loading
Picture of Beef Jerky
Make beef jerky at home with this surprisingly simple recipe you can customize to suit your own tastes. Making it yourself means no added preservatives or nitrates - you control what goes in.
Whether you like it sweet, smokey or spicy, this easy technique will have you loving your homemade jerky, and leave your friends begging for more.
Step 1: Ingredients
Picture of Ingredients
  • 1 1/2 pounds (680 g) flank steak (or any meat! try turkey or bison!)*
  • 1/2 cup (120 mL) Worcestershire sauce
  • 1/2 cup (120 mL) soy sauce
  • 1 tablespoon (15 mL) honey
  • 2 teaspoons (10 g) pepper
  • 2 teaspoons (10 g) preferred seasoning - I used a mesquite blend, but another simple option is garlic or onion powder
  • 1 -2 teaspoons (10 - 20 mL) liquid smoke
  • 1 teaspoon (5 g) red pepper flakes (opt)
I didn't add any extra salt because of the soy sauce. If you like it saltier, then go for it!
*user jaythedogg recommends cooking any poultry or pork before dehydrating!
Step 2: Slice
Picture of Slice
First, freeze your meat for about 1/2 an hour. This just makes it easier to cut and handle. More than that, and it might get too hard to slice!
Slice your meat into very thin strips. Flank steak is great for this because it's got a very obvious grain to it. The only thing I didn't like about it was how thin the cut was, making my strips come out very narrow.
Step 3: Season
Picture of Season
Combine all of your marinade ingredients in a plastic bag, tupperware, or shallow dish.
Add strips of meat and refrigerate for anywhere between 2 hours to overnight.
1-40 of 82Next »
Bronson13 months ago
What flavour is it
dlvendt1 year ago
so i left some on for 2 hours and the rest for 3, delicious. 3 thumbs up and 3 paws up. I will be doing this again.
dlvendt1 year ago
Marinated18 hours and now on then rectec grill at 180 to dehydrate. Will post the results later.
epicfail!2 years ago
for all you aussies out there, this is awesome with kangaroo :) yum
peteg003 years ago
Every Time I've tried to make my own jerky I screw it up somehow ... I prefer to just buy my jerky from http://www.bulkbeefjerky.com
fiive5 years ago
Is it O.K. to skip liquid smoke?
scoochmaroo (author)  fiive5 years ago
If you don't like a smokey flavor, yes. If you want a smokey flavor, you may have to use a smoker instead!
Hi really nice inst!
I want tell you this way for a home made simple light smoking.
Pic a pot, then put inside a little pot with a small ammount of salted water and a tin alluminimu foil with some sage leaves, ignite the leaves or burn them with the heat of the fire down the pot, cover all with a lid. Shaking time to time the big pot to generate waves on the smaller one. Finish pretty smoked water.
Last advice for italian people want to trie this great inst. the piece of meat here is called BAVETTA DI PANCIA.
THX A LOT.
What is liquid smoke? where do you aquire it?
If I'm not mistaken it is liquid that has had smoke condensate of some form dissolved in it, and I'm reasonably sure you can find it at most supermarkets.
jaythedogg5 years ago
MAKE SURE to cook poultry & pork BEFORE dehydrating! Trust me, nasty things can result if you don't! Otherwise, great ible!
200 degrees for four hours will kill most of the uglies...
"Note that the common methods of cooking food do not sterilize food - they simply reduce the number of disease-causing micro-organisms to a level that is not dangerous for people with normal digestive and immune systems."
http://en.wikipedia.org/wiki/Sterilization_%28microbiology%29
True true.
Also to consider is if you freezing the meat, like sushi, before the dehydrating process, this reduce drammatically the presence of dangerous organisms, and also make the meat more soft.
A salt brine marinade will kill lots of uglies too, it dehydrates them to death. See bacon, for example. Of course that makes for some really salty jerky.
scoochmaroo (author)  jaythedogg5 years ago
Ooh, good comment!
big-jamie3 years ago
Straight to the supermarket for me to get some good steak to make this. Ive made plenty of jerky before but finding this instructable has ignited my passion again for jerky, I love it.
I did one time marinade my beef in pure tobasco sauce which gave it a right good kick, shall we say.
I have bacon on the grill the now while reading this so its as if its a smell-ible lol. thank you.
Chrystalkay3 years ago
I had a LOT of left over turkey a couple years ago and decided to try turky jerky with the already cooked met. I marinated it overnight in soya sause, with a bit of rice wine vinegar and fresh ground garlic.
MAN! It made the best jerky! Of course I didn't get much of it once my grown kids discovered it!
Anyway, there is no law that says you have to use fully raw meat. What about that underdone beef roast? Or even a pork roast that came out without much flavor? This has saved several disasterous meats from the garbage pan.
