah, it probably can. if you have to wear welding goggles to protect your eyes from this, then you are still pretty much incapacitated.
Binary0101 says: Oct 8, 2009. 3:08 PM
I have a free solution to make this product inaffective, I close my eyes.
BeanGolem in reply to Binary0101Oct 8, 2009. 5:41 PM
 Yes... but if you close your eyes, then that means you are still incapacitated.
Binary0101 in reply to BeanGolemOct 9, 2009. 6:47 AM
then look away, turn your back to the device and run, it's still a dumb idea and waste of money at any level. Other than a person downrange from a firing squad I don't know of anyone who would just stand there and take the abuse.
swilus in reply to Binary0101Aug 8, 2011. 2:21 PM
Your comment is completely useless. Why are you even on this site?
dennisonb in reply to Binary0101Nov 3, 2010. 3:03 AM
Well if the point is to get you to 'turn around and run' it's pretty effective then, isn't it? It's non-lethal meaning the point wasn't to shoot you to the ground in the first place. Would make nice for angry-mob control for example. Better then needing to point guns at them isn't it?
rohang in reply to Binary0101Oct 22, 2009. 4:21 PM
There are a lot of things that are wastes of money. This is in no way a dumb idea--okay, use as a weapon is, but it's a really cool device and a great idea.
doxsys in reply to Binary0101Oct 9, 2009. 12:29 PM
Why is this a waste of money?  "Look away, turn your back, and run" is what I want when I use it to confront an intruder in my house.
shamanwhitewolf in reply to Binary0101Oct 9, 2009. 8:32 AM
And thus, the device has done its job, no?  If a person forces me to defend my home and I choose to use this, the results arelikely  very good: my home is defended AND I don't have to clean up the invader's blood or vomit.
If the person is an id10t and doesn't do as you suggest, then I have vomit to clean up, a person to arrest, a court case to attend, etc., but my home is still defended.
That this can be done for a few hundred dollars as opposed to the million for the military version is great, and comparable to the cost of a good sidearm.  And using said sidearm has other very negitive potential side effects.
If you're concerned about how effective this would be, mix it with high-powered ultrasonics and/or microwaves.  THEN you'd have a complete pain-field home defense unit.
Binary0101 in reply to shamanwhitewolfOct 9, 2009. 9:00 AM
So if you standing in a small room or hallway don't you think the relfection/pattern of lights off a white wall would induce the same behavior to yourself as your intended target?  I like my shotgun $99.00 dollars at Wal-Mart and I KNOW it works.
Also, I carry pepper spray and tested in the house to see if it would affect me in a burgular confrontation scenario to my suprise it did not. I attribute our swamp cooler ventalation system which recycles air quite rapidly. A spray to the face at least at my house would be a more effective means for non-lethal measures to a potential attacker or a flash gernade.
Now if I can just remember where I put that number to the Black Market. LOL
swilus in reply to Binary0101Aug 8, 2011. 2:22 PM
You would have to be a pretty darn good shot with your shotgun to make the hit "non-lethal"!
shamanwhitewolf in reply to Binary0101Oct 9, 2009. 9:34 AM
And my personal choice is a sword, but to each their own.  IF you are well trained in how to use the $99 shotgun, and you're comfortable with the potential negative consequences, then by all means, use that.  In close-quarter combat (such as home defense), the distance can be closed to blade or hand range extremely quickly and there are fewer risks to other household members, so swords work well for me.  Besides, explaining the headless body to the cops just sounds much more interesting then yet another bullet catcher. :D
The object here for the bedazzler Instructable is to give another very viable option.  If you're not comfortable with it, that's fine.
Binary0101 in reply to shamanwhitewolfOct 9, 2009. 10:21 AM
Well I just finished my enlistment as of 28 Sept 09 in the U.S. Army  and after eight years and I think I'm very comfortable with using weapons. LOL!
Like I said before I think it's a waste of money, as federal funded project and as an instructable. I'd rather use $10 worth or quaters in a sock as a weapon than spend the $250 to make this. The sword works as well unless your that poor kid from Maryland. http://www.cnn.com/2009/CRIME/09/15/samurai.sword.killing/index.html
Eli_Z in reply to Binary0101Nov 29, 2010. 11:31 AM
I was in the army as well, and know first hand that I'd much rather use a non-lethal device to cause an attacker to flee than anything that requires ammunition, preparation and has the potential of causing serious harm.
