3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Beeping Plastic Bottle Bird Feeder
Step 7Finishing up
Finishing up
Cut a piece of PVC pipe that is a little taller than you want your bird feeder to be. Then, cut another piece that is about a foot long. Connect these two pieces with one of the elbow connectors so it is in the shape of an upside down L. Then, put the other connector so it points up. Next, drill two parallel holes in the small bottle and cut a foot long piece of rope/string. Tie each of the ends inside the bottle so you have a loop. Hang this loop on the elbow connector that is pointing upward. Fill the small bottle with bird seed using the slit at the top and than tape the slit shut.
If you are doing the electronics you connect the two long wires to the wires coming from the two tin plates on the bird feeder. You might want to do this before you put the bird seed in and hang it up if you are going to soldier it. If you twist it you can do it in any order you want
Now, you can go put it outside and instead of watching for the birds to come, just wait for the beep!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sporekat
