Introduction: Beehive Shelves
This technique uses masking tape to "clamp" when glueing mitred joints. Its a very useful technique if you need to join anything with more than 4 sides where clamps won't work. Ratchet straps also work but are more expencive.
I'd like to thank Starck Joinery cc in Salt River, Cape Town for teaching me this amazing technique. You guys are true master joiners.
Step 1: Tools
You'll need:
- Sufficient wood to make your boxes. For the 6 boxes you see here I used a piece approx. 1700mm X 600mm
- A saw that can cut an accurate 30 deg. angel.
- Wide masking tape.
- Wood glue.
- Sand paper.
- Wood primer
- Wood varnish
- Paint (colour of your choice)
Step 2: Cutting
I set my saw at 30 deg. You are looking for 60 deg. angles between joints. Just be careful which side you are wanting to face out. I used reclaimed 18 mm shutter plywood; the stuff they use for concrete work on a building site.
You can make the hexagons any size you want, but be careful; the fist couple I made turned out way too big or way too deep. The dimensions for each of the 6 sides of my hexagon boxes are (outside dimension) 150 mm deep X 190 mm long. This creates a hexagon with an approximate diameter of 390 mm.
Step 3: Filling
Step 4: Sanding
Step 5: Painting
Now comes the fun part; painting it gold. Soon you'll have a nice stack of gold bars in front of you. Its more impressive in reality than it is in the photo.
Step 6: Gluing
Now stick masking tape down the length of this leaving quite a bit of run over. You will use this to wrap around the shelf. a bit later. I rolled mine up to keep it out of the way.
Now flip it carefully.
Put glue on all the edges that need glue put on them.
Now just role it up and wrap those left over bits around the box nice and tightly. You might want to wrap more masking tape around a bit more.
Step 7: Things I've Learnt
The wood filler worked pretty well but next time I'd paint it on over the whole surface and try find something to help it bond to the wood a bit better.
I'd definitely paint the surfaces first, then cut with a fine toothed saw to avoid chipping on the edges.
