Bedroom Photography Studio Setup
18,508
39
13
Published
Introduction: Bedroom Photography Studio Setup
I wanted a photography studio. All i had was my bedroom, a couple of flashes and my DSLR camera.
The picture is one that i took using my setup.
Step 1: Backdrop.
I realise there are a lot of ways of making a backdrop. I started out by hanging some bedding off my wardrobe. This worked well, until of course, i needed to access my wardrobe.
I wanted a more permanent, but yet still portable solution. It also needed to be cheap. I bought a load of PVC pipe and fittings for about £20. I then got into my lego mindset and assembled it into a frame like shape. I'm sure you can use your imaginations to create a stable design.
I then got a big piece of white fabric, this cost me about £3.
I sewed a pipe sized loop at the top off the piece of fabric, to loop it over the top of the frame.
Step 2: Flash.
 I already had 2 flash's. For this application, they do not need to be new fancy ones. Mine are my dad's, probably about 10-15 years old. But they still work. Flash's can be picked up on eBay for good money.
Diffusers.
Diffusers soften light, this makes for softer shadows, more aesthetically pleasing photo's. There are plenty of instructable's on making diffusers. I plan on making some one day... But for now, i use a tissue and some elastic bands.
But what i prefer to use, and find it works better, Is to aim the flash's at the ceiling (provided it is white) and use that as a big diffuser. The results are quite remarkable.
I have my flash's on tripods, but you can use anything really. Rest it on the floor or clamp it to your ears, I don't care.
To illuminate the whole object you are photographing, you want a flash on either side. You could use lamps, i guess. But you have to be careful, as they give off a more yellowish colour, which sucks.
Step 3: Radio Slaves.
 Radio slaves are a wireless way to set off flash's. They are very easy to use and fairly cheap. Search for them on ebay, mine cost me about £15. I got one transmitter and 2 receivers, so i can set off two flash's at the same time. It's important to move your flash's away from your camera especially when taking pictures of people. As with built in flash's when you pull your best pout and stare into the lens, the flash goes straight into the back of your eye and this is how red eye is caused.
Step 4: Settings.
 I like to use manual mode, auto doesn't cope very well with the extra flash's.
As a general rule i use a shutter speed of 1/125 ish. This allows enough time for the flash's to be set off, and it's also not too slow so unless you're real shaky you wont have blurred photos.
An aperture of about 5 is about right, but this depends entirely on your flashes, or windows or whatever. Just play about with it.
Basically, that's about it. Give me a comment, or two. I'll like that. Have fun taking pictures.
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    13 Comments
    WARNING As flashes can get very hot I would avoid doing this. There is a very real chance of setting the tissue or any type of paper or most fabrics on FIRE.
    If you do this be sure to monitor the temperature of any flash with this type of diffuser. There are many ibles on how to make a diffuser for low or no cost.
    oh come on... i use pretty much the EXACT SAME SETUP... Flashes are only on for a fraction of a second... not enough to light anything on fire, if you were to use a continous light source for this then you would use a light diffuser.
    For the sake of expedience you can probably do this without a problem. If your flashes has or develops a problem you can have a fire. Since it is cheap and ease to make a modifier for a flash without having a potential hazard, that is what I would do and what I would recommend.
    I am sure if you ask a professional or check your flashes manual he/it will tell you flashes get very hot and can cause a fire. My warning was for everyone's protection.
    The following Warning is from my Nikon SB800 Flash manual;
    "Do not fire the unit while the flash head is touching a person or object. Such use can result in the person being burned, and/or their clothes igniting from the heat of the flash’s firing."
    I've got a similar Kodak, I was thinking of pulling it apart for the prisms & lenses.
    L
    DON'T tear it apart. It's a Classic Collector Item. There are still roll film outlets for it if you search for them. If you just want prisms and lenses...go to Edmund Scientific Company catalog. You'll find them on search. They have stuff that will blow your young mind.
    ~ ED
    Maybe, but you can pick 'em up cheap. It's still on the shelf.
    L
    True...but you cannot replace an original. I had a better one and it sold for $50.00US. The lens is cheap quality compared to what you can get today if you intend to use it for any projects of your own.
    ~ ED
    That's possibly 10x what I could get for mine.
    L
    Nice effect with the two flashes/shadows. Did you overexpose the backdrop intentionally so the object really stands out?
    I like to overexpose the backdrop as the sheet is normally creased, due to the fact i don't like ironing. The creases only show up because of the shadows, so overexposing and taking away these shadows leaves the background crisp white.
     When I saw "Bedroom Photography", I thought something completely different...
     Haha!
