Beef & Bacon Forager Bars
Introduction: Beef & Bacon Forager Bars
Paleo Recipe Challenge
Runner Up in the
For busy, modern paleolithic eaters, we want on-the-go snacks that are easily portable and made from real food. What better fuel for your day than meats, fruit, veggies, and nuts all wrapped into one grab and go snack?!
Not unlike what our ancestors might have packed for a journey across the land- these beef and bacon bars studded with apples, kale and hazelnuts are salty, smokey, soft, just a touch sweet and are the perfect healthy Paleo food!
1/2 cup chopped dried apples
1/2 cup chopped fresh kale
1/2 cup toasted hazelnuts
2oz pasture-raised uncured bacon, cut into pieces
1/2 tsp sea salt
1/4 tsp fresh ground black pepper
8oz grass-fed ground beef
Step 1: Chop Fruits & Veggies
Chop dried apples into small pieces and measure out 1/2 cup.
Remove the center rib from the kale leaves, chop kale into small pieces and measure out 1/2 cup.
Add the chopped dried apple and kale pieces to a food processor, along with 1/2 cup toasted hazelnuts; pulse several times, until the nuts are well chopped.
Step 2: Add Bacon & Beef
To the chopped fruit, veggie and nut mixture, add the bacon pieces and process until the bacon is ground up.
Add in the ground beef, salt, and pepper and process until everything is well combined.
Step 3: Form Into Bars & Dehydrate
Divide the mixture evenly into 1/4 cup portions.
Form each portion into a log by rolling it between your hands, then place onto a non-stick dehydrator sheet and flatten into a rectangle shape, about 1/4" thick. *You could also use smaller portions and form them into circles.
Dehydrate using the jerky or meat setting, for 6-8 hours, or until completely dry, but still pliable.
Alternately, you can dehydrate them in an oven on the lowest setting. To do this, use a parchment-lined pan and flatten the bars to 1/8" thick. Open the oven for 15 minutes every hour (to release moisture) and bake for 6-10 hours, or until completely dry.
Store in an airtight container in the refrigerator for up to one-week, or in the freezer for up to three months.
Step 4:
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Looks delicious, but is the meat (bacon and beef) dried raw? Is it okay to use hamburger with 15% fat added instead of 8 oz straight ground beef?
    Thanks for posting!
    Yes, you can do the the sub, but I would use a lower fat ratio beef, as the bacon adds the fat needed to make this " Pemmican" .Grass fed beef has such a great flavor that I would use it if you can find it. As to the "raw " factor, the temp you will be at when dehydrating it will " cook" it. But, as stated by the author, he keeps it reefered and/ or frozen, wich I also recommend if planning to not use it up soon.
    Thank you for this IBLE, it solves the canoe trip issue of being sick if gorp, granola and drie feuit...ugh!!
