Beebeecraft Instructions on How to Make Strand Pink Pearl Necklace
203
7
Published
Introduction: Beebeecraft Instructions on How to Make Strand Pink Pearl Necklace
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Summary: Pearl beads jewelry is always elegant and beautiful so that many girls admire them very much. Have you been attracted by the following strand pink pearl bead necklace?
This triple strand pearl necklace can dress up in any outfit of party and any important occasions even in office. It is so useful and only looks expensive. But you can make them by yourselves at home in fact. I will share this Beebeecraft tutorial of pink pearl necklace with you now~ Follow me to learn how to make a triple strand pearl necklace step by step!
Step 1: Supplies Needed for the Feather Dangle Earrings:
8mm Dyed pink Glass Pearl Round Bead Strands
6mm Dyed pink Glass Pearl Round Bead Strands
10mm white Glass Pearl Beads Strands
2mm white Glass Pearl Beads Strands
9x3mm Iron Bead Tips Knot Covers
0.3mm LightGrey Tiger Tail
6x3mm Rhinestone Spacers Beads
4x0.7mm Silver-color Iron Eyepins
Step 2: String the First Strand for Making Triple Strand Pearl Necklace
1st, cut off about 30cm tiger wire, slide a bead tips onto the wire and pass the wire, and then slide a pinch the bead with flat nose pliers;
2nd, slide a 8mm pink pearl to the wire followed by a 2mm white pearl beads;
3rd, repeat this pattern for several times to make the basic pattern of the pearl necklace and slide another bead tips on the end;
Step 3: String the Second Strand for Making Pink Strand Pearl Necklace
Do the same pattern as the last step to make another strand.
Step 4: Add the Rhinestone Bridge Spacer
1st, add a rhinestone bridge spacer to the eyepins, along with a 10mm pink glass pearl, a rhinestone spacers beads, one more 10mm pink glass pearl beads, and a rhinestone bridge spacer;
2nd, make a loop of the eyepins with the pliers;
3rd, add 2 more patterns like before (as shown in the picture);
Step 5: Finish Making Strand Pearl Necklace
1st, thread a 6mm pink pearl bead to a 4.0cm silver eyepin. Repeat this step to make more such patterns, and thread a 8mm white pear, a rhinestone spacers beads and a 6mm pink glass pearl in sequence to a 4.0cm silver eyepin;
2nd, connect these patterns by making a loop of these eyepins;
3rd, repeat to make 2 more shorter pearl bead chains like before;
4th, connect the 3 pearl chains patterns with the rhinestone bridge spacer patterns (as shown in the picture); 5th, attach the dangle patterns with the 2 strand necklace pattern finished before by the bead tips knot covers with the loops of the eyepins together.
Step 6: Here Is the Final Look of the Two-strand Pink Pearl Necklace.
Wow! This tutorial on how to make a strand pearl necklace is done! Do you like this handmade pink pearl bead necklace? If you need an accessory for your summer dresses, you can DIY a two-strand pearl necklace follow the beebeecraft tutorial. By the way, while grouping pearl beads with eye pins, be cautious to keep your hands away from being hurt by the pliers and sharp tip on pins.
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
