3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bee Hive in a Bucket
Bees are having a tough time world-wide.  We need bees for our agriculture.
This bee hive is not designed for harvesting honey.  This is just a home for bees.  Not only the bucket is habitable, but the hollow pipe that supports it in the air can also be colonized.
In past years, bees have been getting scarcer around here.  I have had two volunteer bee colonies establish themselves along my ridge this year -- in inconvenient locations.   I hope they will find their way to this hive when the time comes for the volunteer hives to divide.
This is just an experiment.  The hive was put up today near one of the volunteer hives, and has not yet been colonized.
Step 1Background
Background
Bees have colonized an overturned cut-off drum used to support a supply of rebar off the ground.
Local friends said that just drilling a hole in a bucket and leaving it around would attract bees.  In designing this hive, I wanted the entrance high enough off the ground that toads would not be able to leap up and gobble bees at the entrance.
I put the entrance hole in the pipe, a little below the bucket.  That way, the bucket protects the entrance from rain.
80 comments
1-40 of 80next »
May 3, 2012. 3:28 PMfullabull69 says:
PLEASE NOTE: THIS TYPE OF BEEHIVE IS ILLEGAL IN MOST STATES!!! In almost all states, it is illegal to own a beehive with non-removable frames. This is due to diseases, mites and hive beetle infestations. All frames must be able to be removed for inspection. Exemptions may exist if you have no intent to harvest or manipulate the bees, but I think even those are very rare. Please check local agriculture regulations prior to setting this up. Even though you are trying to help the honey bees (a VERY noble cause), you could be doing more harm if the bees in your hive have a disease that can't be observed and they transfer it to other bees during contact or "robbing", etc.
The idea is VERY ingenious, though. Notes on making it more attractive: on the bottom of the bucket (the inside roof once inverted), screw in some small strips of wood about 1/2" x 1/2" x desired length. What this will do is give them an easier start at drawing comb (similar to a top bar hive). Then, find a lemongrass scent, or purchase some cheap "swarm lure" and you'll have success during swarm season. Bees will not just "up and leave" their home for no reason; you will only get new residents if they are swarming or if their old hive becomes uninhabitable.
- Mike, an experienced beekeeper inNevada
Jan 7, 2012. 12:48 AMsasham says:
You should make a skep and hang it on a tree. It is easy and cheap as it gets. Bees will love it. Instructions here, its on Serbian Cyrillic but you can understand almost everything from the pictures only.
http://spos.info/forum/index.php?topic=839.msg10469#msg10469
Bees like some kind of grases, so you can rub it into your beehive to lure them. Ask some local beekeeper which one are used in your area. Enjoy!
Apr 2, 2011. 12:29 PMvelacreations says:
here's a similar design that allows you to take honey: http://www.instructables.com/id/Make-your-own-Honey-Cow-Top-Bar-Bee-Hive/
Mar 26, 2011. 5:50 AMJustABeeK says:
A few comments. First, I applaud your efforts, and I think it silly that people who know nothing about beekeeping are criticizing the design. This looks like a good experiment. As with most experiments, you try something and see if it works. Uninformed people saying "no, that won't work because of x, y, and z" is silly.
I'm a beekeeper, and while wood might be better, you've already found out that feral bees will inhabit most anything. A large open container with a small hole like that seems about right for bees.
As for the hive being colonized, spring time is perfect, as that is when swarms happen.
Dec 17, 2010. 7:20 PMmatt_and_nick says:
could you put the bucket right side up, and put removable shelves in it? i saw this instructable, hoping that there would be a way to extract the honey
Nov 9, 2010. 1:38 AMTurnpike7a says:
any bees yet? interesting design...i'd love to put these up around all my honey suckle if they work
Nov 19, 2010. 6:59 AMpokster says:
i've heard and read that using sugar or syrup can attract them and goad them into establishing a hive, dont use honey though there can be spores in honey that can transmit diseases, would the fact that hive is made of plastic be a factor?
Maybe if you use a wooden container, btw with a similar set up you can even get a wooden post with a few holes drilled into it, and bumble bees will set up shop there. Good luck!
May 27, 2010. 3:06 PMurbanwoodswalker says:
Wondering about the bright white plastic...has anyone ever seen a plastic bee hive in use before?  I have seen wood used.....don't know how bee friendly plastic is to them.  it would get hot, and plastics emit gasses...even if unnoticed by us. i would opt for chemical free wood instead.  why add more plastics to the How hard is it for the bees to climb up and also to store honey to feed young in such a slick surfaces container?