AWSOME!!!!!!!!!!!! :D i must try this! since i don't have the type you suggested, i'll have to use bacon. gotta use it up some how. lol
the problem with using bacon or any fatty meat is the fat can turn rancid and will trun faster the longer it is held in a heated environment and the higher the heat is of course.. Bacon jerky is likely to go quickly so you';ll have to eat it up fast. That's also why they keep the little packets in the store bought jerky. to keep the oxygen from making the fats in the meat rancid before you can eat it.
FWIW, Kitty
fiive5 years ago
Is this wheat free?I am allergic to wheat.
KittyF fiive3 years ago
make your recipe wheat free by subbing wheat free ingredients for one which have wheat in them. when you have an allergy, you have to learn to experiment in self defense. it's even worse if you have several.
whiteoakart5 years ago
I just put in my first batch.  I am using the oven for convenience this time around.  My oven has a convection setting, which I am using for the jerky.  It's perfect because it circulates the air around in the oven.  I am thinking it will take less time to dry it.  I know baking and roasting take less time with the convection setting.
I will post a picture when it is done!
My brine:
1 cup Soy Sauce
1/4 cup BullsEye BarBQ sauce
1 Tbs crushed garlic
1/4 cup basalmic vinegar
2 Tbs Spanish Paprika
I do not like Liquid Smoke.  Next time, I will use a smoker to dry it.
Thanks for the inspiration.
scoochmaroo (author)  whiteoakart5 years ago
Genius!
I am personally addicted to liquid smoke.  I'm sure it's probably some terrible carcinogenic, but then, that's probably what makes it addictive.  ;)
I wish I had a convection oven!  Let us know how long it takes!
actually, I saw some informational video about liquid smoke, and they pretty much just burn wood and pipe the smoke up through some water to dissolve the smoky particulate matter.
very good
codongolev4 years ago
I read in wired a very hazy description on microwave beef jerky (it pretty much consisted of "marinade, then put in microwave for 30 minutes on half power," so yeah), so I tried it. for the marinade, I used some sort of Caribbean jerk marinade overnight, and then I did the microwave thing. it actually took a little longer (closer to 43 minutes) and it was kind of hard to see when it was done (is that water or fat?), but I tried it anyway. it took a little prodding and poking and guesswork, but let's just say my brother's asleep, and I promised him some, but I am having trouble keeping it out of my face.
padz4 years ago
i tried ur way and they were fantastic!!! iv made about four batches since ;) nice one thanks.
renejeddore4 years ago
I let mine soak in a cold garage (approximately 5 degrees Celsius) for around 36 hours. I dried it for four hours with the oven door opened to it's first stop. Came out perfect! Everyone loved it!
Thanks!
Rene
siggibahama4 years ago
since reading your instructable like,,, a year ago, I have been going jerky crazy, trying everything, I now love making pig jerky,,,, but my oven made too little jerky at once, so me and my boys came up with this,,, http://www.instructables.com/id/The-Jerky-Making-Machine-a-low-heat-meat-dryin/
Blaaken4 years ago
Try tenderizing the meat before marinading, it should help the meat absorb more of the marinade and it will be more tender.
bob1503884 years ago
I have been using this recipe since Christmas. Probably made it 10 times. Have a batch ready to go right now. It is the easiest and best jerky I have ever had. I do make a couple of small changes. I add about a 1/2 cup of water to the marinade and prop the oven door open with a wooden spoon handle after about 20 or 30 minutes as someone else here suggested. I dry it for 4 hours at 200 F. Always comes out great!
scoochmaroo (author)  bob1503884 years ago
That's awesome. I was just talking about making some more! I'll try your suggestions.
WryteF5 years ago
There is nothing like the enjoyment of making your own jerky except for savoring it for weeks and months afterward.  A beef jerky maker does make the process a bit less of a mess.
wenpherd5 years ago
Wow! this looks great, oh and a little spelling error (I think) Step 5, 2nd paragraph, sentence two "Its such a fun and......" got to get that "A" in there.
carnivore5 years ago
   i tried your recipe and it's excellent . my first batch just came out of the dehydrator . i used deer meat . everyone likes it. thank you for the post. tomorrow i think ill try beef.
spylock5 years ago
A little ground ginger is my secret ingredient,it does wonders,3/4 to 11/4 teaspoon would do it for the amount of meat you have.
mastermaker5 years ago
Hahahahaha, i didn't read it all the way through, sorry, but still has anyone tried it?
Has anyone ever though of cooking it slightly to remove bacteria, etc. then drying it between two air vent cleaners and a fan like alton brown did? It makes much more proper jerky i believe.
The jerkey was dry, but still a little tender at 1:45.  It was almost completely dried and chewy at 2:00.  The smaller pieces are a bit crunchy.  I would prefer it a little spicy, but the rest of the family doesn't.  They like it just fine.
Thanks Scooch!
Great!
Next time you can make up two different brines - put a little of the stuff in another bag and spice it up for yourself!
1-40 of 82Next »
