Bedazzler: DIY non-lethal weaponry by adafruit
Contest WinnerFeatured
Step 6: Build it: More Testing & Reassembling the Body
Test the circuit with the heatsink and fan activated. (image 6a)
Then try it with the battery as the power supply (image 6b)
Check the temperature of the LEDs, we didn't get above 58 degrees C which is pretty good. (image 6c)
Open up the rest of the lantern and remove the reflector and halogen bulb. (image 6d)
Reassemble the body. (image 6e & 6f)
Extend the power lines and wire them to the main control PCB (image 6g)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