Just wondering...
Jun 13, 2010. 4:54 PMBorion2 says:
Today they are making hive body parts from polystyrene.
Jun 14, 2010. 6:11 AMurbanwoodswalker says:
I have seen those textured plastic sheets inside the wooden hives at the nature center where i used to work. However the frame was always wood. The idea of bees living in plastic pipes and buckets bothers me. there are so many other frugal and Natural ways to entice them .
Aug 6, 2010. 4:41 PMcre814me says:
Thinkenstein - I applaud your attempt, but would agree W8ZNX - go with a top bar hive. I will provide links and plans if you like. I have some KTBH's here in North Carolina. If you have the tools, and access to some old pallets, I am guessing less that $30. Also, to try to catch the swarm, here it is between April and Jun 30th, but mount the hive about 8 ft off the ground. I have never done it that way, but some people swear by it. Also, if you treat the wood, please treat it with a 20:1 mixture of Linseed Oil and melted Beeswax. It easy, and natural. Leaves a nice colored wood. I probably should do an 'ible on building one, but that would not be anytime soon. No need to build more right now. Good luck!
Aug 9, 2010. 5:22 AMclosetosky says:
Hi, I am getting into honey bees and would love to get so plans on the hive with the old pallets. The company that I work for had thrown away all the wooden pallets until I found someone local that would pick them up weekly. Anyway I have plenty of pallets and time. I live in Knightdale N.C. and my email is closetosky@yahoo.com Thanks
Jun 14, 2010. 9:34 AMurbanwoodswalker says:
Nope they were a polystyrene. I know what beesway is. :-)
Aug 6, 2010. 10:57 PMchello2k9 says:
I know nothing about bee keeping, but google knows all and plastic bee keeping equipment does exist, and is sold online. The only issue I see with plastic is bees don't take to it as they do natural material. i saw a site saying keepers should spray the plastic down with sugar water to acclimate them to the plastic. I'm curious, have any bees moved in since you've posted this?
Jun 2, 2010. 4:31 AMurbanwoodswalker says:
Good to know....I can understand that.
Aug 6, 2010. 12:06 PMw8znx says:
nice idea, love pickel bucket projects, but sry it will not work, as stated by others, not enought room for a strong hive that can store enought honey to winter over also a weak hive can be wiped out by a strong hive that steals all its honey no provision for ventilation bees need ventilation to control inside temp of the hive no way to inspect the brood which would make this style hive ilegal in some parts of the United States reason is not mites, but " Paenibacillus larvae larvae " better known as american foul brood AFB nasty stuff that kills a hive can spread to other hives most of all if strong hive steals honey from weak infected hive in the end causing more than one hive to fail for cheap/simple hive see " top bar hives " your truly
May 27, 2010. 12:05 PMpaitch says:
So, did the bees ever move into the bucket?
Jun 2, 2010. 11:27 AMeyepodd says:
not sure if this would work but you could put a bee atractant inside to get the bees to go in there??, nice instructlble 5/5 i might start mine soon, as soon as i get a big bucket :)
Jun 16, 2010. 11:42 AMA good name says:
If you're interested in pollinators, rather than honey collection, try orchard mason bees. They reproduce anywhere with holes and mud (look em up and you'll see what I mean)
May 27, 2010. 5:10 PMgaiatechnician says:
It is great that you are trying. If it works, great!
and if it doesn't,
well too bad, but we have not lost anything.
I leave some of my sprouting broccoli to go to flower just for the bees and humming birds every year.
I would just like to remind people that there are lots of other types of bees and wasps too.  Many of them live in burrows in the ground or in holes in wood.  This year I have bumble bees that took over a wren box.   I think they had the runs because there was brown fluid dripping out but now it has stopped.
  I also drill holes in wood for orchard mason bees and others.  6 inch deep holes or more and different sizes for different types of bees and wasps.  A new thing this year is holes in cob.  Cob is a mucky  mix of clay sand and straw that gets really hard when it dries out.  I made the holes with random pieces of round bar and old pieces of clothes hanger and old knitting needles.
Leave them stuck straight down in a piece of cob for a couple of days, twist them out and you have a bunch of holes in a cob B-block!   It might work, it might not.
