3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Beer Can Usb hub hack
Step 3If you aren't using lights skip this step
If you aren\
Get your small plastic container (I used the retail box from those mini highlighters that smell like food and stuff). Cut a flap out of the end of the box that doesn't open it should be the tiniest bit smaller than the length from the outside edge of the first port to the outside edge of the last and about the height of the ports the plastic was kinda frosted so it helped with the light.
Insert the board into the opening end of the box and push the ports out through your flap you made, you'll notice that there are little flaps on the ports that stick out so pull the board back until the flap is stuck behind them (this is just handy way to get them out a bit for easy access and holds them and the board out straight) now take two safety pins and push them through the plastic box right behind the board stopping the board from moving back. Push the pin end right up so the clipping side is against the box then bend the pins down against your box.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
197
Author:killerjackalope(My website)
A northern ireland based maker that likes breaking stuff as well as fixing it, of no fixed abode for now Working PR for a club in Belfast and freelance photography. I enjoy working with computers,...
more »
