Beer Can Bathroom Cup Dispenser
11,841
63
15
Published
Introduction: Beer Can Bathroom Cup Dispenser
Finding a good quality wall-mounted bathroom cup dispenser is difficult. The few models out there are made of unattractive plastic. The pop-up style of dispenser takes up counter space and the springs wear out and rust. There's a cheap, simple solution.
In this Instructable, you'll see how to transform a common beer can into an attractive polished aluminum dispenser that keeps your cups high and dry.
Step 1: Supplies
Here's what you need, from the left:
* A beer can. Here we have the venerable PBR 24 oz. Any drink can of a similar diameter will work.
* Clear silicone
* A can opener
* Polishing compound
* A strip of hook and loop tape
* Sandpaper
* A file
* Not pictured: a rag
Step 2: Fill
First, fill the can with water. This will support the thin aluminum while you polish and transfer heat so it doesn't warp when you sand it. Is that an ugly sink or what?
Step 3: Sand
Sand the can to remove the paint. If you have an electric palm sander, it will save you time. Wet sanding seems to work best.
Step 4: Polish
Rub the polishing compound on the can until you get the finish you want. Light buffing will give it a cloudy, brushed look and more will result in a mirror shine.
Step 5: Remove the Lid
Drain the water, then remove the lid with a can opener. You'll probably have to go around a couple times to get a clean cut.
Step 6: File
File the rim to remove any leftover shards of aluminum.
Step 7: Apply Glue
Finally, apply four daubs of clear silicone glue to the inside edges of the can. This serves to hold the cups in place, since the beer can diameter is a bit larger than a standard cup. Let the glue cure overnight.
Step 8: Mount
Now you can mount your finished dispenser with four small strips of hook and loop tape. Since it's round, It will be most stable in a corner.
Drink up and enjoy!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    15 Comments
    I think this is an eh, ok, "ible", but think a little bit more should have been done for the reloading process, ... a removable top, would work much better, & after a few dozen uses of putting the cap on, & off, it should be easier to do with more use, ...
    a good idea of repurposing, but could have went a little bit further, ...
    Good question! The cups push right in, catching just a bit on the silicone bumps, whiich then hold the stack in place.
    I love this kind of instructables. Thanks kamm, I think this is a pretty clever way to re-use old cans that otherwise would be wasted. Although I don't drink alcohol, I found the Arizona cans comment very helpful.
    This is easy to follow, I liked it a lot.
    Does one need to be an alcoholic to drink beer?
    You could also use the beer to make bread or as slug bait in the garden if you don't want to drink it. I've found that Tesco Value Lager works well for both purposes, and comes in big cans. ;-)
    o.k i think this is awesome and all but why would you need cups in your bathroom?
    For things like mouth wash, after brushing your teeth to rinse, theres personal measures like medical reasons to test urine ect. Think out side the box lol
    A few tips:
    1. If you polish the can before you drink it, it will be much more rigid, and easier to polish.
    2. A buffing wheel on a bench grinder will polish it up super easy, and super fast!
    Also it could be hung from the bottom of a cabinet, shelf? using a screw or two into the bottom of the can
    Great tips. Thank you!
    NICE RECYCLING INSTRUCTABLES!