But what have I lost if it doesn't?   Bees are getting scarcer and the more ideas to help them, the better.  You might not need cob, maybe ordinary soil will work.
Depends on your soil and your local bees.  Leaf cutter bees are amazing fliers!
They ride that curved up leaf through the air  like it is a surfboard!
And in my area, they need 10 to 12 mm holes in wood or in the ground.  ( Up to half inch)
Brian
Jun 14, 2010. 6:07 AMurbanwoodswalker says:
This is great! Love the Cob idea~~~!
Jun 13, 2010. 4:51 PMBorion2 says:
Great idea!!! I am going to suggest and make some for my dad who is a beekeeper. Should be great for catching swarms from his hives.
May 29, 2010. 7:43 AMspidersaysdie says:
 Realy nice instructable! My dad has been looking into bee keeping for some time but the cost is a big factor. I think he would like to collect the honey so this version is not ideal but it would be a good project to see if a colony could survive in our area.
May 29, 2010. 8:37 AMEric Rochow says:
if you are interested in beekeeping, get the Beekeeping for Dummies book by Howland Atkinson.
I have 4 beginning beekeeping books, and his is the best. I re-read it all the time.
The bucket hive concept is not a good test to see if bees will survive in your area, your best bet is to search online for a local beekeeping group, they have the best local knowledge and probably offer classes.
thx, eric  www.gardenfork.tv
May 31, 2010. 1:30 PMspidersaysdie says:
 Nice one! Thanks very much I'll see if I can pick up a copy. Not sure about local beekeeping groups as we'r on the west cost of scotland but I'll see wot I can dig up.
cheers
May 29, 2010. 8:33 AMEric Rochow says:
ask 12 beekeepers a question and you will get 13 answers.
I am a novice beekeeper, and to me, I think the bees would be better off in something larger and more substantial, and a regular hive answers all of that.
I think this bucket is too small for a hive to have a chance of thriving, and lacks ventilation. the author's point about hive defense should not prevent the hive from having ventilation that does not allow water - rain in.
You can get beehive plans at BeeSource.com. You all could build simple hives with screened bottom boards to allow for some Varroa Mite control. You can purchase synthetic "come here" pheromone from bee suppliers to put in an empty hive to entice a swarm take up residence.
While the bucket concept is green and makes us feel good about helping bees, it doesn't work for bees. The suggestion above about building tube hives for Orchard Mason Bees and similar bees is great.
Its clear to me from the authors intent and the comments that we all want to help bees be bees, and that's good. We learn from this kind of instructable.
thx, eric.  www.gardenfork.tv
May 27, 2010. 9:44 AMbruce.desertrat says:
 Just be absolutely sure to put this far away from humans or pets if you live anywhere  in the Southwestern US where there are Africanized bees. Here in Tucson, you can assume that any wild colony or swarm is Africanized and they are extremely aggressive!
Every year we have people who end up in the hospital or dogs who end up dead because they messed with an africanized colony and get stung hundreds or thousands of times, and to an africanized colony, 'messed with' means as little as 'walking within 5 feet of'.
May 27, 2010. 10:52 PMthewmas says:
 Yea but they still poll>nate, i'v been around them, just like any type of bee, no mess, no sting, and phemon's
May 28, 2010. 11:50 AMbruce.desertrat says:
Yes they do pollinate, and foraging bees (the ones you encounter out flying to the flowers) are not generally aggressive, regardless of origin, but bee behavior at the hive is VERY different!
We have professional beekeepers who manage africanized hives, here in southern AZ, and like their counterparts throughout South and Central America have learned to manage them, but the fact remains that Africanized bees are vastly more aggressive, and recruit defenders in numbers that are orders of magnitude greater when the hive is threatened.
Whereas a European colony might send out a few dozen bees to attack an intruder,  an Africanized colony will send out hundreds, even thousands (if the hive is that large)
Again, you do not want Africanized colonies hanging around places where people and pets frequent.
If you want to encourage pollinators, try setting up homes for native bees, like nesting blocks or reed nests. There's a lot of information out there on providing habitat for native pollinators.
I have a patch of bamboo growing in my yard, and keep the poles around to use for gardening etc. I have them hanging in a bundle up on my porch and some big carpenter bees nest in them every summer.
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
339
Author:Thinkenstein
I'm a refugee from Los Angeles, living in backwoods Puerto Rico for about 35 years now and loving it. I built my own home from discarded nylon fishnet and cement.