Yeah, if I were confronted with a psychotic, armed murderer I'd be happy to blow them away with a shotgun. Of course, you don't know who it is you've just killed until you turn on the lights.
Besides, this is perfect for those jerks who insist on walking out in front of my motorcycle.
de0509 in reply to Eli_ZAug 2, 2012. 8:23 AM
Lol. duct tape it to the shotgun and go LEROY JENKINS....!!!!!
cdousley in reply to Binary0101Dec 26, 2009. 9:00 AM
a sword is what takes training you dont even have to aim with a shotgun
--= Excogitate =-- says: Feb 2, 2010. 11:29 AM
 I like the concept and the spirit behind the 'weapon' but a tazer can be made from a disposable camera (granted not to strong). That's way cheaper and cost effective. Maybe a tazer with a bedazzler attachment... that would make someone trip bawlz and not in a good way. Or a device that can scan the area's/rooms dimensions to calculate that room's acoustic features and throw sounds like a ventriloquist... some really loud trippy sounds... and a bedazzler to top it off. meh.......
dennisonb in reply to --= Excogitate =--Nov 3, 2010. 3:01 AM
Well to be honest, the disposable camera things aren't really tazers. They deliver a bit of a shock, but nothing incapacitating. Especially when made from a disposable camera, the emphasis is on 'not too strong'.
plasticpopcorn4 says: Feb 7, 2010. 11:27 AM
"It doesn't work that well but it works great for raves"
i hope the million dollar government one works well lol
pennsteve says: Jan 14, 2010. 4:30 PM
Now if they can get the bad guys to stare at it for 10 or 15 minutes, they might have something worthwhile!  lol
kidmosey says: Jan 7, 2010. 12:10 AM
This seems like it could be an effective home defense system for when you are away from home.
Combine the dazzler, Laser-Tripwire, and  RFID-Door-Lock.  Way more effective than those loud obnoxious alarms that everyone ignores.  You could even make a portable version for your car.
geonav1 says: Jan 6, 2010. 4:01 PM
Does this work on animals?  I like the idea of adding high freq sound as well...
Nice job!
ANDY! says: Dec 31, 2009. 11:54 PM
does the flashes need to be random, or does it matter.
Topcat2021 says: Dec 5, 2009. 9:34 PM
This is a nice and informative instructable, good work A+ for your efforts.
 As a side note for the effectiveness and uses of a device like this, I watched a similar device used on future weapons it was used in conjunction with a rifle during a "rush" on people holding hostages to confuse the hostage takers giving valuable time to the soldiers in gaining control of the situation.
Again Good Work!
Chromatica says: Nov 30, 2009. 3:04 PM
Video?
boris_1981 says: Nov 4, 2009. 2:12 PM
like we say in puerto rico: BRUTAL!!
nice job ladyada!
Craftibles says: Oct 24, 2009. 6:17 AM
I felt strange just from the video! May just be that I didn't eat breakfast yet.
static says: Oct 22, 2009. 7:03 PM
 Ooops I brought a bedazzler to a gun fight. An interesting,but expensive project  Would the DOD, DOH and the USPTO  actually make available online information necessary to be able to come close to home shop duplicating a non-lethal weapon that could be used against military personell, law enforcement, and law abiding citizens? No doubt the info available online contain incomplete, and misleading data. People are noticeably affected by the flicker rate of the old fluorescent lights, others prose to seizures when exposed to certain flickering images. I have no doubt an effective weapon may have been developed, but I would think more effort would have to be expended to duplicated it. Perhaps of obtaining video of as many demos as possible to analyze, again I would assume there is a demo mode to prevent giving away details
rohang says: Oct 22, 2009. 4:24 PM
Take one of those to a concert or to Disneyland... lol
The Lightning Stalker says: Oct 8, 2009. 9:31 AM
Wood glue will work as long as there's not much flexing and shock.  It has the advantage of being removable in case some of the LEDs burn out.  Like any adhesive, everything has to be clean or it won't stick.  Epoxy will work also, but be very difficult to remove.  I've been using Gorilla Glue™ recently, but you have to be careful to only use a little bit because it will expand.  The other surface has to be moistened.  Huffing on it is usually sufficient, but you have to be quick, though, since it evaporates quickly, as you know.  You could also try melting the plastic onto the circuit board with a soldering iron, but that will likely have an even weaker bond than the wood glue.  Then there's double stick tape, of course, which the manufacturers like to use.  Another adhesive is the 3M™ carpet or corner bead adhesive in the spray can; but it's really expensive and you have to be really careful not to get it on the LEDs or lenses.
