Step 8Hardware Files
*Schematic for LED plate in PNG format
The LEDs originally used are CREE Xlamp 7090 but any 1+ Watt LEDs work OK. The balancing resistors are about 1 ohm, but can be adjusted. Use 2 sets of 6 LEDs for full tri-color (more versatile). Or 3 sets of 6 LEDs for green/blue only (more effective)
The arduino (or compatible) is hooked up to the LEDs via logic-level N-channel FETs. The diagram shows 2 groups of 3 colors but can be easily changed for 2 colors. If red LEDs are used, a 0.5 ohm, 5W led should be placed in series with the wire to the LED plate.
Code:
// Bedazzler! A good multiple LED PWM project, by Limor Fried
// Public domain 2009
#include <util/delay.h>
int value;
int redpin1 = 5, redpin2 = 6;
int greenpin1 = 3, greenpin2 = 11;
int bluepin1 = 9, bluepin2 = 10;
int ledmax;
#define GLITTER 0
#define SWIRL 1
#define DAZZLE 2
volatile int mode = DAZZLE;
// we use a button on pin 2 (interrupt pin) to detect mode changes
void modechange(void)
// debounce it
if (digitalRead(2) == LOW) {
_delay_ms(10);
if (digitalRead(2) != LOW)
return;
Serial.println("button");
mode++;
if (mode > 2)
mode = 0;
Serial.print("new mode! ");
Serial.println(mode, DEC);
void setup()
pinMode(2, INPUT);
digitalWrite(2, HIGH); // pullup on mode button
attachInterrupt(0, modechange, CHANGE);
Serial.begin(9600);
randomSeed(analogRead(0));
// nothing for setup
analogWrite(redpin1, 0);
analogWrite(redpin2, 0);
analogWrite(greenpin1, 0);
analogWrite(greenpin2, 0);
analogWrite(bluepin1, 0);
analogWrite(bluepin2, 0);
ledmax = 250; // change this value to adjust the maximum brightness
void loop()
switch(mode) {
case SWIRL:
//Serial.println("swirl");
ckswirl(ledmax, 10);
break;
case GLITTER:
//Serial.println("glimmer");
glimmertest(ledmax, ledmax/10, 30);
break;
case DAZZLE:
//Serial.println("dazzle");
bedazzle(ledmax, 10, 7, 11);
break;
void bedazzle(int ledmax, int pulselensec, int freqmin, int freqmax) {
long pulses;
// note we dont use red LEDs in this
int freq = random(freqmin, freqmax+1);
int pulsedelay = 1000/freq;
pulsedelay /= 2;
pulses = pulselensec;
pulses *= 1000;
pulses /= 2*pulsedelay;
Serial.print("pulsing at ");
Serial.print(freq, DEC);
Serial.print(" Hz (");
Serial.print(pulsedelay, DEC);
Serial.println(" ms on/off)");
Serial.print(pulses);
Serial.println(" pulses");
while (pulses--) {
analogWrite(greenpin1, ledmax);
analogWrite(greenpin2, ledmax);
analogWrite(bluepin1, ledmax);
analogWrite(bluepin2, ledmax);
_delay_ms(pulsedelay);
if (mode != DAZZLE) return;
void ckswirl(int ledmax, uint8_t z) {
int r, g, b;
// fade from red to orange to yellow to green
for (g=0; g// turn red down
analogWrite(redpin1, ledmax-g);
analogWrite(redpin2, ledmax-g);
analogWrite(greenpin1, g); // sets the value (range from 0 to 255)
analogWrite(greenpin2, g); // sets the value (range from 0 to 255)
delay(z);
if (mode != SWIRL) return;
// fade from green to blue
for (b=0; b// turn red down
analogWrite(bluepin1, b);
analogWrite(bluepin2, b);
analogWrite(greenpin1, ledmax-b); // sets the value (range from 0 to 255)
analogWrite(greenpin2, ledmax-b); // sets the value (range from 0 to 255)
delay(z);
// from blue to red
for (r=0; r// turn red down
analogWrite(redpin1, r);
analogWrite(redpin2, r);
analogWrite(bluepin1, ledmax-r); // sets the value (range from 0 to 255)
analogWrite(bluepin2, ledmax-r); // sets the value (range from 0 to 255)
delay(z);
void glimmertest(int maxvalue, int incr, int z) {
for(value = 0 ; value <= maxvalue; value+=incr)
analogWrite(greenpin1, value); // sets the value (range from 0 to 255)
analogWrite(greenpin2, maxvalue-value); // sets the value (range from 0 to 255)
analogWrite(bluepin1, value);
analogWrite(bluepin2, maxvalue-value); // sets the value (range from 0 to 255)
analogWrite(redpin1, value);
analogWrite(redpin2, maxvalue-value); // sets the value (range from 0 to 255)
delay(z); // waits for 30 milli seconds to see the dimming effect
if (mode != GLITTER) return;
for(value = maxvalue; value >=0; value-=incr) // fade out (from max to min)
analogWrite(greenpin2 , maxvalue-value); // sets the value (range from 0 to 255)
delay(z);
Add Comment
