The picture is one that i took using my setup.
Remove these ads by
Signing UpStep 1Backdrop.
I wanted a more permanent, but yet still portable solution. It also needed to be cheap. I bought a load of PVC pipe and fittings for about £20. I then got into my lego mindset and assembled it into a frame like shape. I'm sure you can use your imaginations to create a stable design.
I then got a big piece of white fabric, this cost me about £3.
I sewed a pipe sized loop at the top off the piece of fabric, to loop it over the top of the frame.
If you do this be sure to monitor the temperature of any flash with this type of diffuser. There are many ibles on how to make a diffuser for low or no cost.
I am sure if you ask a professional or check your flashes manual he/it will tell you flashes get very hot and can cause a fire. My warning was for everyone's protection.
The following Warning is from my Nikon SB800 Flash manual;
"Do not fire the unit while the flash head is touching a person or object. Such use can result in the person being burned, and/or their clothes igniting from the heat of the flash’s firing."
L
~ ED
L
~ ED
That's possibly 10x what I could get for mine.
L