Benson1 in reply to The Lightning StalkerOct 14, 2009. 1:50 AM
Hey, I'm an amateur at most things electronic and I had aquestion.  Why would melting the plastic onto the circuit boardhave a weak bond?
Just so I have future reference...
The Lightning Stalker in reply to Benson1Oct 15, 2009. 11:20 AM
For  some  reason  Instructables  is being  crappy  and  deleting  spaces  in my  comments.
The 3 main reasons are:
Most people don't clean circuit boards after soldering. Melt plasticonto that and it will pick up the impurities and get weak and brittle.
The melted plastic and the object it's melted onto have to be the sametemperature for a good bond.
Few types of plastic can tolerate heating to liquid or semisolid withoutbreaking down.
Hot glue might also work well, but only if you're very meticulous inapplying it.  Unless the board and plastic are very clean and getheated to the same temperature as the hot glue, the bond is fairly weak.
It also has to be a 'hot melt' type gun to get the best bond.
The glue shouldn't be applied until the gun is up to temperature.
The glue melts before the gun is fully heated up since it's designed towork with 'cool melt' guns.
Hot glue won't adhere at all to some plastics. It might look like it's"stuck", but come apart later - probably when you need it most.
Hot glue will absorb cigarette smoke and this will get between the gluean 'workpiece', weakening the bond.
One trick I use on perforated board is to force the hot glue throughsome of the holes and out the other side.  This greatly improvesthe bond.
I don't usually recommend hot glue because of all thesecomplications, but it  can work if done right. It's quick and easy,so it's used a lot in the industry. There are specialty glue sticksaround that can overcome some of these limitations if you look around.Also, keep in mind that hot glue will melt when a soldering iron getsanywhere near it and will really screw up a joint you're trying to solder.
Kyle_S says: Oct 15, 2009. 10:50 AM
For everyone complaining about it's use as a weapon, you're onlythinking of individual weapons.  This appears to be a non-lethalcrowd control weapon, like the big acoustic devices* that police use tobreak up riots and crowds.
http://en.wikipedia.org/wiki/Long_Range_Acoustic_Device
The idea is to make it so uncomfortable to be in that area, that peopleleave, but to do it in a way that doesn't invoke images of whitefirefighters knocking down pacifists with blasts from fire-hoses.
*Mini-close-range versions of those can be built with a 555 timer andsome patience.  In highschool one of my friends made one, but wecould never adjust it to bother more than one person at a time, and itdidn't have enough juice to do more than cause a headache.
Pumpkin$ says: Oct 14, 2009. 12:31 PM
What hath god wrought! XD
It looks like the world's deadliest flashlight.
Mark Rehorst says: Oct 10, 2009. 10:31 AM
This is a fun, geek-party toy but it isn't a weapon.  Anyone who attempts to stand their ground against a determined attacker with just this device in their hand deserves whatever happens to them for being so foolish.
A weapon needs to operate quickly and reliably- hence the popularity of guns as weapons.  This device, if it does what is claimed at all, fails on both counts.  Some targets may feel nauseous, but it doesn't happen within the few seconds it takes an attacker to cross a room, take the thing out of your hand, and use it to bash your skull in.
By the way, nausea means feeling like vomiting, not actually vomiting.  Actual vomiting is emesis.  Neither nausea nor emesis are going to stop a determined attacker.
eyesee says: Oct 10, 2009. 8:55 AM
Does the ability use use
dark sponge says: Oct 10, 2009. 8:37 AM
For some reason this instructable would always crash my browser when I tried to open it. I'm pretty sure that the video is what caused it, because in Google Chrome it would come up as a quicktime symbol with a question mark on it and then freeze, so I had to go to the control panel to end it. But it worked when I opened it with Internet Explorer.
Anyway, very good instructable! I might make one if I have just the right combination of money and free time. 5 stars!
1-40 of 73Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
